[petsc-users] Matrix version of VecScatterCreateToAll
    Matthew Knepley
    knepley at gmail.com
    Sun Dec 18 12:22:37 CST 2022
On Sun, Dec 18, 2022 at 9:44 AM 김성익 <ksi2443 at gmail.com> wrote:
> For example, before using preallocaotor, I made A matrix. (A matrix has
> information about indices of global matrix)
> And the code structures are as below.
> for (int i=0; i<num; i++){
>    MatGetRow(A,~~) // for getting indices info of global matrix.
>    MatSetvalues(preallocator, value_from_A);
> Current state, I got an error at 'MatGetRow' when I run this code in
> parallel.
> That's why I want "all mpi ranks has information of A matrix".
Just from your explanation, this does not sound like a scalable algorithm
for this, and FEM should be scalable.
I would take a look at some parallel FEM codes before settling on this
structure.
However, if you really wish to do this, you can create the original matrix
and then call
  https://petsc.org/main/docs/manualpages/Mat/MatCreateSubMatrices/
with every process giving all indices as the argument.
    Matt
> Thanks,
> Hyung Kim
> 2022년 12월 18일 (일) 오후 11:36, Junchao Zhang <junchao.zhang at gmail.com>님이 작성:
>> I am not clear on what you said "this information must be viewed in all
>> mpi ranks."  Even with preallocator, each rank only needs to insert entries
>> it knows (i.e., don't need to get all entries)
>> Maybe you could provide an example code for us to better understand what
>> you mean?
>> --Junchao Zhang
>> On Sun, Dec 18, 2022 at 8:25 AM 김성익 <ksi2443 at gmail.com> wrote:
>>> Hello,
>>> Is there a matrix version function of VecScatterCreateToAll?
>>> I'm using preallocator for preallocation of global matrix.
>>> Prior to using the preallocator, information related to allocation is
>>> stored in the specific matrix, and this information must be viewed in all
>>> mpi ranks.
>>> For using preallocator, I need scattering the specific matrix info to
>>> all mpi ranks.
>>> Thanks,
>>> Hyung Kim
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221218/b07db5f9/attachment.html>
