[petsc-users] Issue to set values to a matrix in parallel in python
Matthew Knepley
knepley at gmail.com
Tue Aug 9 10:27:52 CDT 2022
On Tue, Aug 9, 2022 at 11:12 AM Stefano Zampini <stefano.zampini at gmail.com>
wrote:
> PETSc distributes matrices and vectors in parallel. Take a look at
> https://petsc.org/release/docs/manualpages/Vec/VecGetOwnershipRange.html
Longer explanation:
Vectors are distributed by giving a stretch of contiguous rows to each
process. Dense matrices also give a stretch of contiguous rows to each
process.
This means that each matrix column would correspond to a vector. The
easiest way I see to do this is to use
https://petsc.org/main/docs/manualpages/Mat/MatDenseGetColumnVec/
and then VecCopy() each vector into the correct column. If you want to
share memory, allocate the dense matrix first, and make you vectors using
this
routine.
Matt
> > On Aug 9, 2022, at 11:21 AM, Thomas Saigre <saigre at math.unistra.fr>
> wrote:
> > Hi,
> > I've been trying for a few weeks to construct a matrix from a list of
> vectors, unsuccessfully.
> > Here is my problem : I have a list l a petsc4py.Vec, each vector has a
> size n, and I have d vectors. I want to "cast" these vectors to a
> petsc4py.Mat Z of shape (n,d), where Z[:, i] = l[i] (using NumPy notation)
> > Here is the code I'm using :
> > import sys
> > from petsc4py import PETSc
> > n = 5
> > d = 10
> > l = [] # creation of the list of vectors
> > for i in range(d):
> > v = PETSc.Vec().create()
> > v.setSizes(n)
> > v.setFromOptions()
> > v.set(i)
> > l.append(v)
> > Z = PETSc.Mat().create()
> > Z.setSizes([n, d])
> > Z.setFromOptions()
> > Z.setUp()
> > for i, v in enumerate(l):
> > Z.setValues(range(n), i, v)
> > Z.assemble()
> > Z.view() # to display the matrix in the terminal
> > In sequential, the result is correct :
> > Mat Object: 1 MPI processes
> > type: seqaij
> > row 0: (0, 0.) (1, 1.) (2, 2.) (3, 3.) (4, 4.) (5, 5.) (6, 6.)
> (7, 7.) (8, 8.) (9, 9.)
> > row 1: (0, 0.) (1, 1.) (2, 2.) (3, 3.) (4, 4.) (5, 5.) (6, 6.)
> > row 2: (0, 0.) (1, 1.) (2, 2.) (3, 3.) (4, 4.) (5, 5.) (6, 6.)
> > row 3: (0, 0.) (1, 1.) (2, 2.) (3, 3.) (4, 4.) (5, 5.) (6, 6.)
> > row 4: (0, 0.) (1, 1.) (2, 2.) (3, 3.) (4, 4.) (5, 5.) (6, 6.)
> > but when I run it using the command mpirun -np 2 python3 file.py, I get
> the following error, about incompatible array sizes (I did not manage to
> understand what ni, nj and nv correspond to...)
> > Traceback (most recent call last):
> > File "/home/Documents/code/tests/file.py", line 31, in <module>
> > Z.setValues(list(range(n)), i, v)
> > File "PETSc/Mat.pyx", line 888, in petsc4py.PETSc.Mat.setValues
> > File "PETSc/petscmat.pxi", line 828, in petsc4py.PETSc.matsetvalues
> > ValueError: incompatible array sizes: ni=5, nj=1, nv=3
> > File "/home/saigre/Documents/code/tests/t2.py", line 31, in <module>
> > ValueError: incompatible array sizes: ni=5, nj=1, nv=2
> > Two weeks ago, I made a post on stack overflow (
> https://stackoverflow.com/questions/73124230/convert-a-list-of-vector-to-a-matrix-with-petsc4py).
> I tried using the apt packages, and I also compiled from the sources, but I
> get the same error.
> > I someone has an idea how to succeed in it, I'm all ears !
> > Thanks,
> > Thomas
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220809/de1afc9c/attachment-0001.html>
