[petsc-users] Update of the buffer
Stefano Zampini stefano.zampini at gmail.com
Thu Feb 10 09:02:54 CST 2022
> On Feb 10, 2022, at 6:00 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Feb 10, 2022 at 9:17 AM Medane TCHAKOROM <medane.tchakorom at univ-fcomte.fr <mailto:medane.tchakorom at univ-fcomte.fr>> wrote:
> Hello ,
> Sorry if this question does not belong to this mailling list, i'am using Petsc , but with some
> MPI parts code, when dealing with communication.
> If a make two consecutive MPI_Isend requests, and if the destination processor has not yet receive the message inbetween the two calls, will the buffer be updated ? I mean if I send message "1" for the first request, then send "0" as the second message. Will the receiver receive "0" as message ? I not, how can I do to update the message ?
> I believe that MPI guarantees in-order message delivery from a source to a target, so if you send 1 before 0, the receiver
> should get them in that order. However, someone here should know for sure.
I don’t think so. You should use tags to flag the proper operation and wait for it if you need the value to arrive.
>   Thanks,
>     Matt
> Thanks
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220210/3468424b/attachment.html>
