[petsc-users] Quasi newton SNES change variable
Yann Jobic yann.jobic at univ-amu.fr
Wed Feb 9 09:33:30 CST 2022
I'm struggling for a very simple error that i can not see. I'm running
in a sequential program, for the test.
MatView is giving me for the row 125 :
row 125: (125, 0.)  (107, 0.)
I'm getting those values with MatGetRow :
       row=125
       CALL MatGetRow(MATGLOB,row,nb,testcols,testvalues,IER)
       write(*,*)row,testcols(1),testvalues(1),
      &          testcols(2),testvalues(2)
       CALL MatRestoreRow(MATGLOB,row,nb,testcols,testvalues,IER)
The output is :
       125    125  0.000000000000000E+000     107    0.000000000000000E+000
Which is what i want. It's ok.
Then i'm doing the MatSetValue :
       val = -1
       row = 125
       col = 107
       CALL MatSetValue(MATGLOB,row,col,val,
      &                  INSERT_VALUES, IER)
And i've got the error :
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Argument out of range
[0]PETSC ERROR: New nonzero at (125,107) caused a malloc
Use MatSetOption(A, MAT_NEW_NONZERO_ALLOCATION_ERR, PETSC_FALSE) to turn
off this check
[0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.16.4, unknown
[0]PETSC ERROR:
/home/jobic/projet/fe-utils/marcus/3.16/test_MatSetValue_loem_3.16p4_openmpi_intel
on a  named leto4.iusti-calcul.recherche by jobic Wed Feb  9 16:01:51 2022
[0]PETSC ERROR: Configure options
--prefix=/local/lib/petsc/3.16/p4/17/openmpi_intel-mkl-works
--with-single-library=0 --with-large-file-io=1 --with-debugging=0
--with-blacs=1
--with-blacs-dir=/opt/intel/compilers_and_libraries_2017.1.132/linux/compiler/lib/intel64/
--download-scalapack=1 --download-parmetis=1 --download-make=1
--download-mumps=1 --LIBS="
-Wl,-rpath,/opt/intel/compilers_and_libraries_2017.1.132/linux/compiler/lib/intel64/"
--with-blaslapack-dir=/opt/intel/compilers_and_libraries_2017.1.132/linux/compiler/lib/intel64/
--download-metis=1 --download-parmetis=1 --download-ptscotch=1
--download-cmake=1 --download-slepc=1 --download-hdf5=1 --with-zlib=1
--download-szlib=1 --download-suitesparse=1 --download-p4est=1
--download-netcdf=1 --download-triangle=1 --with-shared-libraries=0
--with-cxx-dialect=C++11 -CFLAGS=" -O3 -mtune=core-avx2 -mkl"
--COPTFLAGS="-D_POSIX_C_SOURCE=199309L" -CXXFLAGS=" -O3 -mtune=core-avx2
-mkl" -FFLAGS=" -O3 -mtune=core-avx2 -mkl"
PETSC_ARCH=openmpi_intel-mkl-17-works
[0]PETSC ERROR: #1 MatSetValues_SeqAIJ() at
/home/devel/src_linux/petsc-3.16.4/src/mat/impls/aij/seq/aij.c:520
[0]PETSC ERROR: #2 MatSetValues() at
/home/devel/src_linux/petsc-3.16.4/src/mat/interface/matrix.c:1398
[0]PETSC ERROR: #3 MatGetRow() at
/home/devel/src_linux/petsc-3.16.4/src/mat/interface/matrix.c:558
[0]PETSC ERROR: #4 MatRestoreRow_Fortran() at
/home/devel/src_linux/petsc-3.16.4/src/mat/interface/ftn-custom/zmatrixf.c:582
I'm obviously doing something wrong, but where ?
Yann
Le 2/9/2022 à 1:58 PM, Matthew Knepley a écrit :
> On Wed, Feb 9, 2022 at 7:24 AM Bruno Rammon Silva Souza via petsc-users
> <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
>     Hello everyone,
>     I am using the LBFGS type in the SNES solver, and it's working fine.
>     But I want to change the number of stored updates in this method.
>     This variable of quasi-newton methods is usually chosen by the
>     runtime option: -snes_qn_m <m>. However, I would like to change this
>     variable inside my code, when calling a function, for example, but I
>     can't find any kind of PETSc function that changes this variable
>     directly. Is there any function like this? If not, is there some way
>     to do that without using -snes_qn_m <m> at runtime?
> This is an oversight which we will fix. For now you can use
> https://petsc.org/main/docs/manualpages/Sys/PetscOptionsSetValue.html
> <https://petsc.org/main/docs/manualpages/Sys/PetscOptionsSetValue.html>
> in your code.
>    Thanks,
>       Matt
>     Best regards,
>     Bruno Souza
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
