[petsc-users] Turn off CUDA Devices information
Yiyang Li liyiyang30 at gmail.com
Tue Sep 28 12:44:33 CDT 2021
Yes, I do have superlu_dist built with petsc.
The command I used for launching simulation is
mpiexec  --mca btl self,vader,tcp
               -np 4  python3 .../main.py ./input_ls
               -pc_type lu -pc_factor_mat_solver_type superlu_dist
-pc_asm_type basic -cuda_device NONE
On Mon, Sep 27, 2021 at 6:43 PM Satish Balay <balay at mcs.anl.gov> wrote:
> Do you have petsc built with superlu_dist?
> Satish
> On Mon, 27 Sep 2021, Yiyang Li wrote:
> > Hello,
> > I have CUDA aware MPI, and I have upgraded from PETSc 3.12 to PETSc
> 3.15.4
> > and petsc4py 3.15.4.
> > Now, when I call
> > PETSc.KSP().solve(..., ...)
> > The information of GPU is always printed to stdout by every MPI rank,
> like
> > CUDA version:   v 11040
> > CUDA Devices:
> > 0 : Quadro P4000 6 1
> >   Global memory:   8105 mb
> >   Shared memory:   48 kb
> >   Constant memory: 64 kb
> >   Block registers: 65536
> > CUDA Devices:
> > I wonder if there is an option to turn that off?
> > I have tried including
> > -cuda_device NONE
> > in command options, but that did not work.
> > Best regards,
> > Yiyang
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210928/d1139f15/attachment.html>
