[petsc-users] Petsc Section in DMPlex
Nicholas Arnold-Medabalimi
narnoldm at umich.edu
Wed Dec 7 05:51:20 CST 2022
Hi
Thank you so much for your patience. One thing to note: I don't have any
need to go back from the filtered distributed mapping back to the full but
it is good to know.
One aside question.
1) Is natural and global ordering the same in this context?
As far as implementing what you have described.
When I call ISView on the generated SubpointIS, I get an unusual error
which I'm not sure how to interpret. (this case is running on 2 ranks and
the filter label has points located on both ranks of the original DM.
However, if I manually get the indices (the commented lines), it seems to
not have any issues.
call DMPlexFilter(dmplex_full, iBlankLabel, 1, dmplex_filtered,ierr)
call DMPlexGetSubpointIS(dmplex_filtered, subpointsIS,ierr)
!call ISGetIndicesF90(subpointsIS, subPointKey,ierr)
!write(*,*) subPointKey
!call ISRestoreIndicesF90(subpointsIS, subPointKey,ierr)
call ISView(subpointsIS,PETSC_VIEWER_STDOUT_WORLD,ierr)
[1]PETSC ERROR: --------------------- Error Message
[1]PETSC ERROR: Arguments must have same communicators
[1]PETSC ERROR: Different communicators in the two objects: Argument # 1
and 2 flag 3
[1]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
[1]PETSC ERROR: Petsc Development GIT revision: v3.18.1-320-g7810d690132
GIT Date: 2022-11-20 20:25:41 -0600
[1]PETSC ERROR: Configure options with-fc=mpiifort with-mpi-f90=mpiifort
--download-triangle --download-parmetis --download-metis --with-debugging=1
--download-hdf5 --prefix=/home/narnoldm/packages/petsc_install
[1]PETSC ERROR: #1 ISView() at
/home/narnoldm/packages/petsc/src/vec/is/is/interface/index.c:1629
As far as the overall process you have described my question on first
glance is do I have to allocate/create the vector that is output by
VecISCopy before calling it, or does it create the vector automatically? I
think I would need to create it first using a section and Setting the Vec
in the filtered DM? And I presume in this case I would be using the scatter
reverse option to go from the full set to the reduced set?
Sincerely
Nicholas
Sincerely
Nick
On Wed, Dec 7, 2022 at 6:00 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Dec 7, 2022 at 3:35 AM Nicholas Arnold-Medabalimi <
> narnoldm at umich.edu> wrote:
>> Hi Matthew
>> Thank you for the help. This clarified a great deal.
>> I have a follow-up question related to DMPlexFilter. It may be better to
>> describe what I'm trying to achieve.
>> I have a general mesh I am solving which has a section with cell center
>> finite volume states, as described in my initial email. After calculating
>> some metrics, I tag a bunch of cells with an identifying Label and use
>> DMFilter to generate a new DM which is only that subset of cells.
>> Generally, this leads to a pretty unbalanced DM so I then plan to use
>> DMPlexDIstribute to balance that DM across the processors. The coordinates
>> pass along fine, but the state(or I should say Section) does not at least
>> as far as I can tell.
>> Assuming I can get a filtered DM I then distribute the DM and state using
>> the method you described above and it seems to be working ok.
>> The last connection I have to make is the transfer of information from
>> the full mesh to the "sampled" filtered mesh. From what I can gather I
>> would need to get the mapping of points using DMPlexGetSubpointIS and then
>> manually copy the values from the full DM section to the filtered DM? I
>> have the process from full->filtered->distributed all working for the
>> coordinates so its just a matter of transferring the section correctly.
>> I appreciate all the help you have provided.
> Let's do this in two steps, which makes it easier to debug. First, do not
> redistribute the submesh. Just use DMPlexGetSubpointIS()
> to get the mapping of filtered points to points in the original mesh. Then
> create an expanded IS using the Section which makes
> dofs in the filtered mesh to dofs in the original mesh. From this use
> https://petsc.org/main/docs/manualpages/Vec/VecISCopy/
> to move values between the original vector and the filtered vector.
> Once that works, you can try redistributing the filtered mesh. Before
> calling DMPlexDistribute() on the filtered mesh, you need to call
> https://petsc.org/main/docs/manualpages/DM/DMSetUseNatural/
> When you redistribute, it will compute a mapping back to the original
> layout. Now when you want to transfer values, you
> 1) Create a natural vector with DMCreateNaturalVec()
> 2) Use DMGlobalToNaturalBegin/End() to move values from the filtered
> vector to the natural vector
> 3) Use VecISCopy() to move values from the natural vector to the
> original vector
> Let me know if you have any problems.
> Thanks,
> Matt
>> Sincerely
>> Nicholas
>> On Mon, Nov 28, 2022 at 6:19 AM Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Sun, Nov 27, 2022 at 10:22 PM Nicholas Arnold-Medabalimi <
>>>> Hi Petsc Users
>>>> I have a question about properly using PetscSection to assign state
>>>> variables to a DM. I have an existing DMPlex mesh distributed on 2
>>>> processors. My goal is to have state variables set to the cell centers. I
>>>> then want to call DMPlexDistribute, which I hope will balance the mesh
>>>> elements and hopefully transport the state variables to the hosting
>>>> processors as the cells are distributed to a different processor count or
>>>> simply just redistributing after doing mesh adaption.
>>>> Looking at the DMPlex User guide, I should be able to achieve this with
>>>> a single field section using SetDof and assigning the DOF to the points
>>>> corresponding to cells.
>>> Note that if you want several different fields, you can clone the DM
>>> first for this field
>>> call DMClone(dm,dmState,ierr)
>>> and use dmState in your calls below.
>>>> call DMPlexGetHeightStratum(dm,0,c0,c1,ierr)
>>>> call DMPlexGetChart(dm,p0,p1,ierr)
>>>> call PetscSectionCreate(PETSC_COMM_WORLD,section,ierr)
>>>> call PetscSectionSetNumFields(section,1,ierr) call
>>>> PetscSectionSetChart(section,p0,p1,ierr)
>>>> do i = c0, (c1-1)
>>>> call PetscSectionSetDof(section,i,nvar,ierr)
>>>> end do
>>>> call PetscSectionSetup(section,ierr)
>>>> call DMSetLocalSection(dm,section,ierr)
>>> In the loop, I would add a call to
>>> call PetscSectionSetFieldDof(section,i,0,nvar,ierr)
>>> This also puts in the field breakdown. It is not essential, but nicer.
>>>> From here, it looks like I can access and set the state vars using
>>>> call DMGetGlobalVector(dmplex,state,ierr)
>>>> call DMGetGlobalSection(dmplex,section,ierr)
>>>> call VecGetArrayF90(state,stateVec,ierr)
>>>> do i = c0, (c1-1)
>>>> call PetscSectionGetOffset(section,i,offset,ierr)
>>>> stateVec(offset:(offset+nvar))=state_i(:) !simplified assignment
>>>> end do
>>>> call VecRestoreArrayF90(state,stateVec,ierr)
>>>> call DMRestoreGlobalVector(dmplex,state,ierr)
>>>> To my understanding, I should be using Global vector since this is a
>>>> pure assignment operation and I don't need the ghost cells.
>>> Yes.
>>> But the behavior I am seeing isn't exactly what I'd expect.
>>>> To be honest, I'm somewhat unclear on a few things
>>>> 1) Should be using nvar fields with 1 DOF each or 1 field with nvar
>>>> DOFs or what the distinction between the two methods are?
>>> We have two divisions in a Section. A field can have a number of
>>> components. This is intended to model a vector or tensor field.
>>> Then a Section can have a number of fields, such as velocity and
>>> pressure for a Stokes problem. The division is mainly to help the
>>> user, so I would use the most natural one.
>>>> 2) Adding a print statement after the offset assignment I get (on rank
>>>> 0 of 2)
>>>> cell 1 offset 0
>>>> cell 2 offset 18
>>>> cell 3 offset 36
>>>> which is expected and works but on rank 1 I get
>>>> cell 1 offset 9000
>>>> cell 2 offset 9018
>>>> cell 3 offset 9036
>>>> which isn't exactly what I would expect. Shouldn't the offsets reset at
>>>> 0 for the next rank?
>>> The local and global sections hold different information. This is the
>>> source of the confusion. The local section does describe a local
>>> vector, and thus includes overlap or "ghost" dofs. The global section
>>> describes a global vector. However, it is intended to deliver
>>> global indices, and thus the offsets give back global indices. When you
>>> use VecGetArray*() you are getting out the local array, and
>>> thus you have to subtract the first index on this process. You can get
>>> that from
>>> VecGetOwnershipRange(v, &rstart, &rEnd);
>>> This is the same whether you are using DMDA or DMPlex or any other DM.
>>>> 3) Does calling DMPlexDistribute also distribute the section data
>>>> associated with the DOF, based on the description in DMPlexDistribute it
>>>> looks like it should?
>>> No. By default, DMPlexDistribute() only distributes coordinate data. I
>>> you want to distribute your field, it would look something like this:
>>> DMPlexDistribute(dm, 0, &sfDist, &dmDist);
>>> VecCreate(comm, &stateDist);
>>> VecSetDM(sateDist, dmDist);
>>> PetscSectionCreate(comm §ionDist);
>>> DMSetLocalSection(dmDist, sectionDist);
>>> DMPlexDistributeField(dmDist, sfDist, section, state, sectionDist,
>>> stateDist);
>>> We do this in src/dm/impls/plex/tests/ex36.c
>>> THanks,
>>> Matt
>>> I'd appreciate any insight into the specifics of this usage. I expect I
>>>> have a misconception on the local vs global section. Thank you.
>>>> Sincerely
>>>> Nicholas
>>>> Ph.D. Candidate
>>>> Computational Aeroscience Lab
>>>> University of Michigan
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
>> Ph.D. Candidate
> experiments lead.
> -- Norbert Wiener
Ph.D. Candidate
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221207/0b0ce355/attachment.html>
