[petsc-users] 3.16.4 amd blis libflame linking problem
Matthew Knepley
knepley at gmail.com
Fri Feb 4 11:13:12 CST 2022
Can you send the 3.9 log?
Matt
On Fri, Feb 4, 2022 at 12:00 PM Anton Popov <popov at uni-mainz.de> wrote:
> On 04.02.22 17:39, Matthew Knepley wrote:
> On Fri, Feb 4, 2022 at 11:35 AM Anton Popov <popov at uni-mainz.de> wrote:
>> Hi Satish,
>> I just discovered that PETSc 3.16.4 fails to link against the latest AMD
>> BLIS and LibFLAME libraries on a Linux box.
>> You set a value for --with-blas-lib=<lib> and --with-lapack-lib=<lib>,
>> but ['/opt/amd/amd-blis-3.1.0/lib/lp64/libblis.a'] and
>> ['/opt/amd/amd-libflame-3.1.0/lib/lp64/libflame.a'] cannot be used
>> My previous experience with 3.9.4 on the same system was fully
>> successful. Looking in the configure logs (attached) reveals small
>> difference in the linking compared to 3.9.4
>> Could you please make a guess what went wrong?
> Down in the log I see:
> /usr/bin/ld: warning: libgfortran.so.5, needed by
> /opt/amd/amd-libflame-3.1.0/lib/lp64/libflame.so, not found (try using
> -rpath or -rpath-link):
> Thanks Matt, I'll try.
> Did the gfortran library move or get upgraded?
> Not at all. I have configured 3.9.4 just now to make a test, and it
> perfectly finds all the libraries. So there must be something that 3.16.4
> does differently.
> Best,
> Anton
> Thanks,
> Matt
>> Best regards,
>> Anton
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220204/63b1b87a/attachment.html>
