[petsc-users] PetscSF clarification
Toby Isaac
toby.isaac at gmail.com
Tue Aug 2 11:11:44 CDT 2022
I think you want the PetscSF that can be obtained from calling
DMGetPointSF() <https://petsc.org/release/docs/manualpages/DM/DMGetPointSF.html>
on the mesh created by DMPlexDistribute(), not the PetscSF returned by
DMPlexDistribute() itself.
On Tue, Aug 2, 2022 at 10:54 AM Toby Isaac <toby.isaac at gmail.com> wrote:
> Hi Nicholas,
> What command did you use to view the star forest? What you are
> showing looks like the PetscSF that is used to distribute the points
> from the root, not the final PetscSF describing the points and their
> duplicates once it has been distributed.
> -- Toby
> On Tue, Aug 2, 2022 at 10:28 AM Nicholas Arnold-Medabalimi
> <narnoldm at umich.edu> wrote:
> > Hello
> > I have been trying to follow how PetscSF works, and I'm observing some behavior I don't quite understand. I have been looking at some of the past petsc-user discussions involving PetsSF, and my understanding is that each processor will have roots and leaves; roots are "owned" points, and leaves are ghosts of another processor.
> > I have a setup when I've built the original mesh(6000 points) on just a single processor and then distributed it using DMPlexDistrubute with an overlap and then viewing the generated star forest.
> > My expectation is that roughly 1/p points will end up as roots on each processor, with the overlap points being leaves on each processor. However, instead I get the first processor having 6000 roots with ~ 1/p leaves
> > PetscSF Object: 4 MPI processes
> > type: basic
> > [0] Number of roots=6003, leaves=1587, remote ranks=1
> > [0] 0 <- (0,0)
> > , and then each of the following processors having ~1/p leaves all pointed at the root processor
> > [1] Number of roots=0, leaves=1497, remote ranks=1
> > [1] 0 <- (0,262)
> > Is this the expected outcome? At least to me, this implies the first processor still "owns" all the points. I imagine I misunderstand something here. Thank you for the assistance
> > Sincerely
> > Nicholas
> > Ph.D. Candidate
> > Computational Aeroscience Lab
> > University of Michigan
