[petsc-users] Error while running an example
Satish Balay
balay at mcs.anl.gov
Wed Dec 21 11:19:57 CST 2022
Likely mis-configured network.
What do you get for:
host `hostname`
Some additional info:
https://petsc.org/release/faq/#what-does-it-mean-when-make-check-errors-on-petscoptionsinsertfile
For mis-configured network - the following fix might work:
echo 127.0.0.1 `hostname` | sudo tee -a /etc/hosts
Satish
On Wed, 21 Dec 2022, Guilherme Lima wrote:
> Hello
> So, this error occurred while running example 50 on
> petsc/src/ksp/ksp/tutorials
> The machine also have a MPI installed, so in order to run the ex50 I did:
> /home/slave12/projects/petsc/arch-linux-c-debug/bin/mpiexec -n 4 ./ex50
> -da_grid_x 120 -da_grid_y 120 -pc_type lu -pc_factor_mat_solver_type
> superlu_dist -ksp_monitor -ksp_view
> Expecting that the problem was solved, but instead it showed an Error
> message
> Configure.log, make.log and error attached.
