[petsc-users] locate DMSwarm particles with respect to a background DMDA mesh
Matteo Semplice matteo.semplice at uninsubria.it
Thu Dec 22 14:08:27 CST 2022
Il 22/12/22 20:06, Dave May ha scritto:
> On Thu 22. Dec 2022 at 10:27, Matteo Semplice
> <matteo.semplice at uninsubria.it> wrote:
>     Dear Dave and Matt,
>         I am really dealing with two different use cases in a code
>     that will compute a levelset function passing through a large set
>     of points. If I had DMSwarmSetMigrateType() and if it were safe to
>     switch the migration mode back and forth in the same swarm, this
>     would cover all my use cases here. Is it safe to add it back to
>     petsc? Details below if you are curious.
>     1) During preprocessing I am loading a point cloud from disk (in
>     whatever order it comes) and need to send the particles to the
>     right ranks. Since the background DM is a DMDA I can easily figure
>     out the destination rank. This would be covered by your suggestion
>     not to attach the DM, except that later I need to locate these
>     points with respect to the background cells in order to initialize
>     data on the Vecs associated to the DMDA.
>     2) Then I need to implement a semilagrangian time evolution
>     scheme. For this I'd like to send particles around at the "foot of
>     characteristic", collect data there and then send them back to the
>     originating point. The first migration would be based on particle
>     coordinates (DMSwarmMigrate_DMNeighborScatter and the restriction
>     to only neighbouring ranks is perfect), while for the second move
>     it would be easier to just send them back to the originating rank,
>     which I can easily store in an Int field in the swarm. Thus at
>     each timestep I'd need to swap migrate types in this swarm
>     (DMScatter for moving them to the feet and BASIC to send them back).
> When you use BASIC, you would have to explicitly call the point
> location routine from your code as BASIC does not interact with the DM.
> Based on what I see in the code, switching  migrate modes between
> basic and dmneighbourscatter should be safe.
> If you are fine calling the point location from your side then what
> you propose should work.
If I understood the code correctly, BASIC will just migrate particles
sending them to what is stored in DMSwarmField_rank, right? That'd be
easy since I can create a SWARM with all the data I need and an extra
int field (say "original_rank") and copy those values into
DMSwarmField_rank before calling migrate for the "going back" step.
After this backward migration I do not need to locate particles again
(e.g. I do not need DMSwarmSortGetAccess after the BASIC migration, but
only after the DMNeighborScatter one).
Thus having back DMSwarmSetMigrateType() should be enough for me.
Thanks
     Matteo
> Cheers
> Dave
>     Thanks
>         Matteo
>     Il 22/12/22 18:40, Dave May ha scritto:
>>     Hey Matt,
>>     On Thu 22. Dec 2022 at 05:02, Matthew Knepley <knepley at gmail.com>
>>     wrote:
>>         On Thu, Dec 22, 2022 at 6:28 AM Matteo Semplice
>>             Dear all
>>                 please ignore my previous email and read this one: I
>>             have better localized the problem. Maybe DMSwarmMigrate
>>             is designed to migrate particles only to first
>>             neighbouring ranks?
>>         Yes, I believe that was the design.
>>         Dave, is this correct?
>>     Correct. DMSwarmMigrate_DMNeighborScatter() only scatter points
>>     to the neighbour ranks - where neighbours are defined by the DM
>>     provided to represent the mesh.
>>     DMSwarmMigrate_DMNeighborScatter() Is selected by default if you
>>     attach a DM.
>>     The scatter method should be over ridden with
>>     however it appears this method no longer exists.
>>     If one can determine the exact rank where points should should be
>>     sent and it is not going to be the neighbour rank (given by the
>>     DM), I would suggest not attaching the DM at all.
>>     However if this is not possible and one wanted to scatter to say
>>     the neighbours neighbours, we will have to add a new interface
>>     and refactor things a little bit.
>>     Cheers
>>     Dave
>>           Thanks,
>>             Matt
>>             Il 22/12/22 11:44, Matteo Semplice ha scritto:
>>>             Dear everybody,
>>>                 I have bug a bit into the code and I am able to add
>>>             more information.
>>>             Il 02/12/22 12:48, Matteo Semplice ha scritto:
>>>>             Hi.
>>>>             I am sorry to take this up again, but further tests
>>>>             show that it's not right yet.
>>>>             Il 04/11/22 12:48, Matthew Knepley ha scritto:
>>>>>             On Fri, Nov 4, 2022 at 7:46 AM Matteo Semplice
>>>>>                 On 04/11/2022 02:43, Matthew Knepley wrote:
>>>>>>                 On Thu, Nov 3, 2022 at 8:36 PM Matthew Knepley
>>>>>>                 <knepley at gmail.com> wrote:
>>>>>>                     On Thu, Oct 27, 2022 at 11:57 AM Semplice
>>>>>>                     Matteo <matteo.semplice at uninsubria.it> wrote:
>>>>>>                         Dear Petsc developers,
>>>>>>                         I am trying to use a DMSwarm to locate a
>>>>>>                         cloud of points with respect to a
>>>>>>                         background mesh. In the real application
>>>>>>                         the points will be loaded from disk, but
>>>>>>                         I have created a small demo in which
>>>>>>                           * each processor creates Npart
>>>>>>                             particles, all within the domain
>>>>>>                             covered by the mesh, but not all in
>>>>>>                             the local portion of the mesh
>>>>>>                           * migrate the particles
>>>>>>                         After migration most particles are not
>>>>>>                         any more in the DMSwarm (how many and
>>>>>>                         which ones seems to depend on the number
>>>>>>                         of cpus, but it never happens that all
>>>>>>                         particle survive the migration process).
>>>>>>                     Thanks for sending this. I found the problem.
>>>>>>                     Someone has some overly fancy code inside
>>>>>>                     DMDA to figure out the local bounding box
>>>>>>                     from the coordinates.
>>>>>>                     It is broken for DM_BOUNDARY_GHOSTED, but we
>>>>>>                     never tested with this. I will fix it.
>>>>>>                 Okay, I think this fix is correct
>>>>>>                 https://gitlab.com/petsc/petsc/-/merge_requests/5802
>>>>>>                 <https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgitlab.com%2Fpetsc%2Fpetsc%2F-%2Fmerge_requests%2F5802&data=05%7C01%7Cmatteo.semplice%40uninsubria.it%7C94569ac2a32a4838103608dae44f9c46%7C9252ed8bdffc401c86ca6237da9991fa%7C0%7C0%7C638073327837332509%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=9yKNH0%2FbepSLU2PO5S%2B2GkYSmjjFIDGHpapy%2FUb43D4%3D&reserved=0>
>>>>>>                 I incorporated your test as
>>>>>>                 src/dm/impls/da/tests/ex1.c. Can you take a look
>>>>>>                 and see if this fixes your issue?
>>>>>                 Yes, we have tested 2d and 3d, with various
>>>>>                 combinations of DM_BOUNDARY_* along different
>>>>>                 directions and it works like a charm.
>>>>>                 On a side note, neither DMSwarmViewXDMF nor
>>>>>                 DMSwarmMigrate seem to be implemented for 1d: I get
>>>>>                 [0]PETSC ERROR: No support for this operation for
>>>>>                 this object type[0]PETSC ERROR: Support not
>>>>>                 provided for 1D
>>>>>                 However, currently I have no need for this feature.
>>>>>                 Finally, if the test is meant to stay in the
>>>>>                 source, you may remove the call to
>>>>>                 DMSwarmRegisterPetscDatatypeField as in the
>>>>>                 attached patch.
>>>>>                 Thanks a lot!!
>>>>>             Thanks! Glad it works.
>>>>>                Matt
>>>>             There are still problems when not using 1,2 or 4 cpus.
>>>>             Any other number of cpus that I've tested does not work
>>>>             corectly.
>>>             I have now modified
>>>             private_DMDALocatePointsIS_2D_Regular to print out some
>>>             debugging information. I see that this is called twice
>>>             during migration, once before and once after
>>>             DMSwarmMigrate_DMNeighborScatter. If I understand
>>>             correctly, the second call to
>>>             private_DMDALocatePointsIS_2D_Regular should be able to
>>>             locate all particles owned by the rank but it fails for
>>>             some of them because they have been sent to the wrong
>>>             rank (despite being well away from process boundaries).
>>>             For example, running the example
>>>             src/dm/impls/da/tests/ex1.c with Nx=21 (20x20 Q1
>>>             elements on [-1,1]X[-1,1]) with 3 processors,
>>>             - the particles (-0.191,-0.462) and (0.191,-0.462) are
>>>             sent cpu2 instead of cpu0
>>>             - those at (-0.287,-0.693)and (0.287,-0.693) are sent to
>>>             cpu1 instead of cpu0
>>>             - those at (0.191,0.462) and (-0.191,0.462) are sent to
>>>             cpu0 instead of cpu2
>>>             (This is 2d and thus not affected by the 3d issue
>>>             mentioned yesterday on petsc-dev. Tests were made based
>>>             on the release branch pulled out this morning, i.e. on
>>>             commit bebdc8d016f).
>>             I see: particles are sent "all around" and not only to
>>             Still however, running the example
>>             src/dm/impls/da/tests/ex1.c with Nx=21 (20x20 Q1 elements
>>             on [-1,1]X[-1,1]) with 3 processors, there are 2
>>             particles initially owned by rank2 (at y=-0.6929 and
>>             x=+/-0.2870) that are sent only to rank1 and never make
>>             it to rank0 and are thus lost in the end since rank1,
>>             correctly, discards them.
>>             Thanks
>>                 Matteo
>>         What most experimenters take for granted before they begin
>>         their experiments is infinitely more interesting than any
>>         results to which their experiments lead.
>>         -- Norbert Wiener
>>         https://www.cse.buffalo.edu/~knepley/
>>         <https://eur01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.cse.buffalo.edu%2F~knepley%2F&data=05%7C01%7Cmatteo.semplice%40uninsubria.it%7C94569ac2a32a4838103608dae44f9c46%7C9252ed8bdffc401c86ca6237da9991fa%7C0%7C0%7C638073327837332509%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=LEmGbachok2Z3m9SyCASEcTWytkpxw%2FnHCIXjYXPTa8%3D&reserved=0>
>     Professore Associato in Analisi Numerica
>     Dipartimento di Scienza e Alta Tecnologia
>     Università degli Studi dell'Insubria
>     Via Valleggio, 11 - Como  <https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.google.com%2Fmaps%2Fsearch%2FVia%2BValleggio%2C%2B11%2B-%2BComo%3Fentry%3Dgmail%26source%3Dg&data=05%7C01%7Cmatteo.semplice%40uninsubria.it%7C94569ac2a32a4838103608dae44f9c46%7C9252ed8bdffc401c86ca6237da9991fa%7C0%7C0%7C638073327837332509%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=0MwkPJb5hslcrFhqrLCaN4OKs%2FoylMR3dOib2MYsNOY%3D&reserved=0>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221222/57aa4954/attachment-0001.html>
