[petsc-users] prevent linking to multithreaded BLAS?
Mark Lohry
mlohry at gmail.com
Wed Dec 7 15:47:34 CST 2022
Thanks, yes, I figured out the OMP_NUM_THREADS=1 way while triaging it, and
the --download-fblaslapack way occurred to me.
I was hoping for something that "just worked" (refuse to build in this
case) but I don't know if it's programmatically possible for petsc to tell
whether or not it's linking to a threaded BLAS?
On Wed, Dec 7, 2022 at 4:35 PM Satish Balay <balay at mcs.anl.gov> wrote:
> If you don't specify a blas to use - petsc configure will guess and use
> what it can find.
> So only way to force it use a particular blas is to specify one [one way
> is --download-fblaslapack]
> Wrt multi-thread openblas - you can force it run single threaded [by one
> of these 2 env variables]
> # Use single thread openblas
> export OPENBLAS_NUM_THREADS=1
> export OMP_NUM_THREADS=1
> Satish
> On Wed, 7 Dec 2022, Mark Lohry wrote:
> > I ran into an unexpected issue -- on an NP-core machine, each MPI rank of
> > my application was launching NP threads, such that when running with
> > multiple ranks the machine was quickly oversubscribed and performance
> > tanked.
> > The root cause of this was petsc linking against the system-provided
> > library (libopenblas0-pthread in this case) set by the
> update-alternatives
> > in ubuntu. At some point this machine got updated to using the threaded
> > blas implementation instead of serial; not sure how, and I wouldn't have
> > noticed if I weren't running interactively.
> > Is there any mechanism in petsc or its build system to prevent linking
> > against an inappropriate BLAS, or do I need to be diligent about manually
> > setting the BLAS library in the configuration stage?
> > Thanks,
> > Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221207/bb626072/attachment-0001.html>
