[petsc-users] Help with input construction hang on 2-GPU CG Solve
Rohan Yadav rohany at alumni.cmu.edu
Sat Dec 17 23:10:04 CST 2022
Thanks Jed. I had tried just over-preallocating the matrix (using 10 nnz
per row) and that solved the problem. I'm not sure what was wrong with my
initial preallocation, but it's probably likely that things weren't hanging
but just moving very slowly.
Rohan
On Sat, Dec 17, 2022 at 9:57 PM Jed Brown <jed at jedbrown.org> wrote:
> I ran your code successfully with and without GPU-aware MPI. I see a bit
> of time in MatSetValue -- you can make it a bit faster using one
> MatSetValues call per row, but it's typical that assembling a matrix like
> this (sequentially on the host) will be more expensive than some
> unpreconditioned CG iterations (that don't come close to solving the
> problem -- use multigrid if you want to actually solve this problem).
> Rohan Yadav <rohany at alumni.cmu.edu> writes:
> > Hi,
> > I'm developing a microbenchmark that runs a CG solve using PETSc on a
> mesh
> > using a 5-point stencil matrix. My code (linked here:
> > https://github.com/rohany/petsc-pde-benchmark/blob/main/main.cpp, only
> 120
> > lines) works on 1 GPU and has great performance. When I move to 2 GPUs,
> the
> > program appears to get stuck in the input generation. I've literred the
> > code with print statements and have found out the following clues:
> > * The first rank progresses through this loop:
> > https://github.com/rohany/petsc-pde-benchmark/blob/main/main.cpp#L44,
> but
> > then does not exit (it seems to get stuck right before rowStart ==
> rowEnd)
> > * The second rank makes very few iterations through the loop for its
> > allotted rows.
> > Therefore, neither rank makes it to the call to MatAssemblyBegin.
> > I'm running the code using the following command line on the Summit
> > supercomputer:
> > jsrun -n 2 -g 1 -c 1 -b rs -r 2
> > /gpfs/alpine/scratch/rohany/csc335/petsc-pde-benchmark/main -ksp_max_it
> 200
> > -ksp_type cg -pc_type none -ksp_atol 1e-10 -ksp_rtol 1e-10 -vec_type cuda
> > -mat_type aijcusparse -use_gpu_aware_mpi 0 -nx 8485 -ny 8485
> > Any suggestions will be appreciated! I feel that I have applied many of
> the
> > common petsc optimizations of preallocating my matrix row counts, so I'm
> > not sure what's going on with this input generation.
> > Thanks,
> > Rohan Yadav
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221217/9442c805/attachment.html>
