[petsc-users] PETSc on fedora 36
Barry Smith bsmith at petsc.dev
Mon Aug 22 13:36:43 CDT 2022
  Are you sure the mpirun you are using matches the mpi that PETSc was built with?
> On Aug 22, 2022, at 2:31 PM, Rafel Amer Ramon <rafel.amer at upc.edu> wrote:
> Hi,
> I have installed the following packages on fedora 36
> ~# rpm -qa | grep petsc
> petsc64-3.16.4-3.fc36.x86_64
> petsc-3.16.4-3.fc36.x86_64
> petsc-openmpi-3.16.4-3.fc36.x86_64
> petsc-openmpi-devel-3.16.4-3.fc36.x86_64
> python3-petsc-openmpi-3.16.4-3.fc36.x86_64
> petsc-devel-3.16.4-3.fc36.x86_64
> petsc64-devel-3.16.4-3.fc36.x86_64
> ~# rpm -qa | grep openmpi
> openmpi-4.1.2-3.fc36.x86_64
> ptscotch-openmpi-6.1.2-2.fc36.x86_64
> scalapack-openmpi-2.1.0-11.fc36.x86_64
> openmpi-devel-4.1.2-3.fc36.x86_64
> MUMPS-openmpi-5.4.1-2.fc36.x86_64
> superlu_dist-openmpi-6.1.1-9.fc36.x86_64
> hdf5-openmpi-1.12.1-5.fc36.x86_64
> hypre-openmpi-2.18.2-6.fc36.x86_64
> fftw-openmpi-libs-double-3.3.10-2.fc36.x86_64
> fftw-openmpi-libs-long-3.3.10-2.fc36.x86_64
> fftw-openmpi-libs-single-3.3.10-2.fc36.x86_64
> fftw-openmpi-libs-3.3.10-2.fc36.x86_64
> fftw-openmpi-devel-3.3.10-2.fc36.x86_64
> scalapack-openmpi-devel-2.1.0-11.fc36.x86_64
> python3-openmpi-4.1.2-3.fc36.x86_64
> hdf5-openmpi-devel-1.12.1-5.fc36.x86_64
> cgnslib-openmpi-4.2.0-6.fc36.x86_64
> cgnslib-openmpi-devel-4.2.0-6.fc36.x86_64
> and I try to compile and run the program written in the file e.c
> ~# cat e.c
> #include <petsc.h>
> int main(int argc, char **argv) {
>   PetscErrorCode ierr;
>   PetscMPIInt    rank;
>   ierr = PetscInitialize(&argc,&argv,NULL,
>       "Compute e in parallel with PETSc.\n\n"); if (ierr) return ierr;
>   ierr = MPI_Comm_rank(PETSC_COMM_WORLD,&rank); CHKERRQ(ierr);
>   ierr = PetscPrintf(PETSC_COMM_WORLD,"My rank is %d\n",rank); CHKERRQ(ierr);
>   return PetscFinalize();
> I compile it with the command
> ~# mpicc -o e e.c -I/usr/include/petsc64 -lpetsc64
> and I run it with
> ~# mpirun -np 8 ./e
> My rank is 0
> My rank is 0
> My rank is 0
> My rank is 0
> My rank is 0
> My rank is 0
> My rank is 0
> My rank is 0
> but all my process get rank 0.
> Do you know what I'm doing wrong?
> Thank you!!
> Best regards,
> Rafel Amer
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220822/28a12c95/attachment.html>
