[petsc-users] dmplex normal vector incorrect for periodic gmsh grids
Matthew Knepley
knepley at gmail.com
Thu Dec 15 10:23:04 CST 2022
On Wed, Dec 14, 2022 at 9:20 AM Praveen C <praveen at gmx.net> wrote:
> Hello
> I tried this with the attached code but I still get wrong normals.
> ./dmplex -dm_plex_filename ug_periodic.msh -dm_localize_height 1
> Code and grid file are attached
I have fixed the code. The above options should now work for you.
Matt
> Thank you
> praveen
> On 14-Dec-2022, at 6:40 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Dec 14, 2022 at 2:38 AM Praveen C <praveen at gmx.net> wrote:
>> Thank you, this MR works if I generate the mesh within the code.
>> But using a mesh made in gmsh, I see the same issue.
> Because the operations happen in a different order. If you read in your
> mesh with
> -dm_plex_filename mymesh.gmsh -dm_localize_height 1
> then it should work.
> Thanks,
> Matt
>> Thanks
>> praveen
>> On 14-Dec-2022, at 12:51 AM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Tue, Dec 13, 2022 at 10:57 AM Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Tue, Dec 13, 2022 at 6:11 AM Praveen C <praveen at gmx.net> wrote:
>>>> Hello
>>>> In the attached test, I read a small grid made in gmsh with periodic bc.
>>>> This is a 2d mesh.
>>>> The cell numbers are shown in the figure.
>>>> All faces have length = 2.5
>>>> But using PetscFVFaceGeom I am getting length of 7.5 for some faces.
>>>> E.g.,
>>>> face: 59, centroid = 3.750000, 2.500000, normal = 0.000000, -7.500000
>>>> ===> Face length incorrect = 7.500000, should be 2.5
>>>> support[0] = 11, cent = 8.750000, 3.750000, area = 6.250000
>>>> support[1] = 15, cent = 8.750000, 1.250000, area = 6.250000
>>>> There are also errors in the orientation of normal.
>>>> If we disable periodicity in geo file, this error goes away.
>>> Yes, by default we only localize coordinates for cells. I can put in
>>> code to localize faces.
>> Okay, I now have a MR for this:
>> https://gitlab.com/petsc/petsc/-/merge_requests/5917
>> I am attaching your code, slightly modified. You can run
>> ./dmplex -malloc_debug 0 -dm_plex_box_upper 10,10 -dm_plex_box_faces
>> 4,4 -dm_plex_simplex 0 -dm_view ::ascii_info_detail -draw_pause 3
>> -dm_plex_box_bd periodic,periodic -dm_localize_height 0
>> which shows incorrect edges and
>> ./dmplex -malloc_debug 0 -dm_plex_box_upper 10,10 -dm_plex_box_faces 4,4
>> -dm_plex_box_bd periodic,periodic -dm_localize_height 1
>> which is correct. If you want to control things yourself, instead of
>> using the option you can call DMPlexSetMaxProjectionHeight() on the
>> coordinate DM yourself.
>> Thanks,
>> Matt
>>> Thanks,
>>> Matt
>>>> Thanks
>>>> praveen
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221215/0f596300/attachment-0001.html>
