[petsc-users] KSPAGMRES Question
Frank Bramkamp
bramkamp at nsc.liu.se
Tue Aug 2 12:18:56 CDT 2022
Dear PETSc team,
I have seen that there is the KSP method: KSPAGMRES,
https://petsc.org/release/docs/manualpages/KSP/KSPAGMRES.html <https://petsc.org/release/docs/manualpages/KSP/KSPAGMRES.html>
I wanted to test this method, as it also seems to reduce the amount of MPI communication, compared
to the standard GMRES.
I supposed that the class is called “KSPAGMRES”.
But in the include files petscksp.h and petsc/finclude/petscksp.h
there is no definition for KSPAGMRES, just KSPDGMRES.
I wonder if the definition KSPAGMRES is simply missing, or do I have to call
DGMRES and set another option for AGMRES ?!
The standard GMRES has the problem that MPI_Allreduce gets expensive for 2048 cores.
Therefore I wanted to see, if AGMRES has a bit less communication, as this is mentioned in the description
of the method.
Greetings, Frank Bramkamp
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220802/53c1f286/attachment.html>
