[petsc-users] Insert one sparse matrix as a block in another
Jed Brown
jed at jedbrown.org
Mon Dec 12 16:23:57 CST 2022
The description matches MATNEST (MATCOMPOSITE is for a sum or product of matrices) or parallel decompositions. Also consider the assembly style of src/snes/tutorials/ex28.c, which can create either a monolithic or block (MATNEST) matrix without extra storage or conversion costs.
Mark Adams <mfadams at lbl.gov> writes:
> Do you know what kind of solver works well for this problem?
> You probably want to figure that out first and not worry about efficiency.
> MATCOMPOSITE does what you want but not all solvers will work with it.
> Where does this problem come from? We have a lot of experience and might
> know something.
> Mark
> On Mon, Dec 12, 2022 at 1:33 PM Peder Jørgensgaard Olesen via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
>> Hello
>> I have a set of sparse matrices (A1, A2, ...) , and need to generate a
>> larger matrix B with these as submatrices. I do not know the precise sparse
>> layouts of the A's (only that each row has one or two non-zero values),
>> and extracting *all* values to copy into B seems incredibly wasteful. How
>> can I make use of the sparsity to solve this efficiently?
>> Thanks,
>> Peder
>> PhD student
>> Department of Civil and Mechanical Engineering
>> pjool at mek.dtu.dk
>> Koppels Allé
>> Building 403, room 105
>> 2800 Kgs. Lyngby
>> www.dtu.dk/english
