[petsc-users] [SLEPc] generalized symmetric eigensystem
Patrick Alken patrick.alken at geomag.info
Thu Aug 4 22:04:31 CDT 2022
I am trying to solve a generalized symmetric eigensystem problem using
SLEPc, and I am getting much different eigenvalues compared with the
dense LAPACK solver DSYGVD. I have attached a minimal working example
(MWE). The code relies on the external libraries GSL, Lapack and Lapacke.
The matrices (A,B) come from discretizing the Laplacian in spherical
coordinates using a radial basis function method. Here are the
eigenvalues computed by the dense LAPACK solver:
=== LAPACK eigenvalues ===
eval(0) = 1.309567289750e+00
eval(1) = 1.648674331144e+00
eval(2) = 1.709879393690e+00
eval(3) = 1.709879393690e+00
eval(4) = 2.142210251638e+00
eval(5) = 2.142210251638e+00
eval(6) = 2.145726457896e+00
eval(7) = 2.216526311324e+00
eval(8) = 2.216526311324e+00
eval(9) = 2.695837030236e+00
Here are the eigenvalues computed by SLEPc, using the command:
$ ./mwe -eps_nev 10 -eps_smallest_magnitude -eps_tol 1e-8
Number of requested eigenvalues: 10
  Linear eigensolve converged (10 eigenpairs) due to CONVERGED_TOL;
iterations 196
             k             ||Ax-kBx||/||kx||
         0.094520                906.031
         0.177268                363.291
         1.324501                61.9577
         1.786472                35.7082
         2.187857                32.8364
        -2.886905                27.7314
         2.899206                24.2224
         4.195222                20.3007
         4.787192                12.8346
         7.221589                9.58513
As we can see, the results are quite different than LAPACK and the error
norms in the right column are quite large. Using a stricter tolerance
(eps_tol) does not seem to help. Can anyone suggest how to diagnose and
fix the problem?
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220804/0333098a/attachment.bin>
Type: text/x-chdr
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220804/0333098a/attachment-0001.bin>
default: mwe
include ${SLEPC_DIR}/lib/slepc/conf/slepc_common
lib_dir = /home/palken/usr/lib
common_libs = -L${lib_dir} ${lib_dir}/libgsl.a -lm ${lib_dir}/liblapacke.a ${lib_dir}/liblapack.a
OBJECTS = mwe.o laplace3d.o
mwe: ${OBJECTS}
	${CLINKER} -o mwe ${OBJECTS} ${SLEPC_EPS_LIB} ${common_libs}
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220804/0333098a/attachment-0002.bin>
