[petsc-users] DMPlex Interpolation
Fri Aug 26 09:47:54 CDT 2022
On Thu, Aug 25, 2022 at 7:12 PM Mike Michell <mi.mike1021 at gmail.com> wrote:
> Hi, this is a duplication of
> https://lists.mcs.anl.gov/pipermail/petsc-users/2022-August/046746.html
> for in-depth question.
> I wrote a short code as attached to test interpolation between two DMPlex
> objects. Goal is to map solution field defined on cell-centroid(DMPlex-1)
> into vertex(DMPlex-2) field or vice versa.
> Basically, DMCreateInterpolation() fails in the example code and it was
> not allowed to get useful error messages. The DMPlex is created by loading
> a 2D square box in Gmsh. Can I get some comments on that?
Sure, I am looking at it.
     Matt
> Thanks,
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220826/00a617f4/attachment.html>
