[petsc-users] Getting a vector from a DM to output VTK
Nicholas Arnold-Medabalimi narnoldm at umich.edu
Mon Dec 26 09:48:43 CST 2022
Oh it's not a worry. I'm debugging this first in C++, and once it's working
I don't actually need to view what's happening in Fortran when I move over.
In my C debugging code. After I create the distribution vector and
distribute the field based on your input, I'm adding
VecSetOperation(state_dist, VECOP_VIEW, (void(*)(void))VecView_Plex);
But I can't compile it because VecView_Plex is undefined. Thanks
Sincerely
Nicholas
On Mon, Dec 26, 2022 at 10:45 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Dec 26, 2022 at 10:40 AM Nicholas Arnold-Medabalimi <
> narnoldm at umich.edu> wrote:
>> Hi Matt
>> 1) I'm not sure I follow how to call this. If I insert the
>> VecSetOperation call I'm not exactly sure what the VecView_Plex is or where
>> it is defined?
> Shoot, this cannot be done in Fortran. I will rewrite this step to get it
> working for you. It should have been done anyway. I cannot do it
> today since I have to grade finals, but I should have it this week.
>   Thanks,
>      Matt
>> 2) Otherwise I've solved this problem with the insight you provided into
>> the local section. Things look good on the ASCII output but if we can
>> resolve 1 then I think the loop is fully closed and I can just worry about
>> the fortran translation.
>> Thanks again for all your help.
>> Sincerely
>> Nicholas
>> On Mon, Dec 26, 2022 at 9:37 AM Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Mon, Dec 26, 2022 at 3:21 AM Nicholas Arnold-Medabalimi <
>>>> Hi Matt
>>>> I was able to get this all squared away. It turns out I was
>>>> initializing the viewer incorrectly—my mistake. However, there is a
>>>> follow-up question. A while back, we discussed distributing a vector field
>>>> from an initial DM to a new distributed DM. The way you said to do this was
>>>>     // Distribute the submesh with overlap of 1
>>>>     DMPlexDistribute(sub_da, overlap, &distributionSF, &sub_da_dist);
>>>>     //Create a vector and section for the distribution
>>>>     VecCreate(PETSC_COMM_WORLD, &state_dist);
>>>>     VecSetDM(state_dist, sub_da_dist);
>>>>     PetscSectionCreate(PETSC_COMM_WORLD, &distSection);
>>>>     DMSetLocalSection(sub_da_dist, distSection);
>>>>     DMPlexDistributeField(sub_da_dist, distributionSF, filteredSection,
>>>> state_filtered, distSection, state_dist);
>>>>   I've forgone Fortran to debug this all in C and then integrate the
>>>> function calls into the Fortran code.
>>>> There are two questions here.
>>>> 1) How do I associate a vector associated with a DM using VecSetDM to
>>>> output properly as a VTK? When I call VecView at present, if I call VecView
>>>> on state_dist, it will not output anything.
>>> This is a problem. The different pieces of interface were added at
>>> different times. We should really move that manipulation of the function
>>> table into VecSetDM(). Here is the code:
>>> https://gitlab.com/petsc/petsc/-/blob/main/src/dm/impls/plex/plexcreate.c#L4135
>>> You can make the overload call yourself for now, until we decide on the
>>> best fix.
>>>> 2) The visualization is nice, but when I look at the Vec of the
>>>> distributed field using stdout, something isn't distributing correctly, as
>>>> the vector still has some uninitialized values. This is apparent if I
>>>> output the original vector and the distributed vector. Examining the inside
>>>> of DMPlexDistributeField I suspect I'm making a mistake with the sections
>>>> I'm passing. filtered section in this case is the global section but if I
>>>> try the local section I get an error so I'm not sure.
>>> These should definitely be local sections. Global sections are always
>>> built after the fact, and building the global section needs the SF that
>>> indicates what points are shared, not the distribution SF that moves
>>> points. I need to go back and put in checks that all the arguments are the
>>> right type. Thanks for bringing that up. Lets track down the error for
>>> local sections.
>>>   Matt
>>>> *Original Vector(state_filtered)*
>>>> Vec Object: Vec_0x84000004_1 2 MPI processes
>>>>   type: mpi
>>>> Process [0]
>>>> 101325.
>>>> 300.
>>>> 101326.
>>>> 301.
>>>> 101341.
>>>> 316.
>>>> Process [1]
>>>> 101325.
>>>> 300.
>>>> 101326.
>>>> 301.
>>>> 101345.
>>>> 320.
>>>> 101497.
>>>> 472.
>>>> 101516.
>>>> 491.
>>>> *Re-Distributed Vector (state_dist) *
>>>> Vec Object: 2 MPI processes
>>>>   type: mpi
>>>> Process [0]
>>>> 101325.
>>>> 300.
>>>> 101326.
>>>> 301.
>>>> 101341.
>>>> 316.
>>>> 7.90505e-323
>>>> 1.97626e-323
>>>> 4.30765e-312
>>>> 6.91179e-310
>>>> Process [1]
>>>> 101497.
>>>> 472.
>>>> 101516.
>>>> 491.
>>>> 1.99665e-314
>>>> 8.14714e-321
>>>> Any insight on distributing this field and correcting the error would
>>>> be appreciated.
>>>> Sincerely and Happy Holiday
>>>> Nicholas
>>>> On Fri, Dec 23, 2022 at 10:57 AM Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Thu, Dec 22, 2022 at 12:41 AM Nicholas Arnold-Medabalimi <
>>>>>> Hi Petsc Users
>>>>>> I've been having trouble consistently getting a vector generated from
>>>>>> a DM to output to VTK correctly. I've used ex1.c (which works properly)to
>>>>>> try and figure it out, but I'm still having some issues. I must be missing
>>>>>> something small that isn't correctly associating the section with the DM.
>>>>>>     DMPlexGetChart(dm, &p0, &p1);
>>>>>>     PetscSection section_full;
>>>>>>     PetscSectionCreate(PETSC_COMM_WORLD, &section_full);
>>>>>>     PetscSectionSetNumFields(section_full, 1);
>>>>>>     PetscSectionSetChart(section_full, p0, p1);
>>>>>>     PetscSectionSetFieldName(section_full, 0, "state");
>>>>>>     for (int i = c0; i < c1; i++)
>>>>>>         PetscSectionSetDof(section_full, i, 1);
>>>>>>         PetscSectionSetFieldDof(section_full, i, 0, 1);
>>>>>>     PetscSectionSetUp(section_full);
>>>>>>     DMSetNumFields(dm, 1);
>>>>>>     DMSetLocalSection(dm, section_full);
>>>>>>     DMCreateGlobalVector(dm, &state_full);
>>>>>>     int o0, o1;
>>>>>>     VecGetOwnershipRange(state_full, &o0, &o1);
>>>>>>     PetscScalar *state_full_array;
>>>>>>     VecGetArray(state_full, &state_full_array);
>>>>>>     for (int i = 0; i < (c1 - c0); i++)
>>>>>>         int offset;
>>>>>>         PetscSectionGetOffset(section_full, i, &offset);
>>>>>>         state_full_array[offset] = 101325 + i;
>>>>>>     VecRestoreArray(state_full, &state_full_array);
>>>>>>     PetscViewerCreate(PETSC_COMM_WORLD, &viewer);
>>>>>>     PetscViewerSetType(viewer, PETSCVIEWERVTK);
>>>>>>     PetscViewerFileSetMode(viewer, FILE_MODE_WRITE);
>>>>>>     PetscViewerFileSetName(viewer, "mesh.vtu");
>>>>>>     VecView(state_full, viewer);
>>>>>> If I run this mesh.vtu isn't generated at all. If I instead do a
>>>>>> DMView passing the DM it will just output the mesh correctly.
>>>>>> Any assistance would be greatly appreciated.
>>>>> DMCreateGlobalVector() dispatches to DMCreateGlobalVector_Plex(),
>>>>> which resets the view method to VecView_Plex(), which should dispatch to
>>>>> VecView_Plex_Local_VTK(). You can verify this in the debugger, or send us
>>>>> code we can run to verify it.
>>>>>   Thanks,
>>>>>     Matt
>>>>>> Sincerely
>>>>>> Nicholas
>>>>>> Ph.D. Candidate
>>>>>> Computational Aeroscience Lab
>>>>>> University of Michigan
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>> Ph.D. Candidate
>>> experiments lead.
>>> -- Norbert Wiener
>> Ph.D. Candidate
> experiments lead.
> -- Norbert Wiener
Ph.D. Candidate
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221226/0d732141/attachment-0001.html>
