[petsc-users] GMRES for outer solver
Jed Brown
jed at jedbrown.org
Sat Apr 30 22:21:47 CDT 2022
In general, no. A fixed number of Krylov iterations (CG, GMRES, etc.) is a nonlinear operation.
A fixed number of iterations of a method with a fixed polynomial, such as Chebyshev, is a linear operation so you don't need a flexible outer method.
Ramakrishnan Thirumalaisamy <rthirumalaisam1857 at sdsu.edu> writes:
> Hi,
> I have a Krylov solver with a preconditioner that is also a Krylov solver.
> I know I can use "fgmres" for the outer solver but can I use gmres for the
> outer solver with a fixed number of iterations in the Krylov
> preconditioners?
> Thanks,
> Rama
