[petsc-users] Warning while compiling Fortran with PETSc
Thu Feb 10 09:37:17 CST 2022
On Thu, Feb 10, 2022 at 10:34 AM Bojan Niceno <
bojan.niceno.scientist at gmail.com> wrote:
> Dear Satish,
> Thanks for the answer.  Your suggestion makes a lot of sense, but this is
> what I get as a result of that:
> Running check examples to verify correct installation
> Using PETSC_DIR=/home/niceno/Development/petsc-debug and
> PETSC_ARCH=arch-linux-c-debug
> Possible error running C/C++ src/snes/tutorials/ex19 with 1 MPI process
> See http://www.mcs.anl.gov/petsc/documentation/faq.html
> Invalid MIT-MAGIC-COOKIE-1 keylid velocity = 0.0016, prandtl # = 1.,
> grashof # = 1.
> Number of SNES iterations = 2
> Possible error running C/C++ src/snes/tutorials/ex19 with 2 MPI processes
> grashof # = 1.
> Possible error running Fortran example src/snes/tutorials/ex5f with 1 MPI
> process
> Invalid MIT-MAGIC-COOKIE-1 keyNumber of SNES iterations =     4
> Completed test examples
> I am getting the "Possible error running Fortran example" warning with
> this.  This somehow looks more severe to me.  But I could be wrong.
You are getting this message because your MPI implementation is printing
It is still running fine, but this is an MPI configuration issue.
     Matt
Any suggestions what to do?
>     Kind regards,
>     Bojan
> On Wed, Feb 9, 2022 at 5:49 PM Satish Balay <balay at mcs.anl.gov> wrote:
>> To clarify:
>> you are using --download-openmpi=yes with petsc. However you say:
>> > > The mpif90 command which
>> > > I use to compile the code, wraps gfortran with OpenMPI
>> This suggests a different install of OpenMPI is used to build your code.
>> One way to resolve this is - delete current build of PETSc - and rebuild
>> it with this same MPI [that you are using with your application]
>> ./configure --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90
>> --download-fblaslapack --download-metis --download-parmetis --download-cmake
>> Also PETSc provides makefile format that minimizes such conflicts..
>> https://petsc.org/release/docs/manual/getting_started/#writing-c-c-or-fortran-applications
>> Satish
>> On Wed, 9 Feb 2022, Balay, Satish via petsc-users wrote:
>> > Are you using the same MPI to build both PETSc and your appliation?
>> > Satish
>> > On Wed, 2022-02-09 at 05:21 +0100, Bojan Niceno wrote:
>> > > To whom it may concern,
>> > > I am working on a Fortran (2003) computational fluid dynamics solver,
>> > > which is actually quite mature, was parallelized with MPI from the
>> > > very beginning and it comes with its own suite of Krylov solvers.
>> > > Although the code is self-sustained, I am inclined to believe that it
>> > > would be better to use PETSc instead of my own home-grown solvers.
>> > > In the attempt to do so, I have installed PETSc 3.16.4 with following
>> > > options:
>> > > ./configure --with-debugging=yes --download-openmpi=yes --download-
>> > > fblaslapack=yes --download-metis=yes --download-parmetis=yes --
>> > > download-cmake=yes
>> > > on a workstation running Ubuntu 20.04 LTS.  The mpif90 command which
>> > > I use to compile the code, wraps gfortran with OpenMPI, hence the
>> > > option "--download-openmpi=yes" when configuring PETSc.
>> > > Anyhow, installation of PETSc went fine, I managed to link and run it
>> > > with my code, but I am getting the following messages during
>> > > compilation:
>> > > Petsc_Mod.f90:18:6:
>> > >    18 |   use PetscMat, only: tMat, MAT_FINAL_ASSEMBLY
>> > >       |      1
>> > > Warning: Named COMMON block ‘mpi_fortran_bottom’ at (1) shall be of
>> > > the same size as elsewhere (4 vs 8 bytes)
>> > > Petsc_Mod.f90 is a module I wrote for interfacing PETSc.  All works,
>> > > but these messages give me a reason to worry.
>> > > Can you tell what causes this warnings?  I would guess they might
>> > > appear if one mixes OpenMPI with MPICH, but I don't think I even have
>> > > MPICH on my system.
>> > > Please let me know what you think about it?
>> > >     Cheers,
>> > >     Bojan
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220210/45b89c4c/attachment.html>
