[petsc-users] Global Vector Generated from Section memory error
Nicholas Arnold-Medabalimi
narnoldm at umich.edu
Wed Dec 28 13:10:55 CST 2022
Hi Petsc Users
I've been working with vectors generated from a DM and getting some odd
memory errors. Using Valgrind, I have been able to trace the issue to
DMCreateGlobalVector. I've reduced the code to a relatively simple routine
(very similar to example 7) and attached it. I suspect the issue comes down
to something improperly set in the section. The code, when integrated, will
run correctly 10-30% of the time and otherwise give a memory corruption
error.
Any insight on the issue or possible error on my part would be appreciated.
Using Valgrind, I get the following error.
==27064== Invalid write of size 8
==27064== at 0x10C91E: main (section_vector_build.cpp:184)
==27064== Address 0xc4aa248 is 4 bytes after a block of size 3,204 alloc'd
==27064== at 0x483E0F0: memalign (in
/usr/lib/x86_64-linux-gnu/valgrind/vgpreload_memcheck-amd64-linux.so)
==27064== by 0x483E212: posix_memalign (in
==27064== by 0x4C4DAB0: PetscMallocAlign (mal.c:54)
==27064== by 0x4C5262F: PetscTrMallocDefault (mtr.c:186)
==27064== by 0x4C501F7: PetscMallocA (mal.c:420)
==27064== by 0x527E8A9: VecCreate_MPI_Private (pbvec.c:485)
==27064== by 0x527F04F: VecCreate_MPI (pbvec.c:523)
==27064== by 0x53E7097: VecSetType (vecreg.c:89)
==27064== by 0x527FBC8: VecCreate_Standard (pbvec.c:547)
==27064== by 0x6CD77C0: DMCreateGlobalVector_Section_Private (dmi.c:58)
==27064== by 0x61D52DB: DMCreateGlobalVector_Plex (plexcreate.c:4130)
Ph.D. Candidate
Computational Aeroscience Lab
University of Michigan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221228/6fcece4e/attachment.html>
#include <iostream>
#include <math.h>
#include <petscdm.h>
#include <petscksp.h>
#include <petscsnes.h>
#include <petscdmplex.h>
#include <petscsf.h>
#include "hdf5.h"
#define PI 3.14159265
static char help[] = "Show vector build seg fault error\n\n";
int rank, size;
PetscErrorCode ViewDM(DM V, std::string filename)
PetscViewer viewer;
PetscInt ierr;
ierr = PetscViewerCreate(PETSC_COMM_WORLD, &viewer);
ierr = PetscViewerSetType(viewer, PETSCVIEWERVTK);
ierr = PetscViewerFileSetMode(viewer, FILE_MODE_WRITE);
ierr = PetscViewerFileSetName(viewer, filename.c_str());
DMView(V, viewer);
ierr = PetscViewerDestroy(&viewer);
return 0;
PetscErrorCode ViewVec(Vec V, std::string filename)
PetscViewer viewer;
PetscInt ierr;
VecView(V, viewer);
return 0;
PetscErrorCode addSectionToDM(DM &dm, Vec &state)
int ierr;
int p0, p1, c0, c1;
DMPlexGetHeightStratum(dm, 0, &c0, &c1);
DMPlexGetChart(dm, &p0, &p1);
PetscSection section_full;
PetscSectionCreate(PETSC_COMM_WORLD, §ion_full);
PetscSectionSetNumFields(section_full, 2);
PetscSectionSetChart(section_full, p0, p1);
PetscSectionSetFieldComponents(section_full, 0, 1);
PetscSectionSetFieldComponents(section_full, 1, 1);
PetscSectionSetFieldName(section_full, 0, "Pressure");
PetscSectionSetFieldName(section_full, 1, "Temperature");
for (int i = c0; i < c1; i++)
PetscSectionSetDof(section_full, i, 2);
PetscSectionSetFieldDof(section_full, i, 0, 1);
PetscSectionSetFieldDof(section_full, i, 1, 1);
PetscSectionSetUp(section_full);
DMSetNumFields(dm, 2);
DMSetLocalSection(dm, section_full);
//PetscSectionView(section_full, PETSC_VIEWER_STDOUT_WORLD);
PetscSectionDestroy(§ion_full);
ierr=DMCreateGlobalVector(dm, &state);
CHKERRQ(ierr);
return 0;
int main(int argc, char **argv)
PetscErrorCode ierr;
// Creates Petsc world communicator just like MPI, No need for additional MPI call.
ierr = PetscInitialize(&argc, &argv, (char *)0, help);
MPI_Comm_size(PETSC_COMM_WORLD, &size);
MPI_Comm_rank(PETSC_COMM_WORLD, &rank);
if (!rank)
std::cout << "Running on " << size << " processors" << std::endl;
std::cout << help << std::endl;
DM dm, dmDist;
PetscInt i, dim = 2, overlap = 1;
PetscInt faces[dim];
/// Create 2D mesh
// -meshdim will set the square dimension of the mesh
// overlap sets the number of cells around each partition
faces[0] = 20;
PetscOptionsGetInt(NULL, NULL, "-meshdim", &(faces[0]), NULL);
PetscOptionsGetInt(NULL, NULL, "-overlap", &overlap, NULL);
faces[1] = faces[0];
PetscSF distributionSF;
PetscBool simplex = PETSC_FALSE, dmInterped = PETSC_TRUE;
PetscReal lower[2] = {0.0, 0.0};
PetscReal upper[2] = {2.0, 2.0};
ierr = DMPlexCreateBoxMesh(PETSC_COMM_WORLD, dim, simplex, faces, lower, upper, /* periodicity */ NULL, dmInterped, &dm);
CHKERRQ(ierr);
PetscPrintf(PETSC_COMM_WORLD, "Mesh created\n");
double t1 = 0, t2 = 0;
t1 = MPI_Wtime();
ierr = DMPlexDistribute(dm, overlap, &distributionSF, &dmDist);
t2 = MPI_Wtime();
CHKERRQ(ierr);
if (dmDist)
ierr = DMDestroy(&dm);
CHKERRQ(ierr);
dm = dmDist;
PetscPrintf(PETSC_COMM_WORLD, "Mesh distributed\n");
PetscInt c0, c1, f0, f1, e0, e1, v0, v1, p0, p1;
if (dim == 2)
DMPlexGetHeightStratum(dm, 1, &e0, &e1);
DMPlexGetHeightStratum(dm, 2, &v0, &v1);
PetscSynchronizedPrintf(PETSC_COMM_WORLD, "Rank %d\n", rank);
PetscSynchronizedPrintf(PETSC_COMM_WORLD, "Cells: p0:%d ,p1:%d \n", c0, c1);
PetscSynchronizedPrintf(PETSC_COMM_WORLD, "Edges: p0:%d ,p1:%d \n", e0, e1);
PetscSynchronizedPrintf(PETSC_COMM_WORLD, "Vertices: p0:%d ,p1:%d \n", v0, v1);
PetscSynchronizedFlush(PETSC_COMM_WORLD, NULL);
Vec state_full;
addSectionToDM(dm, state_full);
int o0, o1;
VecGetOwnershipRange(state_full, &o0, &o1);
PetscScalar *state_full_array;
VecGetArray(state_full, &state_full_array);
DMGetLocalSection(dm, §ion_full);
int offset;
PetscSectionGetOffset(section_full, i, &offset);
//PetscSynchronizedPrintf(PETSC_COMM_WORLD, "Rank %d, Cell %d, Offset %d\n", rank, i, offset);
state_full_array[offset] = 100000 + i + rank * 100;
state_full_array[offset + 1] = 300 + i + rank * 100;
//PetscSynchronizedFlush (PETSC_COMM_WORLD, NULL);
VecRestoreArray(state_full, &state_full_array);
ViewVec(state_full, "mesh_vec.vtu");
ierr = PetscFinalize();
return ierr;
