[petsc-users] Preallocating a matrix with the d_nnz and o_nnz arrays
Barry Smith
bsmith at petsc.dev
Mon Aug 22 11:39:15 CDT 2022
MatGetOwnershipRangeColumn() tells you the start and end+1 of the columns that are in the diagonal block. For square matrices they are the same as rstart and rend.
Barry
> On Aug 22, 2022, at 12:12 PM, Patrick Alken <patrick.alken at geomag.info> wrote:
> Thank you, I have read that document. I have changed my criteria to:
> if (j >= first && (j - first) < m) {
> /*diagonal*/
> else
> /*off-diagonal*/
> It seems to be working better. I don't know how to get the c1 and c2 columns referred to by the documentation.
> Patrick
> On 8/22/22 10:03, Zhang, Hong wrote:
>> See https://petsc.org/release/docs/manualpages/Mat/MatMPIAIJSetPreallocation.html#MatMPIAIJSetPreallocation <https://petsc.org/release/docs/manualpages/Mat/MatMPIAIJSetPreallocation.html#MatMPIAIJSetPreallocation>
>> MatMPIAIJSetPreallocation - PETSc <https://petsc.org/release/docs/manualpages/Mat/MatMPIAIJSetPreallocation.html#MatMPIAIJSetPreallocation>
>> MatMPIAIJSetPreallocation Preallocates memory for a sparse parallel matrix in AIJ format (the default parallel PETSc format). For good matrix assembly performance the user should preallocate the matrix storage by setting the parameters d_nz (or d_nnz) and o_nz (or o_nnz).
>> petsc.org <http://petsc.org/>
>> if you use mpiaij matrix.
>> Hong
>> From: petsc-users <petsc-users-bounces at mcs.anl.gov> <mailto:petsc-users-bounces at mcs.anl.gov> on behalf of Patrick Alken <patrick.alken at geomag.info> <mailto:patrick.alken at geomag.info>
>> Sent: Monday, August 22, 2022 10:56 AM
>> To: petsc-users <petsc-users at mcs.anl.gov> <mailto:petsc-users at mcs.anl.gov>
>> Subject: [petsc-users] Preallocating a matrix with the d_nnz and o_nnz arrays
>> I am looping through all the non-zero elements of my matrix to count the
>> diagonal and off-diagonal terms in order to pre-allocate the matrix.
>> However, what is the criteria for knowing if a given element is in the
>> diagonal portion or off-diagonal portion? It seems that it will depend
>> on row, column, and also processor. I was doing something like this:
>> MatGetLocalSize(A, &m, &n);
>> MatGetOwnershipRange(A, &first, &last);
>> for (i = first; i < last; ++i) {
>> for (j = 0; j < N; ++j) {
>> if (abs(i - j) < m)
>> ++d_nnz[i - first];
>> else
>> ++o_nnz[i - first];
>> However, the criteria: abs(i - j) < m is not correct. I think the
>> correct criteria will include the processor number also. Does anyone
>> know the correct criteria to use?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220822/f9247c8a/attachment.html>
