[petsc-users] DMCloning from a DMPlex has changed in Petsc-3.17.0?
Berend van Wachem
berend.vanwachem at ovgu.de
Tue Apr 12 01:50:18 CDT 2022
Dear Matt,
Thank you very much - I can confirm that that works.
I have one question about your remark:
> Also, the call to DMPlexDistribute() here (and the Partitioner calls)
> are now superfluous.
If I shouldn't call DMPlexDistribute(), how should I set the overlap of
the DM from within the code (our code determines the overlap required)?
Many thanks, best regards,
Berend.
On 4/11/22 16:23, Matthew Knepley wrote:
> On Wed, Apr 6, 2022 at 9:41 AM Berend van Wachem
> <berend.vanwachem at ovgu.de <mailto:berend.vanwachem at ovgu.de>> wrote:
> Dear Matt,
> I have made a small working example of cloning a DM, illustrating the
> problem we have.
> In the attached code, I wrote a function 'CloneDMWithNewSection', which
> clones a section and puts a different number of fields on it.
> The code itself prints the number of local cells of the DM, which
> changes as the DM is cloned.
> In our code, we assume that the cloned DM should have exactly the same
> partitioning - this was the behaviour in PETSc versions prior to 3.17.
> If I run the attached code on 2 processors, I get:
> First DM: Processor 1 reports Start: 0, End 4000 giving number of local
> cells: 4000
> First DM: Processor 0 reports Start: 0, End 4000 giving number of local
> cells: 4000
> Cloned DM: Processor 1 reports Start: 0, End 3984 giving number of
> local
> cells: 3984
> Cloned DM: Processor 0 reports Start: 0, End 4016 giving number of
> local
> cells: 4016
> Maybe we are doing something wrong in the function
> CloneDMWithNewSection?
> I apologize for taking so long on this. Jed persuaded me to change the
> default. Now, when you
> call DMSetFromOptions() it distributes by default, rather than requiring
> you to explicitly call it.
> You can shut this behavior off, so that if you add
> ierr = DMPlexDistributeSetDefault(*NewDM, PETSC_FALSE);CHKERRQ(ierr);
> right after DMClone(), you will preserve the layout you have.
> Thanks,
> Matt
> Many thanks for looking into this, best regards,
> Berend.
> On 4/4/22 23:05, Matthew Knepley wrote:
> > On Mon, Apr 4, 2022 at 3:36 PM Berend van Wachem
> <mailto:berend.vanwachem at ovgu.de <mailto:berend.vanwachem at ovgu.de>>>
> wrote:
> > Dear Petsc team,
> > Since about 2 years we have been using Petsc with DMPlex, but
> since
> > upgrading our code to Petsc-3.17.0 something has broken.
> > First we generate a DM from a DMPlex with
> DMPlexCreateFromFile or
> > creating one with DMPlexCreateBoxMesh. Then the DM is
> distributed with
> > DMPlexDistribute. This DM works fine and we set a numer of
> fields and
> > set a section to it.
> > However, on the same mesh we also want to solve a problem with a
> > different number of fields, and therefore we create a clone
> of this
> > original DM, using the code:
> > DMClone(OriginalDM, NewDM);
> > DMClearDS(*NewDM);
> > PetscCalloc2(1, &NumComp, 4, &NumDof);
> > NumComp[0] = 1;
> > NumDof[3] = NFields;
> > DMSetNumFields(*NewDM, 1);
> > DMSetFromOptions(*NewDM);
> > DMPlexCreateSection(*NewDM, NULL, NumComp, NumDof, 0, NULL,
> NULL, NULL,
> > NULL, §ion);
> > DMSetLocalSection(*NewDM, section);
> > PetscFree2(NumComp, NumDof);
> > PetscSectionDestroy(§ion);
> > However, with Petsc-3.17.0, the *NewDM is corrupt - When I call
> > DMGlobalToLocalBegin with a Global and Local vector created
> with this
> > NewDM, the code crashes. Indeed, the cloned DM seems to be
> partitioned
> > differently than the original DM, as it these two DMs have a
> different
> > number of local cells.
> > The cloned DM will have exactly the same topology and
> distribution. This
> > must be a misinterpretation
> > of what is happening. We can do a few things:
> > 1) Make a small example to show what you are talking about
> > 2) Look at a PETSc example that does something similar
> > 3) Look directly at your code if I can somehow run it here
> > 4) Start doing diagnostics on your code to see what is going on
> > Which one do you prefer?
> > This worked fine in Petsc releases before 3.17 (e.g. 3.16.5).
> So my
> > question is: what has changed? Am I doing something wrong,
> which should
> > be changed for using with Petsc-3.17?
> > I don't think any of this should have changed, so this should be
> > something simple.
> > Thanks,
> > Matt
> > Thanks, best regards,
> > Berend.
> > What most experimenters take for granted before they begin their
> > experiments is infinitely more interesting than any results to which
> > their experiments lead.
> > -- Norbert Wiener
> > https://www.cse.buffalo.edu/~knepley/
> <https://www.cse.buffalo.edu/~knepley/>
> <http://www.cse.buffalo.edu/~knepley/
> <http://www.cse.buffalo.edu/~knepley/>>
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
