[petsc-users] PC shell destroy
Alfredo J Duarte Gomez aduarteg at utexas.edu
Thu Sep 30 15:14:17 CDT 2021
Good afternoon PETSC team,
I am currently developing an application for PETSC in which I use my own
preconditioner with a PCSHELL.
I have successfully set all the functions and the performance of the
preconditioner is good. I am using this PCSHELL within a TS object, and it
is imperative that the objects in the PCSHELL context are freed every time
since the memory requirements of those are large.
I have set up the Preconditioner before the TS starts with the following
block of code:
ierr = PCSetType(pc,PCSHELL);CHKERRQ(ierr);
  ierr = ShellPCCreate(&shell);CHKERRQ(ierr);
  ierr = PCShellSetApply(pc,MatrixFreePreconditioner);CHKERRQ(ierr);
  ierr = PCShellSetContext(pc,shell);CHKERRQ(ierr);
  ierr = PCShellSetDestroy(pc,ShellPCDestroy);CHKERRQ(ierr);
  ierr = PCShellSetName(pc,"MyPreconditioner");CHKERRQ(ierr);
  ierr = ShellPCSetUp(pc,da,0.0,dt,u,user);CHKERRQ(ierr);
  ierr = TSSetPreStep(ts,PreStep);CHKERRQ(ierr);
The shell context is then updated by using the following code within the
TSPreStep function:
 ierr = TSGetSNES(ts,&snes);CHKERRQ(ierr);
  ierr = SNESGetKSP(snes,&ksp);CHKERRQ(ierr);
  ierr = KSPGetPC(ksp,&pc);CHKERRQ(ierr);
  // Get necessary objects from TS context
  TSGetTime(ts,&time);
  TSGetApplicationContext(ts,&user);
  TSGetSolution(ts,&X);
  TSGetTimeStep(ts,&dt);
  TSGetStepNumber(ts, &stepi);
  TSGetDM(ts,&da);
  tdt = time+dt;
  // Update preconditioner context with current values
  ierr = ShellPCSetUp(pc,da,tdt,dt,X,user);CHKERRQ(ierr);
I have set up the necessary code in the function ShellPCDestroy to free the
objects within this context, however I am unsure when/if this function is
called automatically. Do I have to free the context myself after every
step? How would I call the function myself?
I am running out of memory after a few steps, and I think this shell
context is the culprit.
In addition to that, is it possible to get what is called the "ashift" dF/dU
+ a*dF/dU_t in this function from the TS object?
https://petsc.org/release/docs/manualpages/TS/TSSetIJacobian.html
I need it as an input for my preconditioner (currrently hardcoded for
TSBEULER where ashift is always 1/dt).
Thank you,
-Alfredo
Alfredo Duarte
Graduate Research Assistant
The University of Texas at Austin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210930/28bef399/attachment.html>
