[petsc-users] %T (percent time in this phase)
    Matthew Knepley
    knepley at gmail.com
    Wed Sep 29 04:58:05 CDT 2021
On Wed, Sep 29, 2021 at 5:52 AM Karthikeyan Chockalingam - STFC UKRI <
karthikeyan.chockalingam at stfc.ac.uk> wrote:
> That was helpful. I would like to provide some additional details of my
> run on cpus and gpus. Please find the following attachments:
>    1. graph.pdf a plot showing overall time and various petsc events.
>    2. ksp_ex45_N511_cpu_6.txt data file of the log_summary
>    3. ksp_ex45_N511_gpu_2.txt data file of the log_summary
> I used the following petsc options for cpu
> mpirun -n 6 ./ex45 -log_summary -da_grid_x 511 -da_grid_y 511 -da_grid_z
> 511 -dm_mat_type mpiaij -dm_vec_type mpi -ksp_type cg -pc_type bjacobi
> -ksp_monitor
> and for gpus
> mpirun -n 1 ./ex45 -log_summary -da_grid_x 511 -da_grid_y 511 -da_grid_z
> 511  -dm_mat_type mpiaijcusparse -dm_vec_type mpicuda -ksp_type cg -pc_type
> bjacobi -ksp_monitor
> to run the following problem
> https://petsc.org/release/src/ksp/ksp/tutorials/ex45.c.html
> From the above code, I see is there no individual function called KSPSetUp(),
> so I gather KSPSetDM, KSPSetComputeInitialGuess, KSPSetComputeRHS,
> kSPSetComputeOperators all are timed together as KSPSetUp. For this
> example, is KSPSetUp time and KSPSolve time mutually exclusive?
No, KSPSetUp() will be contained in KSPSolve() if it is called
automatically.
> In your response you said that
>    “PCSetUp() time may be in KSPSetUp() or it maybe in PCApply() it
> depends on how much of the preconditioner construction can take place
> early, so depends exactly on the preconditioner used.”
> I don’t see a explicit call to PCSetUp() or  PCApply() in ex45; so for
> this particular preconditioner (bjacobi) how can I tell how they are timed?
They are all inside KSPSolve(). If you have a preconditioned linear solve,
the oreconditioning happens during the iteration. So an iteration would
mostly
consist of MatMult + PCApply, with some vector work.
> I am hoping to time KSP solving and preconditioning mutually exclusively.
I am not sure that concept makes sense here. See above.
     Matt
> Kind regards,
> Karthik.
> *From: *Barry Smith <bsmith at petsc.dev>
> *Date: *Tuesday, 28 September 2021 at 19:19
> *To: *"Chockalingam, Karthikeyan (STFC,DL,HC)" <
> *Cc: *"petsc-users at mcs.anl.gov" <petsc-users at mcs.anl.gov>
> *Subject: *Re: [petsc-users] %T (percent time in this phase)
> On Sep 28, 2021, at 12:11 PM, Karthikeyan Chockalingam - STFC UKRI <
> Thanks for Barry for your response.
> I was just benchmarking the problem with various preconditioner on cpu and
> gpu. I understand, it is not possible to get mutually exclusive timing.
> However, can you tell if KSPSolve time includes both PCSetup and PCApply?
> And if KSPSolve and KSPSetup are mutually exclusive? Likewise for PCSetUp
> and PCApply.
>    If you do not call KSPSetUp() separately from KSPSolve() then its time
> is included with KSPSolve().
>    PCSetUp() time may be in KSPSetUp() or it maybe in PCApply() it depends
> on how much of the preconditioner construction can take place early, so
>    So yes the answer is not totally satisfying. The one thing I would
> recommend is to not call KSPSetUp() directly and then KSPSolve() will
> always include the total time of the solve plus all setup time. PCApply
> will contain all the time to apply the preconditioner but may also include
> some setup time.
>   Barry
> Best,
> Karthik.
> *Date: *Tuesday, 28 September 2021 at 16:56
> On Sep 28, 2021, at 10:55 AM, Karthikeyan Chockalingam - STFC UKRI <
> Hello,
> I ran ex45 in the KPS tutorial, which is a 3D finite-difference Poisson
> problem. I noticed from the output from using the flag -log_summary that
> for various events their respective %T (percent time in this phase) do not
> add up to 100 but rather exceeds 100. So, I gather there is some overlap
> among these events. I am primarily looking at the events KSPSetUp,
> KSPSolve, PCSetUp and PCSolve. Is it possible to get a mutually exclusive
> %T or Time for these individual events? I have attached  the log_summary
> output file from my run for your reference.
>   For nested solvers it is tricky to get the times to be mutually
> exclusive because some parts of the building of the preconditioner is for
> some preconditioners delayed until the solve has started.
>   It looks like you are using the default preconditioner options which for
> this example are taking more or less no time since so many iterations are
> needed. It is best to use -pc_type mg to use geometric multigrid on this
> problem.
>   Barry
> Thanks!
> Karthik.
> This email and any attachments are intended solely for the use of the
> named recipients. If you are not the intended recipient you must not use,
> disclose, copy or distribute this email or any of its attachments and
> should notify the sender immediately and delete this email from your
> system. UK Research and Innovation (UKRI) has taken every reasonable
> precaution to minimise risk of this email or any attachments containing
> viruses or malware but the recipient should carry out its own virus and
> malware checks before opening the attachments. UKRI does not accept any
> liability for any losses or damages which the recipient may sustain due to
> presence of any viruses.
> <ksp_ex45_N511_cpu_6.txt>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210929/8c9d309e/attachment.html>
