[petsc-users] Installation With MSYS2 and MinGW Compilers
Singh, Rajesh K
rajesh.singh at pnnl.gov
Mon Dec 5 17:51:34 CST 2022
Hi Pierre,
I got following error while compiling PETSc.
make all check
[cid:image001.png at 01D908C1.7267DCE0]
Help for this would be appreciated.
Rajesh
Sent: Monday, December 5, 2022 1:15 PM
To: Singh, Rajesh K <rajesh.singh at pnnl.gov>
Cc: petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] Installation With MSYS2 and MinGW Compilers
On 5 Dec 2022, at 9:50 PM, Singh, Rajesh K <rajesh.singh at pnnl.gov<mailto:rajesh.singh at pnnl.gov>> wrote:
Hi Pierre,
Thank you so much for prompt response. I will run FORTRAN based code with PETSc. Therefore I guess I will need Fortran binding.
OK, so, two things:
1) as said earlier, Sowing is broken with MinGW, but I'm sadly one of the few PETSc people using this environment, so I'm one of the few who can fix it, but I can't tell you when I'll be able to deliver
2) if you stick to an official tarball, the Fortran bindings should be shipped in. While I work on 1), could you stick to, e.g., https://ftp.mcs.anl.gov/pub/petsc/release-snapshots/petsc-3.18.2.tar.gz<https://gcc02.safelinks.protection.outlook.com/?url=https%3A%2F%2Fftp.mcs.anl.gov%2Fpub%2Fpetsc%2Frelease-snapshots%2Fpetsc-3.18.2.tar.gz&data=05%7C01%7Crajesh.singh%40pnnl.gov%7C6ca621eb7f004c35be5f08dad705d997%7Cd6faa5f90ae240338c0130048a38deeb%7C0%7C0%7C638058718442399693%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=grwrIpVDLyzREtA6zRERjN%2FkqaCxkWY51Ade5WtSbTU%3D&reserved=0>?
Pierre
Regards
Rajesh
From: Pierre Jolivet <pierre at joliv.et<mailto:pierre at joliv.et>>
Sent: Monday, December 5, 2022 12:41 PM
To: Singh, Rajesh K <rajesh.singh at pnnl.gov<mailto:rajesh.singh at pnnl.gov>>
Cc: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>
Check twice before you click! This email originated from outside PNNL.
Hello Rajesh,
Do you need Fortran bindings?
Otherwise, ./configure --with-fortran-bindings=0 should do the trick.
Sowing compilation is broken with MinGW compiler.
If you need Fortran bindings, we could try to fix it.
Pierre
On 5 Dec 2022, at 9:22 PM, Singh, Rajesh K via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
Dear All:
I am having diffisulty to install PETSC on the window system. I went through the the steps esplained in the web site and got following error.
<image001.png>
Help for resolving this issue would be really appricaited.
Rajesh
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221205/39c1ca3f/attachment-0001.html>
Type: image/png
Desc: image001.png
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221205/39c1ca3f/attachment-0001.png>
