[petsc-users] Scaling of PETSc example ex2f.F90
    Sidarth Narayanan
    snarayanan1 at altair.com
    Tue Aug 16 11:27:01 CDT 2022
Hello PETSc team,
I am currently using PETSc to improve the performance of a CFD solver by using it's parallel linear solver. While doing so I ran across some scaling issues where performance increase ( measured as KSPSolve time using MPI_Wtime() function )  in the linear algebra operation was only 2 times while using 4 processes. So I tried to check the scaling of the example problem ex2f.F90 provided as a part of the PETSc package and ran across a similar issue there. Here is the issue, If I run the problem on 1000 x 1000 2-D, five-point stencil with the exact solution set to 1.0, the scaling is perfect. But as soon as I change the exact solution to random values by using the flag -random_exact_sol (generally between 0 and 1), the scaling takes a  major hit. I have not changed the example code apart from increasing problem size and adding the time stamps before and after KSPSolve. Could you please let me know what I am missing (or) doing wrong here ? And I was also wondering if PETSc had an option to print out the pre-conditioned matrix as changing the exact solution changes the RHS and hence might change the pre-conditioned matrix. I have provided below the exact code and the results from the 4 runs including the compilation part.
Source Code: (ex2f.F90 with time stamps and increased problem size)
!  Description: Solves a linear system in parallel with KSP (Fortran code).
!               Also shows how to set a user-defined monitoring routine.
      program main
#include <petsc/finclude/petscksp.h>
      use petscksp
      implicit none
!                   Variable declarations
!  Variables:
!     ksp     - linear solver context
!     ksp      - Krylov subspace method context
!     pc       - preconditioner context
!     x, b, u  - approx solution, right-hand-side, exact solution vectors
!     A        - matrix that defines linear system
!     its      - iterations for convergence
!     norm     - norm of error in solution
!     rctx     - random number generator context
!  Note that vectors are declared as PETSc "Vec" objects.  These vectors
!  are mathematical objects that contain more than just an array of
!  double precision numbers. I.e., vectors in PETSc are not just
!        double precision x(*).
!  However, local vector data can be easily accessed via VecGetArray().
!  See the Fortran section of the PETSc users manual for details.
      PetscReal  norm,t1,t2
      PetscInt  i,j,II,JJ,m,n,its
      PetscInt  Istart,Iend,ione
      PetscErrorCode ierr
      PetscMPIInt     rank,size
      PetscBool   flg
      PetscScalar v,one,neg_one
      Vec         x,b,u
      Mat         A
      KSP         ksp
      PetscRandom rctx
      PetscViewerAndFormat vf,vzero
!  These variables are not currently used.
!      PC          pc
!      PCType      ptype
!      PetscReal tol
!  Note: Any user-defined Fortran routines (such as MyKSPMonitor)
!  MUST be declared as external.
      external MyKSPMonitor,MyKSPConverged
!                 Beginning of program
      call PetscInitialize(PETSC_NULL_CHARACTER,ierr)
      if (ierr .ne. 0) then
        print*,'Unable to initialize PETSc'
        stop
      endif
      m = 1000
      n = 1000
      one  = 1.0
      neg_one = -1.0
      ione    = 1
      call PetscOptionsGetInt(PETSC_NULL_OPTIONS,PETSC_NULL_CHARACTER,'-m',m,flg,ierr)
      call PetscOptionsGetInt(PETSC_NULL_OPTIONS,PETSC_NULL_CHARACTER,'-n',n,flg,ierr)
      call MPI_Comm_rank(PETSC_COMM_WORLD,rank,ierr)
      call MPI_Comm_size(PETSC_COMM_WORLD,size,ierr)
!      Compute the matrix and right-hand-side vector that define
!      the linear system, Ax = b.
!  Create parallel matrix, specifying only its global dimensions.
!  When using MatCreate(), the matrix format can be specified at
!  runtime. Also, the parallel partitioning of the matrix is
!  determined by PETSc at runtime.
      call MatCreate(PETSC_COMM_WORLD,A,ierr)
      call MatSetSizes(A,PETSC_DECIDE,PETSC_DECIDE,m*n,m*n,ierr)
      call MatSetFromOptions(A,ierr)
      call MatSetUp(A,ierr)
!  Currently, all PETSc parallel matrix formats are partitioned by
!  contiguous chunks of rows across the processors.  Determine which
!  rows of the matrix are locally owned.
      call MatGetOwnershipRange(A,Istart,Iend,ierr)
!  Set matrix elements for the 2-D, five-point stencil in parallel.
!   - Each processor needs to insert only elements that it owns
!     locally (but any non-local elements will be sent to the
!     appropriate processor during matrix assembly).
!   - Always specify global row and columns of matrix entries.
!   - Note that MatSetValues() uses 0-based row and column numbers
!     in Fortran as well as in C.
!     Note: this uses the less common natural ordering that orders first
!     all the unknowns for x = h then for x = 2h etc; Hence you see JH = II +- n
!     instead of JJ = II +- m as you might expect. The more standard ordering
!     would first do all variables for y = h, then y = 2h etc.
      do 10, II=Istart,Iend-1
        v = -1.0
        i = II/n
        j = II - i*n
        if (i.gt.0) then
          JJ = II - n
          call MatSetValues(A,ione,II,ione,JJ,v,INSERT_VALUES,ierr)
        endif
        if (i.lt.m-1) then
          JJ = II + n
        endif
        if (j.gt.0) then
          JJ = II - 1
        endif
        if (j.lt.n-1) then
          JJ = II + 1
        endif
        v = 4.0
        call  MatSetValues(A,ione,II,ione,II,v,INSERT_VALUES,ierr)
10   continue
!  Assemble matrix, using the 2-step process:
!       MatAssemblyBegin(), MatAssemblyEnd()
!  Computations can be done while messages are in transition,
!  by placing code between these two statements.
      call MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY,ierr)
      call MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY,ierr)
!  Create parallel vectors.
!   - Here, the parallel partitioning of the vector is determined by
!     PETSc at runtime.  We could also specify the local dimensions
!     if desired -- or use the more general routine VecCreate().
!   - When solving a linear system, the vectors and matrices MUST
!     be partitioned accordingly.  PETSc automatically generates
!     appropriately partitioned matrices and vectors when MatCreate()
!     and VecCreate() are used with the same communicator.
!   - Note: We form 1 vector from scratch and then duplicate as needed.
      call VecCreateMPI(PETSC_COMM_WORLD,PETSC_DECIDE,m*n,u,ierr)
      call VecSetFromOptions(u,ierr)
      call VecDuplicate(u,b,ierr)
      call VecDuplicate(b,x,ierr)
!  Set exact solution; then compute right-hand-side vector.
!  By default we use an exact solution of a vector with all
!  elements of 1.0;  Alternatively, using the runtime option
!  -random_sol forms a solution vector with random components.
      call PetscOptionsHasName(PETSC_NULL_OPTIONS,PETSC_NULL_CHARACTER,'-random_exact_sol',flg,ierr)
      if (flg) then
         call PetscRandomCreate(PETSC_COMM_WORLD,rctx,ierr)
         call PetscRandomSetFromOptions(rctx,ierr)
         call VecSetRandom(u,rctx,ierr)
         call PetscRandomDestroy(rctx,ierr)
      else
         call VecSet(u,one,ierr)
      endif
      call MatMult(A,u,b,ierr)
!  View the exact solution vector if desired
      call PetscOptionsHasName(PETSC_NULL_OPTIONS,PETSC_NULL_CHARACTER,'-view_exact_sol',flg,ierr)
      if (flg) then
         call VecView(u,PETSC_VIEWER_STDOUT_WORLD,ierr)
      endif
!         Create the linear solver and set various options
!  Create linear solver context
      call KSPCreate(PETSC_COMM_WORLD,ksp,ierr)
!  Set operators. Here the matrix that defines the linear system
!  also serves as the preconditioning matrix.
      call KSPSetOperators(ksp,A,A,ierr)
!  Set linear solver defaults for this problem (optional).
!   - By extracting the KSP and PC contexts from the KSP context,
!     we can then directly directly call any KSP and PC routines
!     to set various options.
!   - The following four statements are optional; all of these
!     parameters could alternatively be specified at runtime via
!     KSPSetFromOptions(). All of these defaults can be
!     overridden at runtime, as indicated below.
!     We comment out this section of code since the Jacobi
!     preconditioner is not a good general default.
!      call KSPGetPC(ksp,pc,ierr)
!      ptype = PCJACOBI
!      call PCSetType(pc,ptype,ierr)
!      tol = 1.e-7
!      call KSPSetTolerances(ksp,tol,PETSC_DEFAULT_REAL,PETSC_DEFAULT_REAL,PETSC_DEFAULT_INTEGER,ierr)
!  Set user-defined monitoring routine if desired
      call PetscOptionsHasName(PETSC_NULL_OPTIONS,PETSC_NULL_CHARACTER,'-my_ksp_monitor',flg,ierr)
      if (flg) then
        vzero = 0
        call KSPMonitorSet(ksp,MyKSPMonitor,vzero,PETSC_NULL_FUNCTION,ierr)
!     Also use the default KSP monitor routine showing how it may be used from Fortran
        call PetscViewerAndFormatCreate(PETSC_VIEWER_STDOUT_WORLD,PETSC_VIEWER_DEFAULT,vf,ierr)
        call KSPMonitorSet(ksp,KSPMonitorResidual,vf,PetscViewerAndFormatDestroy,ierr)
      endif
!  Set runtime options, e.g.,
!      -ksp_type <type> -pc_type <type> -ksp_monitor -ksp_rtol <rtol>
!  These options will override those specified above as long as
!  KSPSetFromOptions() is called _after_ any other customization
!  routines.
      call KSPSetFromOptions(ksp,ierr)
!  Set convergence test routine if desired
      call PetscOptionsHasName(PETSC_NULL_OPTIONS,PETSC_NULL_CHARACTER,'-my_ksp_convergence',flg,ierr)
      if (flg) then
        call KSPSetConvergenceTest(ksp,MyKSPConverged,0,PETSC_NULL_FUNCTION,ierr)
      endif
!                      Solve the linear system
                 t1 = MPI_Wtime()
      call KSPSolve(ksp,b,x,ierr)
                 t2 = MPI_Wtime()
                 !x =A-1b
!                     Check solution and clean up
!  Check the error
      call VecAXPY(x,neg_one,u,ierr)
      call VecNorm(x,NORM_2,norm,ierr)
      call KSPGetIterationNumber(ksp,its,ierr)
      if (rank .eq. 0) then
        if (norm .gt. 1.e-12) then
           write(6,100) norm,its
        else
           write(6,110) its
        endif
                              write(6,111) t2 - t1
      endif
  100 format('Norm of error ',e11.4,' iterations ',i5)
  110 format('Norm of error < 1.e-12 iterations ',i5)
  111 format('KSPSolve time: ',f10.3)
!  Free work space.  All PETSc objects should be destroyed when they
!  are no longer needed.
      call KSPDestroy(ksp,ierr)
      call VecDestroy(u,ierr)
      call VecDestroy(x,ierr)
      call VecDestroy(b,ierr)
      call MatDestroy(A,ierr)
!  Always call PetscFinalize() before exiting a program.  This routine
!    - finalizes the PETSc libraries as well as MPI
!    - provides summary and diagnostic information if certain runtime
!      options are chosen (e.g., -log_view).  See PetscFinalize()
!      manpage for more information.
      call PetscFinalize(ierr)
      end
!  MyKSPMonitor - This is a user-defined routine for monitoring
!  the KSP iterative solvers.
!  Input Parameters:
!    ksp   - iterative context
!    n     - iteration number
!    rnorm - 2-norm (preconditioned) residual value (may be estimated)
!    dummy - optional user-defined monitor context (unused here)
      subroutine MyKSPMonitor(ksp,n,rnorm,dummy,ierr)
      use petscksp
      implicit none
      KSP              ksp
      Vec              x
      PetscErrorCode ierr
      PetscInt n,dummy
      PetscMPIInt rank
      PetscReal rnorm
!  Build the solution vector
      call KSPBuildSolution(ksp,PETSC_NULL_VEC,x,ierr)
!  Write the solution vector and residual norm to stdout
!   - Note that the parallel viewer PETSC_VIEWER_STDOUT_WORLD
!     handles data from multiple processors so that the
!     output is not jumbled.
      if (rank .eq. 0) write(6,100) n
      call VecView(x,PETSC_VIEWER_STDOUT_WORLD,ierr)
      if (rank .eq. 0) write(6,200) n,rnorm
100  format('iteration ',i5,' solution vector:')
200  format('iteration ',i5,' residual norm ',e11.4)
      ierr = 0
      end
!  MyKSPConverged - This is a user-defined routine for testing
!  convergence of the KSP iterative solvers.
!  Input Parameters:
      subroutine MyKSPConverged(ksp,n,rnorm,flag,dummy,ierr)
      use petscksp
      implicit none
      KSP              ksp
      PetscErrorCode ierr
      PetscInt n,dummy
      KSPConvergedReason flag
      PetscReal rnorm
      if (rnorm .le. .05) then
        flag = 1
      else
        flag = 0
      endif
      ierr = 0
      end
!/*TEST
!   test:
!      nsize: 2
!      args: -pc_type jacobi -ksp_monitor_short -ksp_gmres_cgs_refinement_type refine_always
!   test:
!      suffix: 2
!      nsize: 2
!      args: -pc_type jacobi -my_ksp_monitor -ksp_gmres_cgs_refinement_type refine_always
!TEST*/
Output:
snarayanan1 at USLN38 /cygdrive/c/sidarth/petsc-test/scaling_test
$ make ex2f
/home/snarayanan1/petsc-release/lib/petsc/bin/win32fe/win32fe ifort -MT -O3 -fpp  -MT -O3 -fpp   -I/home/snarayanan1/petsc-release/include -I/home/snarayanan1/petsc-release/arch-ci-mswin-opt-impi/include -I/cygdrive/c/PROGRA~2/Intel/oneAPI/mpi/2021.5.0/include     ex2f.F90  -L/cygdrive/c/cygwin64/home/snarayanan1/petsc-release/arch-ci-mswin-opt-impi/lib -L/cygdrive/c/PROGRA~2/Intel/oneAPI/mkl/2022.0.0/lib/intel64 -lpetsc mkl_intel_lp64_dll.lib mkl_sequential_dll.lib mkl_core_dll.lib /cygdrive/c/PROGRA~2/Intel/oneAPI/mpi/2021.5.0/lib/release/impi.lib Gdi32.lib User32.lib Advapi32.lib Kernel32.lib Ws2_32.lib -o ex2f
$ $PETSC_DIR/lib/petsc/bin/petscmpiexec -n 1 ex2f.exe
Norm of error  0.1214E+02 iterations  2571
KSPSolve time:    104.949
$ $PETSC_DIR/lib/petsc/bin/petscmpiexec -n 2 ex2f.exe
Norm of error  0.1221E+02 iterations  1821
KSPSolve time:     47.139
$ $PETSC_DIR/lib/petsc/bin/petscmpiexec -n 1 ex2f.exe -random_exact_sol
Norm of error  0.8541E+02 iterations  1003
KSPSolve time:     40.853
$ $PETSC_DIR/lib/petsc/bin/petscmpiexec -n 2 ex2f.exe -random_exact_sol
Norm of error  0.8562E+02 iterations  1191
KSPSolve time:     31.745
Thank You,
Sidarth Narayanan
Electronics Thermal Management Intern
Altair Engineering Inc.
Troy, MI
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220816/39a9f47c/attachment-0001.html>
