[petsc-users] Getting a vector from a DM to output VTK
Matthew Knepley
knepley at gmail.com
Fri Dec 23 09:57:18 CST 2022
On Thu, Dec 22, 2022 at 12:41 AM Nicholas Arnold-Medabalimi <
narnoldm at umich.edu> wrote:
> Hi Petsc Users
> I've been having trouble consistently getting a vector generated from a DM
> to output to VTK correctly. I've used ex1.c (which works properly)to try
> and figure it out, but I'm still having some issues. I must be missing
> something small that isn't correctly associating the section with the DM.
> DMPlexGetChart(dm, &p0, &p1);
> PetscSection section_full;
> PetscSectionCreate(PETSC_COMM_WORLD, §ion_full);
> PetscSectionSetNumFields(section_full, 1);
> PetscSectionSetChart(section_full, p0, p1);
> PetscSectionSetFieldName(section_full, 0, "state");
> for (int i = c0; i < c1; i++)
> PetscSectionSetDof(section_full, i, 1);
> PetscSectionSetFieldDof(section_full, i, 0, 1);
> PetscSectionSetUp(section_full);
> DMSetNumFields(dm, 1);
> DMSetLocalSection(dm, section_full);
> DMCreateGlobalVector(dm, &state_full);
> int o0, o1;
> VecGetOwnershipRange(state_full, &o0, &o1);
> PetscScalar *state_full_array;
> VecGetArray(state_full, &state_full_array);
> for (int i = 0; i < (c1 - c0); i++)
> int offset;
> PetscSectionGetOffset(section_full, i, &offset);
> state_full_array[offset] = 101325 + i;
> VecRestoreArray(state_full, &state_full_array);
> PetscViewerCreate(PETSC_COMM_WORLD, &viewer);
> PetscViewerSetType(viewer, PETSCVIEWERVTK);
> PetscViewerFileSetMode(viewer, FILE_MODE_WRITE);
> PetscViewerFileSetName(viewer, "mesh.vtu");
> VecView(state_full, viewer);
> If I run this mesh.vtu isn't generated at all. If I instead do a DMView
> passing the DM it will just output the mesh correctly.
> Any assistance would be greatly appreciated.
DMCreateGlobalVector() dispatches to DMCreateGlobalVector_Plex(), which
resets the view method to VecView_Plex(), which should dispatch to
VecView_Plex_Local_VTK(). You can verify this in the debugger, or send us
code we can run to verify it.
Matt
> Sincerely
> Nicholas
> Ph.D. Candidate
> Computational Aeroscience Lab
> University of Michigan
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221223/9571aff3/attachment.html>
