[petsc-users] [petsc-dev] MatPreallocatorPreallocate segfault with PETSC 3.16
Stefano Zampini
stefano.zampini at gmail.com
Tue Feb 1 09:59:54 CST 2022
Il giorno mar 1 feb 2022 alle ore 18:34 Jed Brown <jed at jedbrown.org> ha
scritto:
> Patrick Sanan <patrick.sanan at gmail.com> writes:
> > Am Di., 1. Feb. 2022 um 16:20 Uhr schrieb Jed Brown <jed at jedbrown.org>:
> >> > Sorry about the delay on this. I can reproduce.
> >> > This regression appears to be a result of this optimization:
> >> > https://gitlab.com/petsc/petsc/-/merge_requests/4273
> >> Thanks for tracking this down. Is there a reason to prefer preallocating
> >> twice
> >> ierr =
> >> MatPreallocatorPreallocate(preallocator,PETSC_TRUE,A);CHKERRQ(ierr);
> >> ierr =
> MatPreallocatorPreallocate(preallocator,PETSC_TRUE,A_duplicate);CHKERRQ(ierr);
> >> versus using MatDuplicate() or MatConvert()?
Jed
this is not the point. Suppose you pass around only a preallocator, but do
not pass around the matrices. Reusing the preallocator should be allowed.
> > Maybe if your preallocation is an overestimate for each of two different
> > post-assembly non-zero structures in A and A_duplicate?
> Even then, why not preallocate A and duplicate immediately, before
> compressing out zeros?
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220201/2015926c/attachment.html>
