[petsc-users] About matrix assembly
Matthew Knepley
knepley at gmail.com
Mon Dec 5 07:16:31 CST 2022
On Mon, Dec 5, 2022 at 6:48 AM 김성익 <ksi2443 at gmail.com> wrote:
> Hello,
> In matrix preallocation procedure, I tried 2 options to preallocate global
> matrix.
> The first is ‘MatSeqAIJSetPreallocation’ and the second is
> ‘MatSetPreallocationCOO’.
> When I adopt the first option “MatSeqAIJSetPreallocation(Mat, nz, nnz)”, I
> just put overestimated nz for getting enough memory space and also getting
> nice performance.
> However, It couldn’t run without “MatSetOption(Mat,
> MAT_NEW_NONZERO_ALLOCATION_ERR, PETSC_FALSE);” And also, there are no speed
> up compare with no preallocation case.
1. This means your nz was not big enough.
2. I suggest computing the correct length for every row. The easiest way to
do this is to use
https://petsc.org/main/docs/manualpages/Mat/MatPreallocatorPreallocate/
There re instructions on that page. This is how I do it in the library now.
> When in the second option “MatSetPreallocationCOO(Mat,ncoo,coo_i,coo_j)”,
> I put correct size parameters(ncoo, coo_i, coo_j). However, It couldn’t run
> without “MatSetOption(Mat, MAT_NEW_NONZERO_ALLOCATION_ERR, PETSC_FALSE);”
> Regarding this problem, I suspect that it is a problem caused by mapping a
> small-sized local matrix with a different order from the order of coo_i and
> coo_j to the global matrix by using “matsetvalue”. And also, there are no
> speed up compare with no preallocation case.
If you cannot run without that flag, it means that you are inserting
different nonzeros then you did with MatSetPreallocationCOO(). You need to
tell
it _exactly_ the same nonzeros as you input with MatSetValues().
Matt
> 1. How can I do proper preallocation procedure?
> 2. Why in my cases there are no speed up?
> Thanks,
> Hyung Kim
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221205/d5e03e24/attachment.html>
