[petsc-users] SNES Matrix-Free Parameters
Alfredo J Duarte Gomez aduarteg at utexas.edu
Wed Apr 6 14:13:41 CDT 2022
Good afternoon petsc team,
I have a few questions regarding the matrixfree in the snes context.
I am currently using the matrix-free method with my own preconditioner to
solve a TS problem. I currently trigger this with the -snes_mf_operator
option.
So far the default values have been working great, but I ran into trouble
during a convergence study when I made the time step very small, which I
suspect is probably happening because it's dropping below the matrix-vector
product tolerance.
I wanted to explore the parameters of the matrix-vector product but using
the -snes_view option I notice that the following full message comes out:
SNES Object: 96 MPI processes
  type: newtonls
  maximum iterations=20, maximum function evaluations=10000
  tolerances: relative=1e-06, absolute=1e-06, solution=1e-15
  total number of linear solver iterations=14
  total number of function evaluations=35
  norm schedule ALWAYS
  Jacobian is never rebuilt
  Jacobian is applied matrix-free with differencing
  Jacobian is applied matrix-free with differencing, no explict Jacobian
  SNESLineSearch Object: 96 MPI processes
    type: l2
    maxstep=1.000000e+08, minlambda=1.000000e-12
    tolerances: relative=1.000000e-08, absolute=1.000000e-15,
lambda=1.000000e-08
    maximum iterations=1
  KSP Object: 96 MPI processes
    type: gmres
      restart=100, using Classical (unmodified) Gram-Schmidt
Orthogonalization with no iterative refinement
      happy breakdown tolerance 1e-30
    maximum iterations=400, initial guess is zero
    tolerances:  relative=0.01, absolute=1e-50, divergence=10000.
    left preconditioning
    using PRECONDITIONED norm type for convergence test
  PC Object: 96 MPI processes
    type: shell
      MyPreconditioner
    linear system matrix followed by preconditioner matrix:
    Mat Object: 96 MPI processes
      type: mffd
      rows=8400000, cols=8400000
        Matrix-free approximation:
          err=1.49012e-08 (relative error in function evaluation)
          Using wp compute h routine
              Does not compute normU
      type: mpiaij
      rows=8400000, cols=8400000, bs=4
      total: nonzeros=2041029504, allocated nonzeros=2041029504
      total number of mallocs used during MatSetValues calls=0
I have been focusing specifically on the part:
I notice that this part of the message does not change even when I specify
"-snes_mf_type default" (which is the alternative to wp), so I am a bit
confused on how I interact to the -snes_mf_type or if I am interpreting the
message wrong. Could you clarify this?
Also let me know if you have any general suggestions on tightening the
tolerance of the matricxvector products.
Thank you,
-Alfredo
Alfredo Duarte
Graduate Research Assistant
The University of Texas at Austin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220406/76b8920b/attachment.html>
