[petsc-users] DMPlex Interpolation
Matthew Knepley
knepley at gmail.com
Sun Aug 28 18:17:37 CDT 2022
On Sun, Aug 28, 2022 at 5:36 PM Mike Michell <mi.mike1021 at gmail.com> wrote:
> Thank you for the reply.
> I think it can be more helpful for me if the attached sample code
> (DMInterpolation_Mod.tar) could be checked by you.
Okay, you are right. I will run it tomorrow.
Matt
> If you run the sample code, basically, you would get
> "VertexField_Map_from_Cell.vtu" file which displays a solution vector field
> defined on each vertex, which is mapped from another solution field defined
> on each cell-centroid. The vertex solution field in the vtu file should
> match with "x-coordinate" value in the same file. Basically, the attached
> code tries to reproduce vertex's x-coordinate value using
> cell-centroid's x-coordinate value by means of finite-element space mapping
> between Q0 and Q1.
> From the vtu file, it is obvious that at the physical boundaries (left,
> right, top, and bottom) x-coordinate value is not properly mapped from
> cell-centroid, whereas interior vertex's solution seems okay. What I do not
> understand is why the boundary vertices cannot have properly mapped
> coordinate values? I believe I am doing something wrong and I was
> suspicious about the ghost cell, which I do not have. But your comment
> seems to say that the problem is not related to the ghost cell. What am I
> doing wrong?
> Does your section mark these unknowns as constrained?
> --> Yes, as shown in the code, I defined one section for each dmplex, one
> for vertex and one for cell, respectively, with 1-dof for each (See code
> line from 91 to 124).
> You should not get 0 unless you constrained these variables in the
> section. If not, you should see it use the constant values in the cell.
> --> Yes, you are correct. Now I do not have zero value at the physical
> boundaries, however, it is still not proper value and seems underscaled,
> compared to the proper answer (i.e., compared with the properly mapped
> interior values).
> Thanks,
>> On Sun, Aug 28, 2022 at 12:11 PM Mike Michell <mi.mike1021 at gmail.com>
>>> *I cannot quite understand. Are you saying that you have inhomogeneous
>>> Dirichlet conditions on the boundary, and a 0 guess in the interior, and
>>> you get all zeros from interpolation? Yes, we have no way of getting
>>> boundary values into the operator. You could conceivably make an operator
>>> that mapped between local vectors, but it is hard to see why you would want
>>> this. In the solver, we usually just care about the unknowns we are
>>> solving for. Did I understand your question, or is it about something else?*
>>> --> It is not imposing a physical boundary condition (Dirichlet
>>> condition for example), but my solver needs to import an external solution
>>> vector field resolved to each cell-centroid, then I need to map it to a
>>> vertex field in which my solver is resolved for solving governing
>>> equations. Then, my code solves its equations. After my solver is done
>>> solving the equations, the vertex field should be re-map into cell-field
>>> and then push back the cell field to the external code. With this context,
>>> I have zero values returned at the vertices on the physical boundaries
>>> if I try mapping from cell-center to vertex field without having ghost
>>> cell layers inside physical boundaries. For interior vertices, I get
>>> reasonable mapped values, although the mapping accuracy seems to be able to
>>> be improved as I mentioned in the earlier email.
>> As I replied, I think this is not true.
>>> If dmplex for cell-center field would be defined to have ghost cell
>>> layer, and fill it (it meant import ghost cell values as well from the
>>> external code), and map it to vertex-field, can it be possible to fill
>>> vertex points on the physical boundaries?
>> Thanks,
>> Matt
>>> I was trying to test this strategy, but it
>>> seems DMPlexComputeCellGeometryFVM() gives NaN values if dmplex has ghost
>>> cell by calling DMPlexConstructGhostCells(). In detail,
>>> DMPlexComputeCellGeometryFVM() gives zero area for each cell, and returns
>>> NaN values for cell centroids and normals for the ghost cells.
>>> Thanks,
>>>> On Sun, Aug 28, 2022 at 8:51 AM Mike Michell <mi.mike1021 at gmail.com>
>>>> wrote:
>>>>> Hi, thank you for the reply.
>>>>> I was able to manage mapping from cell-center to vertex. Basically, in
>>>>> Fortran, it seems DMCreateInterpolation() requires the optional scaling
>>>>> vector as a mandatory argument, which is strange.
>>>> It needs a custom Fortran wrapper to check for the NULL input from
>>>> Fortran.
>>>>> My dmplex has zero overlap layer over the procs, and there is no ghost
>>>>> cell inside physical boundary. In this case, it seems mapping between cell
>>>>> center to vertex returns zero (in case the global cell vector initialized
>>>>> to zero) value at the nodes, which are located at physical boundary. To
>>>>> manage this problem, is it mandatory to have ghost cells. Is this correct
>>>>> understanding?
>>>> solving for.
>>>>> Also, my mapping accuracy itself seems to be improved. For simple
>>>>> test, cell-center's x-coordinate value of each cell mapped to node and
>>>>> printed to the vertex field as .vtu format, and the mapped
>>>>> x-vertex-coordinate is quite different with the actual nodal coordinate
>>>>> values what PETSc intrinsically provides through DMGetCoordinatesLocal(). I
>>>>> believe I am doing something wrong, probably arguments
>>>>> in PetscFECreateLagrange() can improve the mapping accuracy in
>>>>> finite-element space?
>>>> Yes, a cellwise field is much less accurate than a linear field.
>>>> Pushing the values up to a linear field does not make them more accurate.
>>>> Thanks,
>>>> Matt
>>>>> Thanks,
>>>>>> On Thu, Aug 25, 2022 at 7:12 PM Mike Michell <mi.mike1021 at gmail.com>
>>>>>> wrote:
>>>>>>> Hi, this is a duplication of
>>>>>>> https://lists.mcs.anl.gov/pipermail/petsc-users/2022-August/046746.html
>>>>>>> for in-depth question.
>>>>>>> I wrote a short code as attached to test interpolation between two
>>>>>>> DMPlex objects. Goal is to map solution field defined on
>>>>>>> cell-centroid(DMPlex-1) into vertex(DMPlex-2) field or vice versa.
>>>>>>> Basically, DMCreateInterpolation() fails in the example code and it
>>>>>>> was not allowed to get useful error messages. The DMPlex is created by
>>>>>>> loading a 2D square box in Gmsh. Can I get some comments on that?
>>>>>> Sure, I am looking at it.
>>>>>> Thanks,
>>>>>> Matt
>>>>>>> Thanks,
>>>>>> What most experimenters take for granted before they begin their
>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220828/25ea6792/attachment.html>
