[petsc-users] Union of sequential vecs
Fri Dec 9 20:20:00 CST 2022
On Fri, Dec 9, 2022 at 6:50 PM Karthikeyan Chockalingam - STFC UKRI via
petsc-users <petsc-users at mcs.anl.gov> wrote:
> Thank you Mark and Barry.
> @Mark Adams <mfadams at lbl.gov> I follow you for the most part. Shouldn’t R
> be an MPI Vector?
> Here it goes:
> Q[Vec[i]] for all "i" in my local (sequential) "Vec".
> Compute number of local nonzeros in Q, call it n.
> //Create a MPI Vector R, with local size n
> VecCreate(PETSC_COMM_WORLD, &R);
> VecSetType(R, VECMPI);
> VecSetSizes(R, *n*, PETSC_DECIDE);
> //Populate MPI Vector R with local (sequential) "Vec".
> VecGetOwnershipRange(R, &istart, &iend);
> local_size = iend - istart; //The local_size should be ‘*n*’ right?
> VecGetArray(R, &values);
>   *for* (i = 0; i < local_size; i++) {
>     values[i] = Vec[i];
> VecRestoreArray(R, &values);
> //Scatter R to all processors
> Vec            V_SEQ;
> VecScatter     ctx;
> VecScatterCreateToAll(R,&ctx,&V_SEQ);
> //Remove duplicates in V_SEQ
> How can I use PetscSortRemoveDupsInt to remove duplicates in V_SEQ?
> Physics behind:
> I am reading a parallel mesh, and want to mark all the boundary nodes. I
> use a local (sequential) Vec to store the boundary nodes for each parallel
> partition. Hence, local Vecs can end up with duplicate node index among
> them, which I would like to get rid of when I combine all of them together.
1) Blaise is right you should use an IS, not a Vec, to hold node indices.
His solution is only a few lines, so I would use it.
2) I would not recommend doing things this way in the first place. PETSc
can manage parallel meshes scalably, marking boundaries using DMLabel
objects.
     Matt
> Best,
> Karthik.
> *From: *Mark Adams <mfadams at lbl.gov>
> *Date: *Friday, 9 December 2022 at 21:08
> *To: *Chockalingam, Karthikeyan (STFC,DL,HC) <
> karthikeyan.chockalingam at stfc.ac.uk>
> *Cc: *Barry Smith <bsmith at petsc.dev>, petsc-users at mcs.anl.gov <
> *Subject: *Re: [petsc-users] Union of sequential vecs
> If your space is pretty compact, eg, (0,12), you could create an MPI
> vector Q of size 13, say, and each processor can add 1.0 to Q[Vec[i]], for
> all "i" in my local "Vec".
> Then each processor can count the number of local nonzeros in Q, call it
> n, create a new vector, R, with local size n, then set R[i] = global index
> of the nonzero for each nonzero in Q, i=0:n.
> Do some sort of vec-scatter-to-all with R to get what you want.
> Does that work?
> Mark
> On Fri, Dec 9, 2022 at 3:25 PM Karthikeyan Chockalingam - STFC UKRI via
> That is where I am stuck, *I don’t know* who to combine them to get Vec =
> {2,5,7,8,10,11,12}.
> I just want them in an MPI vector.
> I finally plan to call VecScatterCreateToAll so that all processor gets a
> copy.
> Thank you.
> Kind regards,
> Karthik.
> *From: *Barry Smith <bsmith at petsc.dev>
> *Date: *Friday, 9 December 2022 at 20:04
> *Cc: *petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
>   How are you combining them to get Vec = {2,5,7,8,10,11,12}?
>   Do you want the values to remain on the same MPI rank as before, just in
> an MPI vector?
> On Dec 9, 2022, at 2:28 PM, Karthikeyan Chockalingam - STFC UKRI via
> Hi,
> I want to take the union of a set of sequential vectors, each living in a
> different processor.
> Say,
> Vec_Seq1 = {2,5,7}
> Vec_Seq2 = {5,8,10,11}
> Vec_Seq3 = {5,2,12}.
> Finally, get the union of all them Vec = {2,5,7,8,10,11,12}.
> I initially wanted to create a parallel vector and insert the (sequential
> vector) values but I do not know, to which index to insert the values to.
> But I do know the total size of Vec (which in this case is 7).
> Any help is much appreciated.
> Kind regards,
> Karthik.
> This email and any attachments are intended solely for the use of the
> named recipients. If you are not the intended recipient you must not use,
> disclose, copy or distribute this email or any of its attachments and
> should notify the sender immediately and delete this email from your
> system. UK Research and Innovation (UKRI) has taken every reasonable
> precaution to minimise risk of this email or any attachments containing
> viruses or malware but the recipient should carry out its own virus and
> malware checks before opening the attachments. UKRI does not accept any
> liability for any losses or damages which the recipient may sustain due to
> presence of any viruses.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221209/d01c9b3a/attachment-0001.html>
