[petsc-users] Installation With MSYS2 and MinGW Compilers
Mon Dec 5 23:43:31 CST 2022
The build log looks fine. Its not clear why these warnings [and
errors] are coming up in make check [while there are no such warnings
in the build].
Since you are using PETSc fromfortran - Can you try compiling/running
a test manually and see if that works.
cd src/snes/tutorials
make ex5f90
./ex5f90
mpiexec -n 2 ./ex5f90
Satish
On Tue, 6 Dec 2022, Singh, Rajesh K wrote:
> Hi Satish,
> Thank you so much for offering help for installing PETSc in MSYS2 and mingw64. Attached are configure.log and make.log files. I am newb in this. Please let me know if you need further information. I will be glad to provide.
> Regards,
> Rajesh
> -----Original Message-----
> From: Satish Balay <balay at mcs.anl.gov>
> Sent: Monday, December 5, 2022 6:53 PM
> To: Singh, Rajesh K <rajesh.singh at pnnl.gov>
> Cc: Pierre Jolivet <pierre at joliv.et>; petsc-users at mcs.anl.gov
> Subject: Re: [petsc-users] Installation With MSYS2 and MinGW Compilers
> Can you send corresponding configure.log and make.log? [should be in PETSC_DIR/PETSC_ARCH/lib/petsc/conf
> Also what is your requirement wrt using PETSc on windows?
> - need to link with other MS compiler libraries?
> - Can you use WSL?
> Our primary instructions for windows usage is with MS/Intel compilers [with cygwin tools] not MSYS2.
> https://gcc02.safelinks.protection.outlook.com/?url=https%3A%2F%2Fpetsc.org%2Frelease%2Finstall%2Fwindows%2F&data=05%7C01%7Crajesh.singh%40pnnl.gov%7Ccf1975f0691a4a6f77a808dad734eec8%7Cd6faa5f90ae240338c0130048a38deeb%7C0%7C0%7C638058922771517675%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=hpyNWLZfFlS6NgV5ehRZ0EwyCnkrJw4yYT0HBvrVJF8%3D&reserved=0
> But As Pierre mentioned - MSYS2 should also work.
> Satish
> On Mon, 5 Dec 2022, Singh, Rajesh K via petsc-users wrote:
> > Hi Pierre,
> > I got following error while compiling PETSc.
> > make all check
> > [cid:image001.png at 01D908C1.7267DCE0]
> > Help for this would be appreciated.
> > Thanks,
> > Rajesh
> > From: Pierre Jolivet <pierre at joliv.et>
> > Sent: Monday, December 5, 2022 1:15 PM
> > Cc: petsc-users at mcs.anl.gov
> > On 5 Dec 2022, at 9:50 PM, Singh, Rajesh K <rajesh.singh at pnnl.gov<mailto:rajesh.singh at pnnl.gov>> wrote:
> > Hi Pierre,
> > Thank you so much for prompt response. I will run FORTRAN based code with PETSc. Therefore I guess I will need Fortran binding.
> > OK, so, two things:
> > 1) as said earlier, Sowing is broken with MinGW, but I'm sadly one of
> > the few PETSc people using this environment, so I'm one of the few who
> > can fix it, but I can't tell you when I'll be able to deliver
> > 2) if you stick to an official tarball, the Fortran bindings should be shipped in. While I work on 1), could you stick to, e.g., https://gcc02.safelinks.protection.outlook.com/?url=https%3A%2F%2Fftp.mcs.anl.gov%2Fpub%2Fpetsc%2Frelease-snapshots%2Fpetsc-3.18.2.tar.gz&data=05%7C01%7Crajesh.singh%40pnnl.gov%7Ccf1975f0691a4a6f77a808dad734eec8%7Cd6faa5f90ae240338c0130048a38deeb%7C0%7C0%7C638058922771517675%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=3gU1u2WRKKvNlBMbq%2FL6RZwvp%2FcRY%2BcLx5i9gJbp9nI%3D&reserved=0<https://gcc02.safelinks.protection.outlook.com/?url=https%3A%2F%2Fftp.mcs.anl.gov%2Fpub%2Fpetsc%2Frelease-snapshots%2Fpetsc-3.18.2.tar.gz&data=05%7C01%7Crajesh.singh%40pnnl.gov%7Ccf1975f0691a4a6f77a808dad734eec8%7Cd6faa5f90ae240338c0130048a38deeb%7C0%7C0%7C638058922771517675%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&s
 data=3gU
 1u2WRKKvNlBMbq%2FL6RZwvp%2FcRY%2BcLx5i9gJbp9nI%3D&reserved=0>?
> > Thanks,
> > Pierre
> > Regards
> > Rajesh
> > From: Pierre Jolivet <pierre at joliv.et<mailto:pierre at joliv.et>>
> > Sent: Monday, December 5, 2022 12:41 PM
> > To: Singh, Rajesh K
> > Cc: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>
> > Check twice before you click! This email originated from outside PNNL.
> > Hello Rajesh,
> > Do you need Fortran bindings?
> > Otherwise, ./configure --with-fortran-bindings=0 should do the trick.
> > Sowing compilation is broken with MinGW compiler.
> > If you need Fortran bindings, we could try to fix it.
> > Thanks,
> > Pierre
> > On 5 Dec 2022, at 9:22 PM, Singh, Rajesh K via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
> > Dear All:
> > I am having diffisulty to install PETSC on the window system. I went through the the steps esplained in the web site and got following error.
> > <image001.png>
> > Help for resolving this issue would be really appricaited.
> > Thanks,
> > Rajesh
