[petsc-users] [petsc-maint] metis version of petsc - segmentation fault
Matthew Knepley
knepley at gmail.com
Thu Aug 25 12:08:22 CDT 2022
On Thu, Aug 25, 2022 at 12:38 PM Alexandre Halbach <
alexandre.halbach at gmail.com> wrote:
> Hello,
> I am using the metis package provided by the latest petsc version, using
> --download-metis (Linux, 32 bits). This question is arguably more a metis
> issue but since metis is used in petsc and mumps this seems relevant to ask
> here too.
> I systematically get a segmentation fault on this metis version (didn't
> try others) when I partition even simple and not too large graphs ( O(5
> millions)). I tried a lot of cases as well as both the 32 and 64 bits
> version of petsc and also increasing ulimit (on Linux).
> Here is the shortest possible representative example with that problem
> (c++). I double checked it and I hope there is no mistake in this example.
> The below example constructs the containers for a 1D line graph (n
> vertices connected by edges one by one as in a chain. Both end vertices
> only have a single neighbor while all other vertices have two neighbors).
> Either this is something I am doing wrong or there is a bug in at least
> the metis version proposed in petsc.
> Here is the example producing a segfault. If you don't get a segfault try
> a 10 millions or more vertices graph.
You are exceeding the stack space. I will rewrite to malloc() and take a
look.
Matt
> Thank you for your help and your great work!
> Alex
> #include "metis.h"
> int main(void)
> // Number of vertices:
> int n = 1000000;
> // Addresses should for example be [0 1 3 5 7 8] for 5 vertices
> idx_t addresses[n+1];
> addresses[0] = 0; addresses[1] = 1;
> for (int i = 2; i < n; i++)
> addresses[i] = addresses[i-1] + 2;
> addresses[n] = addresses[n-1]+1;
> // Connected vertices should for example be [1 0 2 1 3 2 4 3] for 5
> vertices
> idx_t connectivities[2*(n-1)];
> connectivities[0] = 1;
> for (int i = 1; i < n-1; i++)
> connectivities[2*i-1] = i-1;
> connectivities[2*i+0] = i+1;
> connectivities[2*(n-1)-1] = connectivities[2*(n-1)-2]-1;
> idx_t nvtxs = n;
> idx_t nEdges = n-1;
> idx_t metisOptions[METIS_NOPTIONS];
> METIS_SetDefaultOptions(metisOptions);
> metisOptions[METIS_OPTION_NUMBERING] = 0; // c numbering (start at 0)
> idx_t ncon = 1;
> idx_t nParts = 2;
> idx_t objval;
> idx_t part[nvtxs];
> int ret = METIS_PartGraphRecursive ( &nvtxs, &ncon, addresses,
> connectivities, NULL, NULL, NULL, &nParts, NULL, NULL, metisOptions,
> &objval, part );
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220825/dc127ba3/attachment.html>
