[petsc-users] %T (percent time in this phase)
Barry Smith
bsmith at petsc.dev
Tue Sep 28 10:56:11 CDT 2021
> On Sep 28, 2021, at 10:55 AM, Karthikeyan Chockalingam - STFC UKRI <karthikeyan.chockalingam at stfc.ac.uk> wrote:
> Hello,
> I ran ex45 in the KPS tutorial, which is a 3D finite-difference Poisson problem. I noticed from the output from using the flag -log_summary that for various events their respective %T (percent time in this phase) do not add up to 100 but rather exceeds 100. So, I gather there is some overlap among these events. I am primarily looking at the events KSPSetUp, KSPSolve, PCSetUp and PCSolve. Is it possible to get a mutually exclusive %T or Time for these individual events? I have attached the log_summary output file from my run for your reference.
For nested solvers it is tricky to get the times to be mutually exclusive because some parts of the building of the preconditioner is for some preconditioners delayed until the solve has started.
It looks like you are using the default preconditioner options which for this example are taking more or less no time since so many iterations are needed. It is best to use -pc_type mg to use geometric multigrid on this problem.
Barry
> Thanks!
> Karthik.
> This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses.
> <ksp_ex45_N511_cpu_6.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210928/775c25de/attachment.html>
