[petsc-users] Hint for compiling PETSC on Windows with non-english language settings
Barry Smith
bsmith at petsc.dev
Sun Aug 28 13:14:58 CDT 2022
Is there a way to automatically check the package language? If so, we will do that check right at the beginning of configure to limit the user's need to read the PETSc documentation before getting to work :-)
> On Aug 28, 2022, at 2:09 PM, Andreas Hauffe <andreas.hauffe at tu-dresden.de> wrote:
> Hi,
> perhaps it is possible to add a short hint in the documentation (https://petsc.org/main/install/windows/ <https://petsc.org/main/install/windows/>) for Windows OS with a non-english default language. It is important, that the compiler is installed with english language pack, so that all compiler output is in english. Otherwise the filter during the PETSC configuration will not work correctly.
> Regards,
> Andreas Hauffe
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220828/48ba096a/attachment-0001.html>
