[petsc-users] PETSc GPU MatMatMult performance question
Mark Adams
mfadams at lbl.gov
Thu Feb 3 11:42:40 CST 2022
Oly 5% on the GPU:
MatMatMultNum 20 1.0 9.9320e+01 1.1 2.90e+11 1.0 4.0e+01 2.1e+09
0.0e+00 46 67 57 65 0 93100100100 0 5777 182577 0 0.00e+00 20
4.16e+04 *5*
A bug in MPI-MatMatMultNum? Maybe a device method is not implemented?
On Thu, Feb 3, 2022 at 12:29 PM Rohan Yadav <rohany at alumni.cmu.edu> wrote:
> > Please send the code that builds the sparse B matrix and the setMatToConstant()
> routine.
> Setting to a constant:
> void setMatToConstant(Mat mat, PetscScalar c) {
> PetscInt rStart, rEnd, m, n;
> MatGetSize(mat, &m, &n);
> MatGetOwnershipRange(mat, &rStart, &rEnd);
> for (int i = rStart; i < rEnd; i++) {
> for (int j = 0; j < n; j++) {
> MatSetValue(mat, i, j, c, INSERT_VALUES);
> MatAssemblyBegin(mat, MAT_FINAL_ASSEMBLY);
> MatAssemblyEnd(mat, MAT_FINAL_ASSEMBLY);
> Loading sparse matrix from disk:
> int loadMatrixFromFile(Mat* A, char* filename) {
> auto ierr = MatCreate(PETSC_COMM_WORLD, A); CHKERRQ(ierr);
> MatSetFromOptions(*A);
> PetscViewer viewer;
> PetscViewerCreate(PETSC_COMM_WORLD, &viewer);
> PetscViewerSetType(viewer, PETSCVIEWERBINARY);
> PetscViewerFileSetMode(viewer, FILE_MODE_READ);
> PetscViewerFileSetName(viewer, filename);
> MatLoad(*A, viewer);
> return 0;
> These are only called once and should not affect the computation in a loop though.
> > But first please verify that if you run with one MPI rank the "on GPU" and the overall flop rates for the MatMatMult() are almost the same and there is no copy from the GPU for each multiply?
> Yes, with 1 mpi rank / GPU there are no extra copies done. As soon as I
> move to 2 ranks I see this behavior.
> Here are updated logs with a new stage for 2 ranks. I've staged the logs
> into "MyComputation".
> ---------------------------------------------- PETSc Performance Summary:
> /g/g15/yadav2/taco/petsc/bin/benchmark on a named lassen572 with 2
> processors, by yadav2 Thu Feb 3 09:27:30 2022
> Using Petsc Release Version 3.16.3, unknown
> Max Max/Min Avg Total
> Time (sec): 2.091e+02 1.001 2.090e+02
> Objects: 4.800e+01 1.000 4.800e+01
> Flop: 4.344e+11 1.019 4.303e+11 8.606e+11
> Flop/sec: 2.077e+09 1.018 2.059e+09 4.118e+09
> MPI Messages: 3.500e+01 1.000 3.500e+01 7.000e+01
> MPI Message Lengths: 6.316e+10 1.000 1.805e+09 1.263e+11
> MPI Reductions: 8.100e+01 1.000
> Flop counting convention: 1 flop = 1 real number operation of type
> (multiply/divide/add/subtract)
> e.g., VecAXPY() for real vectors of length N
> --> 2N flop
> and VecAXPY() for complex vectors of length N
> --> 8N flop
> Summary of Stages: ----- Time ------ ----- Flop ------ --- Messages
> --- -- Message Lengths -- -- Reductions --
> Avg %Total Avg %Total Count
> %Total Avg %Total Count %Total
> 0: Main Stage: 1.0555e+02 50.5% 2.8686e+11 33.3% 3.000e+01
> 42.9% 1.466e+09 34.8% 4.300e+01 53.1%
> 1: MyComputation: 1.0345e+02 49.5% 5.7373e+11 66.7% 4.000e+01
> 57.1% 2.058e+09 65.2% 2.000e+01 24.7%
> See the 'Profiling' chapter of the users' manual for details on
> interpreting output.
> Phase summary info:
> Count: number of times phase was executed
> Time and Flop: Max - maximum over all processors
> Ratio - ratio of maximum to minimum over all processors
> Mess: number of messages sent
> AvgLen: average message length (bytes)
> Reduct: number of global reductions
> Global: entire computation
> Stage: stages of a computation. Set stages with PetscLogStagePush() and
> PetscLogStagePop().
> %T - percent time in this phase %F - percent flop in this
> phase
> %M - percent messages in this phase %L - percent message lengths
> in this phase
> %R - percent reductions in this phase
> Total Mflop/s: 10e-6 * (sum of flop over all processors)/(max time over
> all processors)
> GPU Mflop/s: 10e-6 * (sum of flop on GPU over all processors)/(max GPU
> time over all processors)
> CpuToGpu Count: total number of CPU to GPU copies per processor
> CpuToGpu Size (Mbytes): 10e-6 * (total size of CPU to GPU copies per
> processor)
> GpuToCpu Count: total number of GPU to CPU copies per processor
> GpuToCpu Size (Mbytes): 10e-6 * (total size of GPU to CPU copies per
> processor)
> GPU %F: percent flops on GPU in this event
> Event Count Time (sec) Flop
> --- Global --- --- Stage ---- Total GPU - CpuToGpu - -
> GpuToCpu - GPU
> Max Ratio Max Ratio Max Ratio Mess AvgLen
> Reduct %T %F %M %L %R %T %F %M %L %R Mflop/s Mflop/s Count Size
> Count Size %F
> --- Event Stage 0: Main Stage
> BuildTwoSided 2 1.0 4.0085e-0136.3 0.00e+00 0.0 2.0e+00 4.0e+00
> 2.0e+00 0 0 3 0 2 0 0 7 0 5 0 0 0 0.00e+00 0
> 0.00e+00 0
> BuildTwoSidedF 1 1.0 4.0080e-0113602.0 0.00e+00 0.0 0.0e+00
> 0.0e+00 1.0e+00 0 0 0 0 1 0 0 0 0 2 0 0 0
> 0.00e+00 0 0.00e+00 0
> MatAssemblyBegin 12 1.0 4.0084e-017217.1 0.00e+00 0.0 0.0e+00 0.0e+00
> 1.0e+00 0 0 0 0 1 0 0 0 0 2 0 0 0 0.00e+00 0
> 0.00e+00 0
> MatAssemblyEnd 12 1.0 3.4970e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 6.0e+00 2 0 0 0 7 3 0 0 0 14 0 0 0 0.00e+00 0
> 0.00e+00 0
> MatZeroEntries 1 1.0 2.4093e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00 0 0 0 0 0 0 0 0 0 0 0 0 0 0.00e+00 0
> 0.00e+00 0
> MatLoad 1 1.0 1.3756e+01 1.0 0.00e+00 0.0 6.0e+00 4.6e+08
> 2.1e+01 7 0 9 2 26 13 0 20 6 49 0 0 0 0.00e+00 0
> 0.00e+00 0
> MatMatMultSym 20 1.0 4.7919e+00 2.4 0.00e+00 0.0 4.0e+00 1.6e+07
> 1.2e+01 2 0 6 0 15 3 0 13 0 28 0 0 0 0.00e+00 0
> 0.00e+00 0
> MatMatMultNum 10 1.0 4.9853e+01 1.1 1.45e+11 1.0 2.0e+01 2.1e+09
> 0.0e+00 23 33 29 33 0 46100 67 94 0 5754 182686 2 2.23e+03 10
> 2.08e+04 5
> MatCUSPARSCopyTo 1 1.0 2.2646e-02 1.1 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00 0 0 0 0 0 0 0 0 0 0 0 0 1 1.55e+02 0
> 0.00e+00 0
> MatDenseCopyTo 1 1.0 1.6636e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00 0 0 0 0 0 0 0 0 0 0 0 0 1 2.08e+03 0
> 0.00e+00 0
> MatDenseCopyFrom 11 1.0 3.0463e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00 1 0 0 0 0 3 0 0 0 0 0 0 0 0.00e+00 11
> 2.29e+04 0
> VecSet 3 1.0 5.0035e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.00e+00 0
> SFSetGraph 1 1.0 4.4294e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.00e+00 0
> SFSetUp 1 1.0 1.3982e-01 1.0 0.00e+00 0.0 4.0e+00 1.6e+07
> 1.0e+00 0 0 6 0 1 0 0 13 0 2 0 0 0 0.00e+00 0
> 0.00e+00 0
> --- Event Stage 1: MyComputation
> MatAssemblyBegin 20 1.0 1.6894e-05 2.7 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.00e+00 0
> MatAssemblyEnd 20 1.0 1.5575e-05 1.5 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.00e+00 0
> MatMatMultSym 40 1.0 1.0096e+01 2.6 0.00e+00 0.0 0.0e+00 0.0e+00
> 2.0e+01 3 0 0 0 25 7 0 0 0100 0 0 0 0.00e+00 0
> 0.00e+00 0
> 4.16e+04 5
> MatDenseCopyFrom 20 1.0 5.5380e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00 3 0 0 0 0 5 0 0 0 0 0 0 0 0.00e+00 20
> 4.16e+04 0
> Memory usage is given in bytes:
> Object Type Creations Destructions Memory Descendants' Mem.
> Reports information only for process 0.
> Matrix 17 10 20381695840 0.
> Viewer 2 0 0 0.
> Vector 4 1 1792 0.
> Index Set 2 2 31848152 0.
> Star Forest Graph 3 0 0 0.
> Matrix 20 20 40763391680 0.
> Average time to get PetscTime(): 3.96e-08
> Average time for MPI_Barrier(): 8.184e-07
> Average time for zero size MPI_Send(): 2.8165e-06
> #PETSc Option Table entries:
> -bench spmm
> -enable_gpu
> -log_view
> -mat_type aijcusparse
> -matload_block_size 1
> -matrix /p/gpfs1/yadav2/tensors/petsc/nlpkkt200.petsc
> -n 20
> -vec_type cuda
> -warmup 10
> #End of PETSc Option Table entries
> Compiled without FORTRAN kernels
> Compiled with full precision matrices (default)
> sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8
> sizeof(PetscScalar) 8 sizeof(PetscInt) 4
> Configure options: --download-c2html=0 --download-hwloc=0
> --download-sowing=0 --prefix=./petsc-install/ --with-64-bit-indices=0
> --with-blaslapack-lib="/usr/tcetmp/packages/lapack/lapack-3.9.0-gcc-7.3.1/lib/liblapack.so
> /usr/tcetmp/packages/lapack/lapack-3.9.0-gcc-7.3.1/lib/libblas.so"
> --with-cc=/usr/tce/packages/spectrum-mpi/spectrum-mpi-rolling-release-gcc-8.3.1/bin/mpigcc
> --with-clanguage=C --with-cxx-dialect=C++17
> --with-cxx=/usr/tce/packages/spectrum-mpi/spectrum-mpi-rolling-release-gcc-8.3.1/bin/mpig++
> --with-cuda=1 --with-debugging=0
> --with-fc=/usr/tce/packages/spectrum-mpi/spectrum-mpi-rolling-release-gcc-8.3.1/bin/mpigfortran
> --with-fftw=0
> --with-hdf5-dir=/usr/tcetmp/packages/petsc/build/3.13.0/spack/opt/spack/linux-rhel7-power9le/xl_r-16.1/hdf5-1.10.6-e7e7urb5k7va3ib7j4uro56grvzmcmd4
> --with-hdf5=1 --with-mumps=0 --with-precision=double --with-scalapack=0
> --with-scalar-type=real --with-shared-libraries=1 --with-ssl=0
> --with-suitesparse=0 --with-trilinos=0 --with-valgrind=0 --with-x=0
> --with-zlib-include=/usr/include --with-zlib-lib=/usr/lib64/libz.so
> --with-zlib=1 CFLAGS="-g -DNoChange" COPTFLAGS="-O3" CXXFLAGS="-O3"
> CXXOPTFLAGS="-O3" FFLAGS=-g CUDAFLAGS=-std=c++17 FOPTFLAGS=
> PETSC_ARCH=arch-linux-c-opt
> Libraries compiled on 2022-01-21 06:41:50 on lassen111
> Machine characteristics:
> Linux-4.14.0-115.21.2.1chaos.ch6a.ppc64le-ppc64le-with-redhat-7.6-Maipo
> Using PETSc directory: /g/g15/yadav2/taco/petsc/petsc/petsc-install
> Using PETSc arch:
> Using C compiler:
> -g -DNoChange -fPIC "-O3"
> Using Fortran compiler:
> -g -fPIC
> Using include paths:
> -I/g/g15/yadav2/taco/petsc/petsc/petsc-install/include
> -I/usr/tcetmp/packages/petsc/build/3.13.0/spack/opt/spack/linux-rhel7-power9le/xl_r-16.1/hdf5-1.10.6-e7e7urb5k7va3ib7j4uro56grvzmcmd4/include
> -I/usr/include -I/usr/tce/packages/cuda/cuda-11.1.0/include
> Using C linker:
> Using Fortran linker:
> Using libraries:
> -Wl,-rpath,/g/g15/yadav2/taco/petsc/petsc/petsc-install/lib
> -L/g/g15/yadav2/taco/petsc/petsc/petsc-install/lib -lpetsc
> -Wl,-rpath,/usr/tcetmp/packages/lapack/lapack-3.9.0-gcc-7.3.1/lib
> -L/usr/tcetmp/packages/lapack/lapack-3.9.0-gcc-7.3.1/lib
> -Wl,-rpath,/usr/tcetmp/packages/petsc/build/3.13.0/spack/opt/spack/linux-rhel7-power9le/xl_r-16.1/hdf5-1.10.6-e7e7urb5k7va3ib7j4uro56grvzmcmd4/lib
> -L/usr/tcetmp/packages/petsc/build/3.13.0/spack/opt/spack/linux-rhel7-power9le/xl_r-16.1/hdf5-1.10.6-e7e7urb5k7va3ib7j4uro56grvzmcmd4/lib
> -Wl,-rpath,/usr/tce/packages/cuda/cuda-11.1.0/lib64
> -L/usr/tce/packages/cuda/cuda-11.1.0/lib64
> -Wl,-rpath,/usr/tce/packages/spectrum-mpi/ibm/spectrum-mpi-rolling-release/lib
> -L/usr/tce/packages/spectrum-mpi/ibm/spectrum-mpi-rolling-release/lib
> -Wl,-rpath,/usr/tce/packages/gcc/gcc-8.3.1/rh/usr/lib/gcc/ppc64le-redhat-linux/8
> -L/usr/tce/packages/gcc/gcc-8.3.1/rh/usr/lib/gcc/ppc64le-redhat-linux/8
> -Wl,-rpath,/usr/tce/packages/gcc/gcc-8.3.1/rh/usr/lib64
> -L/usr/tce/packages/gcc/gcc-8.3.1/rh/usr/lib64
> -L/usr/tce/packages/gcc/gcc-8.3.1/rh/usr/lib -llapack -lblas -lhdf5_hl
> -lhdf5 -lm /usr/lib64/libz.so -lcuda -lcudart -lcufft -lcublas -lcusparse
> -lcusolver -lcurand -lstdc++ -ldl -lmpiprofilesupport -lmpi_ibm_usempi
> -lmpi_ibm_mpifh -lmpi_ibm -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath
> -lpthread -lquadmath -lstdc++ -ldl
> On Wed, Feb 2, 2022 at 11:59 PM Stefano Zampini <stefano.zampini at gmail.com>
> wrote:
>> 1) It uses MatMPIDenseScatter() to move to the other ranks their needed
>>> rows of the C matrix. That function has the call MatDenseGetArrayRead()
>>> normally would trigger a copy of C up to the CPU each time. But since C is
>>> not changing in your test run I guess it only triggers one copy.
>>> 2) If uses
>>> MatMatMultNumericAdd_SeqAIJ_SeqDense(aij->B,workB,cdense->A,PETSC_TRUE);CHKERRQ(ierr);
>>> to do the off diagonal part of the product but this triggers for each
>>> multiply a copy of the result matrix from the CPU to the GPU (hugely
>>> expensive)
>>> For performance there needs to be a new routine MatMatMultNumeric_MPIAIJCUSPRSE_MPICUDADense()
>>> that is smarter about the needed MPI communication so it only moves exactly
>>> what it needs to the other ranks and it does the off-diagonal part of the
>>> product on the GPU so it does not need to copy the result up to the CPU.
>> MPIAIJCUSPARSE uses MatProductSetFromOptions_MPIAIJBACKEND
>> Rohan
>> I would suggest to add PetscLogStage around your performance loop (do a
>> warmup outside of it) and send the relevant portion of the log
>>> Barry
>>> ---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
>>> /g/g15/yadav2/taco/petsc/bin/benchmark on a named lassen457 with 2 processors, by yadav2 Wed Feb 2 17:23:19 2022
>>> Time (sec): 1.163e+02 1.000 1.163e+02
>>> Flop: 6.338e+11 1.065 6.144e+11 1.229e+12
>>> Flop/sec: 5.451e+09 1.065 5.284e+09 1.057e+10
>>> MPI Message Lengths: 2.544e+09 1.000 7.267e+07 5.087e+09
>>> Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
>>> e.g., VecAXPY() for real vectors of length N --> 2N flop
>>> and VecAXPY() for complex vectors of length N --> 8N flop
>>> Summary of Stages: ----- Time ------ ----- Flop ------ --- Messages --- -- Message Lengths -- -- Reductions --
>>> Avg %Total Avg %Total Count %Total Avg %Total Count %Total
>>> 0: Main Stage: 1.1628e+02 100.0% 1.2288e+12 100.0% 7.000e+01 100.0% 7.267e+07 100.0% 6.300e+01 77.8%
>>> See the 'Profiling' chapter of the users' manual for details on interpreting output.
>>> Phase summary info:
>>> Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
>>> %T - percent time in this phase %F - percent flop in this phase
>>> %M - percent messages in this phase %L - percent message lengths in this phase
>>> Total Mflop/s: 10e-6 * (sum of flop over all processors)/(max time over all processors)
>>> GPU Mflop/s: 10e-6 * (sum of flop on GPU over all processors)/(max GPU time over all processors)
>>> CpuToGpu Size (Mbytes): 10e-6 * (total size of CPU to GPU copies per processor)
>>> GpuToCpu Size (Mbytes): 10e-6 * (total size of GPU to CPU copies per processor)
>>> Event Count Time (sec) Flop --- Global --- --- Stage ---- Total GPU - CpuToGpu - - GpuToCpu - GPU
>>> Max Ratio Max Ratio Max Ratio Mess AvgLen Reduct %T %F %M %L %R %T %F %M %L %R Mflop/s Mflop/s Count Size Count Size %F
>>> BuildTwoSided 2 1.0 4.4400e-01567.5 0.00e+00 0.0 2.0e+00 4.0e+00 2.0e+00 0 0 3 0 2 0 0 3 0 3 0 0 0 0.00e+00 0 0.00e+00 0
>>> BuildTwoSidedF 1 1.0 4.4395e-0115659.1 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+00 0 0 0 0 1 0 0 0 0 2 0 0 0 0.00e+00 0 0.00e+00 0
>>> MatAssemblyBegin 32 1.0 4.4400e-017378.9 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+00 0 0 0 0 1 0 0 0 0 2 0 0 0 0.00e+00 0 0.00e+00 0
>>> MatAssemblyEnd 32 1.0 1.8511e+00 2.2 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00 1 0 0 0 7 1 0 0 0 10 0 0 0 0.00e+00 0 0.00e+00 0
>>> MatZeroEntries 1 1.0 3.3306e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0 0 0 0.00e+00 0 0.00e+00 0
>>> MatLoad 1 1.0 1.7220e+01 1.0 0.00e+00 0.0 6.0e+00 -8.8e+07 2.1e+01 15 0 9-10 26 15 0 9-10 33 0 0 0 0.00e+00 0 0.00e+00 0
>>> MatMatMultSym 60 1.0 9.2215e-01 2.6 0.00e+00 0.0 4.0e+00 7.3e+05 3.2e+01 1 0 6 0 40 1 0 6 0 51 0 0 0 0.00e+00 0 0.00e+00 0
>>> MatMatMultNum 30 1.0 4.2967e+01 1.0 6.34e+11 1.1 6.0e+01 9.4e+07 0.0e+00 37100 86110 0 37100 86110 0 28598 920026 2 6.71e+03 30 8.73e+04 98
>>> MatCUSPARSCopyTo 1 1.0 4.4761e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0 0 1 3.80e+03 0 0.00e+00 0
>>> MatDenseCopyTo 1 1.0 2.2742e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0 0 1 2.91e+03 0 0.00e+00 0
>>> MatDenseCopyFrom 31 1.0 1.2006e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 10 0 0 0 0 10 0 0 0 0 0 0 0 0.00e+00 31 9.02e+04 0
>>> VecSet 3 1.0 4.1917e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0 0 0 0.00e+00 0 0.00e+00 0
>>> SFSetGraph 1 1.0 1.9180e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0 0 0 0.00e+00 0 0.00e+00 0
>>> SFSetUp 1 1.0 1.3672e-02 1.1 0.00e+00 0.0 4.0e+00 7.3e+05 1.0e+00 0 0 6 0 1 0 0 6 0 2 0 0 0 0.00e+00 0 0.00e+00 0
>>> Matrix 37 30 2867511840 0.
>>> Viewer 2 0 0 0.
>>> Vector 4 1 1792 0.
>>> Index Set 2 2 1495248 0.
>>> Average time to get PetscTime(): 3.83e-08
>>> Average time for MPI_Barrier(): 7.874e-07
>>> Average time for zero size MPI_Send(): 3.4035e-06
>>> -bench spmm
>>> -enable_gpu
>>> -log_view
>>> -matrix /p/gpfs1/yadav2/tensors/petsc/arabic-2005.petsc
>>> -n 20
>>> -vec_type cuda
>>> -warmup 10
>>> Thanks,
>>> Rohan Yadav
>> Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220203/149dbd86/attachment-0001.html>
