[petsc-users] MatView to file
    Alfredo Jaramillo
    ajaramillopalma at gmail.com
    Fri Aug 12 11:59:54 CDT 2022
Hello Mark,
Thank you, I added the lines that you sent.
This only happens when running the code with more than 1 process. With only
1 MPI process the matrix is printed out.
With 2 processes or more I observed the program begins to allocate RAM
until it exceeds the computer capacity (32GB) so I wasn't able to get the
stack trace.
However, I was able to reproduce the problem by compiling
src/ksp/ksp/tutorials/ex54.c.html
<https://petsc.org/release/src/ksp/ksp/tutorials/ex54.c.html> (modifying
line 144) and running it with
mpirun -np 2 ex54 -ne 1000
This gives a sparse matrix of order ~1 million. When running ex54 with only
one MPI process I don't observe this excessive allocation and the matrix is
printed out.
Alfredo
On Fri, Aug 12, 2022 at 10:02 AM Mark Adams <mfadams at lbl.gov> wrote:
> You also want:
>     PetscCall(PetscViewerPopFormat(viewer));
>     PetscCall(PetscViewerDestroy(&viewer));
> This should not be a problem.
> If this is a segv and you configure it with   '--with-debugging=1', you
> should get a stack trace, which would help immensely.
> Or run in a debugger to get a stack trace.
> Thanks,
> Mark
> On Fri, Aug 12, 2022 at 11:26 AM Alfredo Jaramillo <
> ajaramillopalma at gmail.com> wrote:
>> Dear developers,
>> I'm writing a sparse matrix into a file by doing
>>     if (dump_mat) {
>>         PetscViewer viewer;
>>         PetscViewerASCIIOpen(PETSC_COMM_WORLD,"mat-par-aux.m",&viewer);
>>         PetscViewerPushFormat(viewer, PETSC_VIEWER_ASCII_MATLAB);
>>         MatView(A,viewer);
>> This works perfectly for small cases.
>> The program crashes for a case where the matrix A is of order 1 million
>> but with only 4 million non-zero elements.
>> Maybe at some point petsc is full-sizing A?
>> Thank you,
>> Alfredo
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220812/7191b5cc/attachment.html>
