[petsc-users] DMPlex Parallel Output and DMPlexCreateSection Crashes when DMPlexCreateGmshFromFile used
Fri Apr 29 07:51:03 CDT 2022
On Fri, Apr 29, 2022 at 8:27 AM Mike Michell <mi.mike1021 at gmail.com> wrote:
> Thanks for the answers and I agree. Creating dual mesh when the code
> starts and uses that dm will be the easiest way.
> But it is confusing how to achieve that. The entire DAG of the original
> mesh should change, except for vertices. How can PETSc rebuild DAG for
> cells and edges (and faces for 3D)?
In this paper (https://arxiv.org/pdf/0908.4427.pdf), Section 3.1, we show
that the dual is just the original DAG with the arrows
reversed, so it is trivial to construct. There are two issues:
  1) You have to compute the geometry once you have the topology, but you
already do that
  2) In parallel you will produce a mesh with cell overlap, but I think
this is normal for dual methods. We have special methods
      to get around this (we use them in mesh partitioning), which we can
use to parallelize this step.
     Matt
> In 2D for example, I need to reconstruct median-dual edges and cells by
> connecting the cell-centroids and edge-centers in the original mesh.
> Thanks,
> Mike
> On Wed, Apr 27, 2022 at 11:31 PM Mike Michell <mi.mike1021 at gmail.com>
>> wrote:
>>> Thanks for the answers. Major reason that not to store those dual cells
>>> is to share the same grid file with other codes that are required for
>>> coupled physics modeling.
>> Yes, I would create the dual on startup and throw away the original mesh.
>>> As a follow-up question, there is struggling to use PetscSection. I
>>> attached my example code.
>>> The PETSc-provided example, "ex1f90.F90" uses DMPlexCreateSection() to
>>> make a PetscSection object.
>>> However, by reading .msh & creating a DMPlex, none of label is working
>>> with that, except for 'marker' label, which should be provided through
>>> "-dm_plex_gmsh_use_marker" option in case gmsh file is used.
>> I have replaced your startup code with the canonical code we use in C
>> examples. It should be more flexible and robust.
>> Here is the concise output for your mesh:
>> master *:~/Downloads/tmp/Mitchell/Question_3$ ./test -dm_plex_filename
>> new.msh -dm_view
>> DM Object: 1 MPI processes
>>   type: plex
>> DM_0x84000000_1 in 2 dimensions:
>>   Number of 0-cells per rank: 44
>>   Number of 1-cells per rank: 109
>>   Number of 2-cells per rank: 66
>> Labels:
>>   celltype: 3 strata with value/size (0 (44), 3 (66), 1 (109))
>>   depth: 3 strata with value/size (0 (44), 1 (109), 2 (66))
>>   Face Sets: 4 strata with value/size (5 (5), 7 (5), 6 (5), 8 (5))
>> The original code was built to take GMsh markers to canonical names
>> because users wanted that. However, if you want your names preserved, you
>> can use
>> new.msh -dm_view -dm_plex_gmsh_use_regions
>>  MPI information ...            0           1
>>   type: plex
>> Labels:
>>   inlet: 1 strata with value/size (5 (5))
>>   upper: 1 strata with value/size (7 (5))
>>   outlet: 1 strata with value/size (6 (5))
>>   lower: 1 strata with value/size (8 (5))
>> There is also code to mark vertices, which some users do not want, that
>> you can turn on using -dm_plex_gmsh_mark_vertices. I use both of these
>> options with PyLith.
>>> In my .msh file, there are several boundary conditions, and if I declare
>>> labels using them and try to give them to DMGetStratumIS(), the code
>>> crashed. It only works with 'marker' label. Any comments?
>>> More importantly, trying to use DMPlexCreateSection() is quite painful.
>> What is not working for you?
>>> Therefore, I tried to create PetscSection object through
>>> PetscSectionCreate() as attached. But declared vectors are not printed out
>>> if I use this way.
>> If you used the default viewer (PETSC_VIEWER_STDOUT_WORLD), you can see
>> them printed. You are using VTK with a Section that put values on all mesh
>> points. VTK only understands cell fields and vertex fields, so the code
>> does not know how to output this vector. If you define values only on cells
>> or vertices, you will see the output. I believe.
>>   Thanks,
>>      Matt
>>> I guess the section object is not properly linked to dm object.
>>> Basically, my vector objects (x, y, vel) are not seen from dm viewer &
>>> relevant output file. Do you have any recommendations?
>>> Thanks,
>>> Mike
>>> On Tue, Apr 26, 2022 at 7:27 PM Mike Michell <mi.mike1021 at gmail.com>
>>>> wrote:
>>>>> Thanks for the answers. One last question related to designing my
>>>>> code.
>>>>> What I want to do is to build a finite-volume code discretized on
>>>>> "median dual" unstructured mesh. So basically it will use a vertex-centered
>>>>> discretization scheme by looping over "median dual faces", which is not
>>>>> physically existing in my mesh file.
>>>>> I can acheive this by allocating some vectors to compute required
>>>>> geometrical metrics (e.g., face normal vectors, face area, etc. that
>>>>> required to integrate over median dual control volume) as I did before even
>>>>> without PETSc. However, I think this definitely cannot be an optimal way,
>>>>> and I believe there should be much larger benefit that can be obtained, if
>>>>> I well design my DMPlex's data structure (e.g., PetscSection).
>>>>> Is there any example with this median dual control volume case? or Any
>>>>> guideline will be helpful.
>>>>> I was thinking to borrow some functions designed for finite element.
>>>> I have never done a dual scheme before, so let me ask some questions to
>>>> better understand the underlying ideas.
>>>> 1) Is there a reason not to store the dual directly? That seems like
>>>> the easiest approach.
>>>> 2) You can use Plex to layout auxiliary geometric data. I do it the
>>>> following way:
>>>>   DMClone(dm, dmGeom);
>>>>   <Create the Section s you want>
>>>>   DMSetLocalSection(dmGeom, s);
>>>>   PetscSectionDestroy(&s);
>>>> then
>>>>   DMCreateLocalVector(dmGeom, &lv);
>>>> will give you a Vec with the local data in it that can be addressed by
>>>> mesh point (global vectors too). Also you would be able
>>>> to communicate this data if the mesh is redistributed, or replicate
>>>> this data if you overlap cells in parallel.
>>>>   Thanks,
>>>>      Matt
>>>>> Thanks,
>>>>> Mike
>>>>> On Tue, Apr 26, 2022 at 4:48 PM Mike Michell <mi.mike1021 at gmail.com>
>>>>>> wrote:
>>>>>>> Below two interesting things are found:
>>>>>>> - If DMPlexCreateGmshFromFile() is used, DMPlexDistribute() is not
>>>>>>> done by default. I should call DMPlexDistribute() to distribute DMPlex over
>>>>>>> the procs.
>>>>>> Here is the explanation. The default distribution comes from
>>>>>> DMSetFromOptions(), which I am guessing was not called after
>>>>>> DMPlexCreateGmshFromFile().
>>>>>>> - If {DMCreate(), DMSetType(), DMSetFromOptions()} in serially used
>>>>>>> with "-dm_plex_filename ./new.msh" option in command line,
>>>>>>> DMPlexDistribute() is done by default even though DMPlex object is created
>>>>>>> by reading the same .msh file.
>>>>>>> Thanks for the modification to the example ex1f90.F90, now it works
>>>>>>> with 2 procs.
>>>>>>> But still, if I print my output to "sol.vtk", the file has only a
>>>>>>> part of whole mesh. However, the file is okay if I print to "sol.vtu".
>>>>>>> From "sol.vtu" I can see the entire field with rank. Is using .vtu
>>>>>>> format preferred by petsc?
>>>>>> VTK is generally for debugging, but it should work. I will take a
>>>>>> look.
>>>>>> VTU and HDF5 are the preferred formats.
>>>>>>   Thanks,
>>>>>>      Matt
>>>>>>> On Tue, Apr 26, 2022 at 9:33 AM Mike Michell <mi.mike1021 at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> Thank you for the answers.
>>>>>>>>> For the first question, basically, I cannot
>>>>>>>>> run "/dm/impls/plex/ex1f90.F90" example with more than 1 proc. I removed
>>>>>>>>> DMPlexDistribute() following your comment and what I tried is:
>>>>>>>>> - no modification to ex1f90.F90 (as it is)
>>>>>>>>> - make "ex1f90"
>>>>>>>>> - mpirun -np 2 ./ex1f90
>>>>>>>>> It gives me "Bad termination of one of ..." for Rank 1. The code
>>>>>>>>> runs okay with "mpirun -np 1 ./ex1f90".
>>>>>>>> You are correct. It evidently never worked in parallel, since those
>>>>>>>> checks will only work in serial.
>>>>>>>> I have fixed the code, and added a parallel test. I have attached
>>>>>>>> the new file, but it is also in this MR:
>>>>>>>>   https://gitlab.com/petsc/petsc/-/merge_requests/5173
>>>>>>>>   Thanks,
>>>>>>>>      Matt
>>>>>>>>> Thanks,
>>>>>>>>> Mike
>>>>>>>>> On Mon, Apr 25, 2022 at 9:41 PM Mike Michell <
>>>>>>>>>>> Dear PETSc developer team,
>>>>>>>>>>> I'm trying to learn DMPlex to build a parallel finite volume
>>>>>>>>>>> code in 2D & 3D. More specifically, I want to read a grid from .msh file by
>>>>>>>>>>> Gmsh.
>>>>>>>>>>> For practice, I modified /dm/impls/plex/ex1f90.F90 case to read
>>>>>>>>>>> & distribute my sample 2D grid, which is attached. I have two questions as
>>>>>>>>>>> below:
>>>>>>>>>>> (1) First, if I do not use my grid, but use the default box grid
>>>>>>>>>>> built by ex1f90.F90 and if I try "DMPlexDistribute" over mpi processors,
>>>>>>>>>>> the output file (sol.vtk) has only some portion of the entire mesh. How can
>>>>>>>>>>> I print out the entire thing into a single file? Is there any example for
>>>>>>>>>>> parallel output? (Related files attached to "/Question_1/") Paraview gives
>>>>>>>>>>> me some error messages about data size mismatching.
>>>>>>>>>> For the last release, we made parallel distribution the default.
>>>>>>>>>> Thus, you do not need to call DMPlexDIstribute() explicitly here. Taking it
>>>>>>>>>> out, I can run your example.
>>>>>>>>>>> (2) If I create DMPlex object through
>>>>>>>>>>> "DMPlexCreateGmshFromFile", "DMPlexCreateSection" part is crashed. I do not
>>>>>>>>>>> understand why my example code does not work, because the only change was
>>>>>>>>>>> switching from "DMCreate" to "DMPlexCreateGmshFromFile" and providing
>>>>>>>>>>> "new.msh" file. Without the PetscSection object, the code works fine. Any
>>>>>>>>>>> comments about this? (Related files attached to "/Question_2/")
>>>>>>>>>> If I remove DMPlexDistribute() from this code, it is clear that
>>>>>>>>>> the problem is with the "marker" label. We do not create this by default
>>>>>>>>>> from GMsh since we assume people have defined their own labels. You can pass
>>>>>>>>>> to your code. WHen I do this, you example runs for me.
>>>>>>>>>>   Thanks,
>>>>>>>>>>     Matt
>>>>>>>>>>> Thanks,
>>>>>>>>>>> Mike
>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>> experiments lead.
>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220429/1c89bab6/attachment-0001.html>
