[petsc-users] problems with petsc4py on M1 mac when configuring PETSc
Veronika Ulanova
19veronika97 at gmail.com
Fri Apr 8 03:20:16 CDT 2022
I have been trying to configure the petsc4py package along with my PETSc
installation for my research. I have searched for solutions on the internet
but there was no luck, this is the error I get when I am trying to
configure PETSC and use it to run examples of code that utilise the
petsc4py package...
File
"/Users/veronikaulanova/Documents/documents/Oxford_work/petsc/arch-darwin-c-debug/lib/petsc4py/PETSc.py",
line 3, in <module>
PETSc = ImportPETSc(ARCH)
File
"/Users/veronikaulanova/Documents/documents/Oxford_work/petsc/arch-darwin-c-debug/lib/petsc4py/lib/__init__.py",
line 29, in ImportPETSc
return Import('petsc4py', 'PETSc', path, arch)
File
line 73, in Import
module = import_module(pkg, name, path, arch)
File
line 58, in import_module
with f: return imp.load_module(fullname, f, fn, info)
File "/opt/homebrew/Cellar/python at 3.9/3.9.10/Frameworks/Python.framework/Versions/3.9/lib/python3.9/imp.py",
line 242, in load_module
return load_dynamic(name, filename, file)
line 342, in load_dynamic
return _load(spec)
ImportError:
dlopen(/Users/veronikaulanova/Documents/documents/Oxford_work/petsc/arch-darwin-c-debug/lib/petsc4py/lib/arch-darwin-c-debug/
PETSc.cpython-39-darwin.so <http://petsc.cpython-39-darwin.so/>, 2): no
suitable image found. Did find:
PETSc.cpython-39-darwin.so <http://petsc.cpython-39-darwin.so/>: mach-o,
but wrong architecture
PETSc.cpython-39-darwin.so <http://petsc.cpython-39-darwin.so/>: stat()
failed with errno=25
As you can see I am using an M1 mac and therefore that causes the petsc4py
package to give me an error (highlighted above), but do you have any idea
of how I can solve it or why it is even there? I know that the new M1 has a
different architecture to intel macs but I have no idea of where to
start with fixing this or how to make it work. Any help would be much
appreciated, thank you in advance.
Kind Regards, Veronika
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220408/8bb6d904/attachment.html>
