[petsc-users] Matrix preallocation
Samuel Estes
samuelestes91 at gmail.com
Sun Feb 6 13:39:07 CST 2022
First of all, thank you so much for the detailed answers!
That clears up most of my confusion. Just to clarify let me make sure I
understand everything:
1. So it seems that your advice is just to call the
MatXAIJSetPreallocation() routine (rather than make separate calls to other
preallocation routines such as MatSeqAIJPreallcation() and
MatMPIAIJPreallcation())? This will preallocate for Seq and MPI matrices
(among other types) and the decision will be made at runtime?
2. So the old way was just to call MatSeqAIJPreallcation() and
MatMPIAIJPreallcation()? I had thought that if you called the sequential
version for a parallel matrix or vice versa that the program would crash.
It seems that instead nothing happens, so by calling both you were covered
in either case. Is this correct? Essentially, one would always execute and
the other would do nothing?
3. If the dnnzu and onnzu arrays for the upper triangular parts seem
unnecessary for me I can just call the MatXAIJSetPreallocation() routine
with those values set to 'NULL'? I'm really just looking for a blend of the
MatSeqAIJPreallcation() and MatMPIAIJPreallcation() routines so it seems
that I only need dnnz and onnz arrays.
4. If we ignore the dnnzu and onnzu upper triangular parameters, then the
MatXAIJSetPreallocation() routine has the same parameters as the
MatMPIAIJSetPreallocation() routine without the option to give constant
integer values for diagonal and off-diagonal parts of the matrix so it
seems clear to me how this routine would work for a parallel matrix when
the upper triangular parameters are NULL. If the matrix is sequential then
does MPIXAIJSetPreallocation() just ignore the onnz parameter and just use
the dnnz parameter as the sole argument for determining preallocation?
Thanks again for all the help. I think I understand well enough to use this
routine now. The questions above are mostly just to clarify and
double-check that I understood your previous responses correctly.
Sam
On Sat, Feb 5, 2022 at 10:12 AM Mark Adams <mfadams at lbl.gov> wrote:
> On Sat, Feb 5, 2022 at 10:36 AM Matthew Knepley <knepley at gmail.com> wrote:
>> On Fri, Feb 4, 2022 at 11:47 PM Samuel Estes <samuelestes91 at gmail.com>
>> wrote:
>>> Hi,
>>> I have a very basic question about matrix preallocation. I am trying to
>>> use the MatCreate(), MatSetFromOptions(), MatXXXXSetPreallocation()
>>> paradigm. I thought that I should use the MatXAIJSetPreallocation() routine
>>> since the code may be run with a SeqAIJ or MPIAIJ matrix but I do not
>>> understand all of the inputs required for the
>>> MatXAIJSetPreallocation routine. In particular, the dnnzu and
>>> onnzu variables don't quite make sense to me. Can these be NULL? I was
>>> basically just hoping for a routine that would preallocate for either a
>>> sequential or parallel matrix depending on what was given at runtime. This
>>> routine seems to be what I want but I don't understand it very well and the
>>> documentation hasn't helped me to figure it out.
>> The example for this is here
>> https://petsc.org/main/docs/manualpages/Mat/MatMPIAIJSetPreallocation.html#MatMPIAIJSetPreallocation
>> Maybe we should copy it to the XAIJ page as well. Does this help explain
>> the arguments?
>>> A related followup question: Is it good practice to use this function or
>>> should I just use the other routines like MatSeqAIJSetPreallocation() and
>>> MatMPIAIJSetPreallocation()?
>>> And finally my last question: if I were to use the
>>> MatSeqAIJSetPreallocation()/MatMPIAIJSetPreallocation() routines for
>>> preallocating memory, is it common to just call MatGetType() then call the
>>> appropriate routine depending on whether or not the matrix is parallel or
>>> not? I ask because when I have tested these routines out, it seems
>>> that MatSeqAIJSetPreallocation() works even for parallel matrices which is
>>> a bit confusing. I'm assuming that it just sets the diagonal part of the
>>> matrix?
>> No, it definitely will not preallocate in parallel, so something else is
>> happening.
> With only MatSeqAIJSetPreallocation in parallel it would not do any
> preallocation, in which case it would fall back to dynamic allocation. I'm
> guessing that is what is happening and it will be very slow.
>> Thanks,
>> Matt
>>> I hope that my questions were clear. Let me know if they need
>>> clarification and thanks in advance for the help!
>>> Sam
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220206/6d8a0b94/attachment.html>
