[petsc-users] About MPIRUN
김성익
ksi2443 at gmail.com
Tue Dec 6 22:34:57 CST 2022
I already done VecAssemblyBegin/End().
However, only mpirun case these outputs are represented.
There are more error outputs as below.
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_SELF
with errorcode 73.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
[ubuntu:02473] PMIX ERROR: UNREACHABLE in file
../../../src/server/pmix_server.c at line 2193
[ubuntu:02473] 3 more processes have sent help message help-mpi-api.txt /
mpi-abort
[ubuntu:02473] Set MCA parameter "orte_base_help_aggregate" to 0 to see all
help / error messages
Could this be the cause of the former petsc error??
Hyung Kim
2022년 12월 6일 (화) 오후 10:58, Matthew Knepley <knepley at gmail.com>님이 작성:
> On Tue, Dec 6, 2022 at 6:45 AM 김성익 <ksi2443 at gmail.com> wrote:
>> Hello,
>> There is a code which can run in not mpirun and also it can run in
>> mpi_linear_solver_server.
>> However, it has an error in just mpirun case such as mpirun -np ./program.
>> The error output is as below.
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Object is in wrong state
>> [0]PETSC ERROR: Not for unassembled vector
>> [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
>> [0]PETSC ERROR: Petsc Release Version 3.18.1, unknown
>> [0]PETSC ERROR: ./app on a arch-linux-c-debug named ubuntu by ksi2443 Tue
>> Dec 6 03:39:13 2022
>> [0]PETSC ERROR: Configure options -download-mumps -download-scalapack
>> -download-parmetis -download-metis
>> [0]PETSC ERROR: #1 VecCopy() at
>> /home/ksi2443/petsc/src/vec/vec/interface/vector.c:1625
>> [0]PETSC ERROR: #2 KSPInitialResidual() at
>> /home/ksi2443/petsc/src/ksp/ksp/interface/itres.c:60
>> [0]PETSC ERROR: #3 KSPSolve_GMRES() at
>> /home/ksi2443/petsc/src/ksp/ksp/impls/gmres/gmres.c:227
>> [0]PETSC ERROR: #4 KSPSolve_Private() at
>> /home/ksi2443/petsc/src/ksp/ksp/interface/itfunc.c:899
>> [0]PETSC ERROR: #5 KSPSolve() at
>> /home/ksi2443/petsc/src/ksp/ksp/interface/itfunc.c:1071
>> [0]PETSC ERROR: #6 main() at /home/ksi2443/Downloads/coding/a1.c:450
>> [0]PETSC ERROR: No PETSc Option Table entries
>> [0]PETSC ERROR: ----------------End of Error Message -------send entire
>> error message to petsc-maint at mcs.anl.gov----------
>> How can I fix this??
> It looks like we do not check the assembled state in parallel, since it
> cannot cause a problem, but every time you
> update values with VecSetValues(), you should call VecAssemblyBegin/End().
> Thanks
> Matt
>> Thanks,
>> Hyung Kim
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221207/c8fc08e1/attachment.html>
