[petsc-users] Petsc Section in DMPlex
Nicholas Arnold-Medabalimi narnoldm at umich.edu
Wed Dec 7 20:21:32 CST 2022
Thank you for the help.
I think the last piece of the puzzle is how do I create the "expanded IS"
from the subpoint IS using the section?
Sincerely
Nicholas
On Wed, Dec 7, 2022 at 7:06 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Dec 7, 2022 at 6:51 AM Nicholas Arnold-Medabalimi <
> narnoldm at umich.edu> wrote:
>> Hi
>> Thank you so much for your patience. One thing to note: I don't have any
>> need to go back from the filtered distributed mapping back to the full but
>> it is good to know.
>> One aside question.
>> 1) Is natural and global ordering the same in this context?
> No.
>> As far as implementing what you have described.
>> When I call ISView on the generated SubpointIS, I get an unusual error
>> which I'm not sure how to interpret. (this case is running on 2 ranks and
>> the filter label has points located on both ranks of the original DM.
>> However, if I manually get the indices (the commented lines), it seems to
>> not have any issues.
>> call DMPlexFilter(dmplex_full, iBlankLabel, 1, dmplex_filtered,ierr)
>> call DMPlexGetSubpointIS(dmplex_filtered, subpointsIS,ierr)
>> !call ISGetIndicesF90(subpointsIS, subPointKey,ierr)
>> !write(*,*) subPointKey
>> !call ISRestoreIndicesF90(subpointsIS, subPointKey,ierr)
>> call ISView(subpointsIS,PETSC_VIEWER_STDOUT_WORLD,ierr)
>> [1]PETSC ERROR: --------------------- Error Message
>> [1]PETSC ERROR: Arguments must have same communicators
>> [1]PETSC ERROR: Different communicators in the two objects: Argument # 1
>> and 2 flag 3
>> [1]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
>> [1]PETSC ERROR: Petsc Development GIT revision: v3.18.1-320-g7810d690132
>>  GIT Date: 2022-11-20 20:25:41 -0600
>> [1]PETSC ERROR: Configure options with-fc=mpiifort with-mpi-f90=mpiifort
>> --download-triangle --download-parmetis --download-metis --with-debugging=1
>> --download-hdf5 --prefix=/home/narnoldm/packages/petsc_install
>> [1]PETSC ERROR: #1 ISView() at
>> /home/narnoldm/packages/petsc/src/vec/is/is/interface/index.c:1629
> The problem here is the subpointsIS is a _serial_ object, and you are
> using a parallel viewer. You can use PETSC_VIEWER_STDOUT_SELF,
> or you can pull out the singleton viewer from STDOUT_WORLD if you want
> them all to print in order.
>> As far as the overall process you have described my question on first
>> glance is do I have to allocate/create the vector that is output by
>> VecISCopy before calling it, or does it create the vector automatically?
> You create both vectors. I would do it using DMCreateGlobalVector() from
> both DMs.
>> I think I would need to create it first using a section and Setting the
>> Vec in the filtered DM?
> Setting the Section in the filtered DM.
>> And I presume in this case I would be using the scatter reverse option to
>> go from the full set to the reduced set?
> Yes
>   Thanks
>      Matt
>> Sincerely
>> Nicholas
>> Sincerely
>> Nick
>> On Wed, Dec 7, 2022 at 6:00 AM Matthew Knepley <knepley at gmail.com> wrote:
>>> On Wed, Dec 7, 2022 at 3:35 AM Nicholas Arnold-Medabalimi <
>>>> Hi Matthew
>>>> Thank you for the help. This clarified a great deal.
>>>> I have a follow-up question related to DMPlexFilter. It may be better
>>>> to describe what I'm trying to achieve.
>>>> I have a general mesh I am solving which has a section with cell center
>>>> finite volume states, as described in my initial email. After calculating
>>>> some metrics, I tag a bunch of cells with an identifying Label and use
>>>> DMFilter to generate a new DM which is only that subset of cells.
>>>> Generally, this leads to a pretty unbalanced DM so I then plan to use
>>>> DMPlexDIstribute to balance that DM across the processors. The coordinates
>>>> pass along fine, but the state(or I should say Section) does not at least
>>>> as far as I can tell.
>>>> Assuming I can get a filtered DM I then distribute the DM and state
>>>> using the method you described above and it seems to be working ok.
>>>> The last connection I have to make is the transfer of information from
>>>> the full mesh to the "sampled" filtered mesh. From what I can gather I
>>>> would need to get the mapping of points using DMPlexGetSubpointIS and then
>>>> manually copy the values from the full DM section to the filtered DM? I
>>>> have the process from full->filtered->distributed all working for the
>>>> coordinates so its just a matter of transferring the section correctly.
>>>> I appreciate all the help you have provided.
>>> Let's do this in two steps, which makes it easier to debug. First, do
>>> not redistribute the submesh. Just use DMPlexGetSubpointIS()
>>> to get the mapping of filtered points to points in the original mesh.
>>> Then create an expanded IS using the Section which makes
>>> dofs in the filtered mesh to dofs in the original mesh. From this use
>>>   https://petsc.org/main/docs/manualpages/Vec/VecISCopy/
>>> to move values between the original vector and the filtered vector.
>>> Once that works, you can try redistributing the filtered mesh. Before
>>> calling DMPlexDistribute() on the filtered mesh, you need to call
>>>   https://petsc.org/main/docs/manualpages/DM/DMSetUseNatural/
>>> When you redistribute, it will compute a mapping back to the original
>>> layout. Now when you want to transfer values, you
>>>   1) Create a natural vector with DMCreateNaturalVec()
>>>   2) Use DMGlobalToNaturalBegin/End() to move values from the filtered
>>> vector to the natural vector
>>>   3) Use VecISCopy() to move values from the natural vector to the
>>> original vector
>>> Let me know if you have any problems.
>>>   Thanks,
>>>      Matt
>>>> Sincerely
>>>> Nicholas
>>>> On Mon, Nov 28, 2022 at 6:19 AM Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Sun, Nov 27, 2022 at 10:22 PM Nicholas Arnold-Medabalimi <
>>>>>> Hi Petsc Users
>>>>>> I have a question about properly using PetscSection to assign state
>>>>>> variables to a DM. I have an existing DMPlex mesh distributed on 2
>>>>>> processors. My goal is to have state variables set to the cell centers. I
>>>>>> then want to call DMPlexDistribute, which I hope will balance the mesh
>>>>>> elements and hopefully transport the state variables to the hosting
>>>>>> processors as the cells are distributed to a different processor count or
>>>>>> simply just redistributing after doing mesh adaption.
>>>>>> Looking at the DMPlex User guide, I should be able to achieve this
>>>>>> with a single field section using SetDof and assigning the DOF to the
>>>>>> points corresponding to cells.
>>>>> Note that if you want several different fields, you can clone the DM
>>>>> first for this field
>>>>>   call DMClone(dm,dmState,ierr)
>>>>> and use dmState in your calls below.
>>>>>> call DMPlexGetHeightStratum(dm,0,c0,c1,ierr)
>>>>>> call DMPlexGetChart(dm,p0,p1,ierr)
>>>>>> call PetscSectionCreate(PETSC_COMM_WORLD,section,ierr)
>>>>>> call PetscSectionSetNumFields(section,1,ierr) call
>>>>>> PetscSectionSetChart(section,p0,p1,ierr)
>>>>>> do i = c0, (c1-1)
>>>>>>     call PetscSectionSetDof(section,i,nvar,ierr)
>>>>>> end do
>>>>>> call PetscSectionSetup(section,ierr)
>>>>>> call DMSetLocalSection(dm,section,ierr)
>>>>> In the loop, I would add a call to
>>>>>   call PetscSectionSetFieldDof(section,i,0,nvar,ierr)
>>>>> This also puts in the field breakdown. It is not essential, but nicer.
>>>>>> From here, it looks like I can access and set the state vars using
>>>>>> call DMGetGlobalVector(dmplex,state,ierr)
>>>>>> call DMGetGlobalSection(dmplex,section,ierr)
>>>>>> call VecGetArrayF90(state,stateVec,ierr)
>>>>>> do i = c0, (c1-1)
>>>>>> call PetscSectionGetOffset(section,i,offset,ierr)
>>>>>> stateVec(offset:(offset+nvar))=state_i(:) !simplified assignment
>>>>>> end do
>>>>>> call VecRestoreArrayF90(state,stateVec,ierr)
>>>>>> call DMRestoreGlobalVector(dmplex,state,ierr)
>>>>>> To my understanding, I should be using Global vector since this is a
>>>>>> pure assignment operation and I don't need the ghost cells.
>>>>> Yes.
>>>>> But the behavior I am seeing isn't exactly what I'd expect.
>>>>>> To be honest, I'm somewhat unclear on a few things
>>>>>> 1) Should be using nvar fields with 1 DOF each or 1 field with nvar
>>>>>> DOFs or what the distinction between the two methods are?
>>>>> We have two divisions in a Section. A field can have a number of
>>>>> components. This is intended to model a vector or tensor field.
>>>>> Then a Section can have a number of fields, such as velocity and
>>>>> pressure for a Stokes problem. The division is mainly to help the
>>>>> user, so I would use the most natural one.
>>>>>> 2) Adding a print statement after the offset assignment I get (on
>>>>>> rank 0 of 2)
>>>>>> cell           1 offset           0
>>>>>>  cell           2 offset          18
>>>>>>  cell           3 offset          36
>>>>>> which is expected and works but on rank 1 I get
>>>>>>  cell           1 offset        9000
>>>>>>  cell           2 offset        9018
>>>>>>  cell           3 offset        9036
>>>>>> which isn't exactly what I would expect. Shouldn't the offsets reset
>>>>>> at 0 for the next rank?
>>>>> The local and global sections hold different information. This is the
>>>>> source of the confusion. The local section does describe a local
>>>>> vector, and thus includes overlap or "ghost" dofs. The global section
>>>>> describes a global vector. However, it is intended to deliver
>>>>> global indices, and thus the offsets give back global indices. When
>>>>> you use VecGetArray*() you are getting out the local array, and
>>>>> thus you have to subtract the first index on this process. You can get
>>>>> that from
>>>>>   VecGetOwnershipRange(v, &rstart, &rEnd);
>>>>> This is the same whether you are using DMDA or DMPlex or any other DM.
>>>>>> 3) Does calling DMPlexDistribute also distribute the section data
>>>>>> associated with the DOF, based on the description in DMPlexDistribute it
>>>>>> looks like it should?
>>>>> No. By default, DMPlexDistribute() only distributes coordinate data. I
>>>>> you want to distribute your field, it would look something like this:
>>>>> DMPlexDistribute(dm, 0, &sfDist, &dmDist);
>>>>> VecCreate(comm, &stateDist);
>>>>> VecSetDM(sateDist, dmDist);
>>>>> PetscSectionCreate(comm &sectionDist);
>>>>> DMSetLocalSection(dmDist, sectionDist);
>>>>> DMPlexDistributeField(dmDist, sfDist, section, state, sectionDist,
>>>>> stateDist);
>>>>> We do this in src/dm/impls/plex/tests/ex36.c
>>>>>   THanks,
>>>>>      Matt
>>>>> I'd appreciate any insight into the specifics of this usage. I expect
>>>>>> I have a misconception on the local vs global section. Thank you.
>>>>>> Sincerely
>>>>>> Nicholas
>>>>>> Ph.D. Candidate
>>>>>> Computational Aeroscience Lab
>>>>>> University of Michigan
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>> Ph.D. Candidate
>>> experiments lead.
>>> -- Norbert Wiener
>> Ph.D. Candidate
> experiments lead.
> -- Norbert Wiener
Ph.D. Candidate
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221207/f3d75e0f/attachment-0001.html>
