[petsc-users] Configure error with PETSc 3.17.4 on Ubuntu 22.04
David Knezevic
david.knezevic at akselos.com
Fri Aug 12 12:51:41 CDT 2022
Thanks for this suggestion, using --download-mpich got it working!
David
On Fri, Aug 12, 2022 at 1:25 PM Satish Balay <balay at mcs.anl.gov> wrote:
> We've seen issues with Ubuntu built MPI. Can you try --download-mpich and
> see if that helps?
> Also you don't need --with-clanguage=cxx for complex. PETSc can be built
> with c99 compilex - i.e "--with-clanguage=c --with-scalar-type=complex"
> should work.
> Satish
> On Fri, 12 Aug 2022, David Knezevic via petsc-users wrote:
> > I get a configure error when building PETSc 3.17.4 on Ubuntu 22.04. The
> > configure.log is attached.
> > This error seems to only occur when we use --with-clanguage=cxx. We need
> to
> > use that object when building with complex numbers.
> > Guidance on how to resolve this would be most appreciated.
> > Thanks,
> > David
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220812/7fc5f869/attachment.html>
