[petsc-users] problems with petsc4py on M1 mac when configuring PETSc
Veronika Ulanova
19veronika97 at gmail.com
Fri Apr 8 04:41:24 CDT 2022
I pulled the updated repo but now I get a different error also related to
architecture:
ld: file not found: @rpath/libgcc_s.1.1.dylib for architecture arm64
clang: error: linker command failed with exit code 1 (use -v to see
invocation)
error: command
'/Users/veronikaulanova/Documents/documents/Oxford_work/petsc/arch-darwin-c-debug/bin/mpicc'
**************************ERROR*************************************
Error building petsc4py.
make[2]: *** [petsc4pybuild] Error 1
***************************ERROR**************************************
* Error during compile, check arch-darwin-c-debug/lib/petsc/conf/make.log*
* Send it and arch-darwin-c-debug/lib/petsc/conf/configure.log to
petsc-maint at mcs.anl.gov <petsc-maint at mcs.anl.gov>*
Any idea about this one? Thank you
On Fri, Apr 8, 2022 at 10:09 AM Veronika Ulanova <19veronika97 at gmail.com>
wrote:
> Hello Satish,
> By the repo you mean the main PETSc repository?
> Thank you, Veronika
> On Fri, Apr 8, 2022 at 9:49 AM Satish Balay <balay at mcs.anl.gov> wrote:
>> A fix for M1 was recently pushed to the git repo.
>> Can you try using it [with either release or main branches] - and see if
>> that works?
>> Satish
>> On Fri, 8 Apr 2022, Veronika Ulanova wrote:
>> > Hi,
>> > I have been trying to configure the petsc4py package along with my PETSc
>> > installation for my research. I have searched for solutions on the
>> internet
>> > but there was no luck, this is the error I get when I am trying to
>> > configure PETSC and use it to run examples of code that utilise the
>> > petsc4py package...
>> > File
>> "/Users/veronikaulanova/Documents/documents/Oxford_work/petsc/arch-darwin-c-debug/lib/petsc4py/PETSc.py",
>> > line 3, in <module>
>> > PETSc = ImportPETSc(ARCH)
>> > File
>> "/Users/veronikaulanova/Documents/documents/Oxford_work/petsc/arch-darwin-c-debug/lib/petsc4py/lib/__init__.py",
>> > line 29, in ImportPETSc
>> > return Import('petsc4py', 'PETSc', path, arch)
>> > File
>> > line 73, in Import
>> > module = import_module(pkg, name, path, arch)
>> > File
>> > line 58, in import_module
>> > with f: return imp.load_module(fullname, f, fn, info)
>> > File "/opt/homebrew/Cellar/python at 3.9
>> /3.9.10/Frameworks/Python.framework/Versions/3.9/lib/python3.9/imp.py",
>> > line 242, in load_module
>> > return load_dynamic(name, filename, file)
>> > line 342, in load_dynamic
>> > return _load(spec)
>> > ImportError:
>> dlopen(/Users/veronikaulanova/Documents/documents/Oxford_work/petsc/arch-darwin-c-debug/lib/petsc4py/lib/arch-darwin-c-debug/
>> > PETSc.cpython-39-darwin.so <http://petsc.cpython-39-darwin.so/>, 2): no
>> > suitable image found. Did find:
>> > PETSc.cpython-39-darwin.so <http://petsc.cpython-39-darwin.so/>:
>> mach-o,
>> > but wrong architecture
>> > PETSc.cpython-39-darwin.so <http://petsc.cpython-39-darwin.so/>: stat()
>> > failed with errno=25
>> > As you can see I am using an M1 mac and therefore that causes the
>> petsc4py
>> > package to give me an error (highlighted above), but do you have any
>> idea
>> > of how I can solve it or why it is even there? I know that the new M1
>> has a
>> > different architecture to intel macs but I have no idea of where to
>> > start with fixing this or how to make it work. Any help would be much
>> > appreciated, thank you in advance.
>> > Kind Regards, Veronika
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220408/ca507f8c/attachment.html>
