[petsc-users] dmplex normal vector incorrect for periodic gmsh grids
Matthew Knepley
knepley at gmail.com
Fri Dec 16 10:02:10 CST 2022
On Fri, Dec 16, 2022 at 12:22 AM Praveen C <praveen at gmx.net> wrote:
> Thank you very much. I do see correct normals now.
> Is there a way to set the option
> -dm_localize_height 1
> within the code ?
The problem is that the localization happens within the Gmsh construction,
so it is difficult to insert an API.
We could use a callback, but that rapidly becomes unwieldy. If you want to
do it programmatically, I would use
PetscOptionsSetValue().
Matt
> best
> praveen
> On 15-Dec-2022, at 9:53 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Dec 14, 2022 at 9:20 AM Praveen C <praveen at gmx.net> wrote:
>> Hello
>> I tried this with the attached code but I still get wrong normals.
>> ./dmplex -dm_plex_filename ug_periodic.msh -dm_localize_height 1
>> Code and grid file are attached
> I have fixed the code. The above options should now work for you.
> Thanks,
> Matt
>> Thank you
>> praveen
>> On 14-Dec-2022, at 6:40 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Wed, Dec 14, 2022 at 2:38 AM Praveen C <praveen at gmx.net> wrote:
>>> Thank you, this MR works if I generate the mesh within the code.
>>> But using a mesh made in gmsh, I see the same issue.
>> Because the operations happen in a different order. If you read in your
>> mesh with
>> -dm_plex_filename mymesh.gmsh -dm_localize_height 1
>> then it should work.
>> Thanks,
>> Matt
>>> Thanks
>>> praveen
>>> On 14-Dec-2022, at 12:51 AM, Matthew Knepley <knepley at gmail.com> wrote:
>>> On Tue, Dec 13, 2022 at 10:57 AM Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Tue, Dec 13, 2022 at 6:11 AM Praveen C <praveen at gmx.net> wrote:
>>>>> Hello
>>>>> In the attached test, I read a small grid made in gmsh with periodic
>>>>> bc.
>>>>> This is a 2d mesh.
>>>>> The cell numbers are shown in the figure.
>>>>> All faces have length = 2.5
>>>>> But using PetscFVFaceGeom I am getting length of 7.5 for some faces.
>>>>> E.g.,
>>>>> face: 59, centroid = 3.750000, 2.500000, normal = 0.000000, -7.500000
>>>>> ===> Face length incorrect = 7.500000, should be 2.5
>>>>> support[0] = 11, cent = 8.750000, 3.750000, area = 6.250000
>>>>> support[1] = 15, cent = 8.750000, 1.250000, area = 6.250000
>>>>> There are also errors in the orientation of normal.
>>>>> If we disable periodicity in geo file, this error goes away.
>>>> Yes, by default we only localize coordinates for cells. I can put in
>>>> code to localize faces.
>>> Okay, I now have a MR for this:
>>> https://gitlab.com/petsc/petsc/-/merge_requests/5917
>>> I am attaching your code, slightly modified. You can run
>>> ./dmplex -malloc_debug 0 -dm_plex_box_upper 10,10 -dm_plex_box_faces
>>> 4,4 -dm_plex_simplex 0 -dm_view ::ascii_info_detail -draw_pause 3
>>> -dm_plex_box_bd periodic,periodic -dm_localize_height 0
>>> which shows incorrect edges and
>>> ./dmplex -malloc_debug 0 -dm_plex_box_upper 10,10 -dm_plex_box_faces 4,4
>>> -dm_plex_box_bd periodic,periodic -dm_localize_height 1
>>> which is correct. If you want to control things yourself, instead of
>>> using the option you can call DMPlexSetMaxProjectionHeight() on the
>>> coordinate DM yourself.
>>> Thanks,
>>> Matt
>>>> Thanks,
>>>> Matt
>>>>> Thanks
>>>>> praveen
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221216/1bc64f49/attachment.html>
