[petsc-users] petsc 3.17 mpi configure issue
Ben Pietras
ben.pietras at manchester.ac.uk
Thu Apr 14 08:31:22 CDT 2022
Hello,
If I run
$ ./configure --prefix=$PREFIX --with-mpi-dir=/opt/apps/mpi/gcc/openmpi/4.1.0-numa-ucx-1.9.0--gcc-4.8.5/ LDFLAGS=$LDFLAGS
I get
WARNING! Found environment variable: MPI_DIR=/opt/apps/mpi/gcc/openmpi/4.1.0-numa-ucx-1.9.0--gcc-4.8.5
Ignoring it! Use "./configure MPI_DIR=$MPI_DIR" if you really want to use this value
So, I try:
$ ./configure --prefix=$PREFIX --with-mpi-dir=/opt/apps/mpi/gcc/openmpi/4.1.0-numa-ucx-1.9.0--gcc-4.8.5/ LDFLAGS=$LDFLAGS MPI_DIR=$MPI_DIR
ERROR in COMMAND LINE ARGUMENT to ./configure
The option MPI_DIR should probably be MPI-DIR
Then,
$ ./configure --prefix=$PREFIX --with-mpi-dir=/opt/apps/mpi/gcc/openmpi/4.1.0-numa-ucx-1.9.0--gcc-4.8.5/ LDFLAGS=$LDFLAGS MPI-DIR=$MPI_DIR
Ignoring it! Use "./configure MPI_DIR=$MPI_DIR" if you really want to use this value =============================================================================================
My guess is that this is a bug (there is a '-' where it should be a '_').
If I'm mistaken, could I be advised how to correct?
Best,
Ben
Dr Ben Pietras <ben.pietras at manchester.ac.uk>
Research Infrastructure, IT Services
University of Manchester, UK
ext. 63266
http://ri.itservices.manchester.ac.uk
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220414/49e3217c/attachment-0001.html>
Type: text/x-log
Desc: configure.log
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220414/49e3217c/attachment-0001.bin>
