[petsc-users] dmplex normal vector incorrect for periodic gmsh grids
Sun Dec 18 12:11:08 CST 2022
On Sun, Dec 18, 2022 at 9:21 AM Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> > On Fri, Dec 16, 2022 at 12:22 AM Praveen C <praveen at gmx.net> wrote:
> >> Thank you very much. I do see correct normals now.
> >> Is there a way to set the option
> >> -dm_localize_height 1
> >> within the code ?
> > The problem is that the localization happens within the Gmsh
> construction,
> > so it is difficult to insert an API.
> > We could use a callback, but that rapidly becomes unwieldy. If you want
> to
> > do it programmatically, I would use
> > PetscOptionsSetValue().
> Can it not be created explicitly later?
> This kind of thing isn't really a run-time choice, but rather a statement
> about the way the calling code has been written.
You could tear down the localization, then set the height, and recreate the
localization.
     Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221218/3e3f6cc9/attachment.html>
